Question about Mitsubishi WD-57732 Projection Television
Dead lamp!!! I have a mitsubishi WD-57732 dlp tv. I replaced the bulb in it about a month ago it lasted 2 weeks so I got another one it lasted 2 days!! Am I on a roll or what? Does anybody know what could be the problem?
  • 51 Answers
Is it tha lamp cracked? are you using original lamp from mits? i founded people using aftermarket lamps with other specks this lamp is 150 watts ,this info its going to help.
if components on the Power board K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects are a deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010 let me know if you need anything else
Posted on Jul 04, 2008
  • Dale McDuffie
    Dale McDuffie Aug 20, 2014
    The lamp is cracked. I put in a new lamp housing (factory model) and the TV wirked all evening but when we turned it off, there was a pop and I took out the lamp housing and you can see the lamp is busted.
My replacement bulbs keep burning out within 30 days. I took a closer look and there is a small square piece of glass that sits next to the lamp housing. It looks as if the light from the lamp goes through...
Something is definitely wrong if you are consistently only getting a month out of a bulb.
Either something is overdriveing the power to the bulb (unlikely) or there is a vibration or something is intruding on the bulb itself.
Good luck and let us know what you find on this.
Jan 08, 2015 | Mitsubishi WD-57732 Projection Television
How can you diagnose a failed lamp in a Mitsubishi DLP WD 52631
Remove the lamp and do a visual inspection.
If this is a DLP you may have a bad color wheel! whistling sound is a sign of color wheel.
Good luck to you
www.aaatvservice.com
May 08, 2012 | Mitsubishi TV Lamp 915P049010 for WD-52631...
I replaced the bulb on my mitsubishi DLP WD-57732 57 in DLP TV. A few months later a white hazeappeared on the screen.
The problem seems to be a malfunctioning DMD module. Do you still have sound when this haze appears? Are all the other controls such as volume up/down, channel up/down operational?
Jan 16, 2011 | Mitsubishi WD-57733 57" HDTV
Mitsubishi wd-73736 bulbs buzzing noise
The Ballast that ignites the Lamp could cause the Lamp to fail and/or cause a buzzing noise. That being said, the Color Wheel in the Optical Block assembly could also cause a similar symptom. If Mitsubishi would be willing to help with the Lamp cost, I would call a local Mitsubishi repair facility to install it and see if the noise is still there and find out exactly what is causing it. Mitsubishi Customer Service Phone number is 1800-332-2119.
I hope this helps,
Skyassoc
Oct 24, 2009 | Mitsubishi WD-73736 Television
LAMP JUST WENT OUT
I have a 57" DLP and have replaced the bulb 3 times in 2&1/2 years. I'm not possitive but I think I have 6-800 hrs on it total. Mitsubishi claims it a part they expect to go out, but the told me they typically last about ten yrs. If you have proof of purchase they will send you a new one for free, otherwise it'll cost you about $150 on ebay.
May 29, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a wd 57732 and want to replace just the lamp, how do i take the housing unit off? and is it safe?
Hi! It's perfectly safe! Just be sure to always wait an hour or preferebly more before doing this, and unplug the tv! On a DLP tv such as this there is a hatch with two phillips screws holding the cover on for the bulb assembly. Remove them 2 screws. Remove the cover and you will see two thumbscrews that may need extra help from a screwdiver as they may be too tight. Now put on a pair of vinyl or rubber gloves and pull the lamp cartridge absolutly straight out with no twist motion!. Glass lamp section will potentially fall if you do. Place the cartridge on a flat surface and find the 3 tabs on the lamp unit and carefully pry them off. Inside, take out the 4 screws and the mounting brackets holding bulb. At this point you can clean out dust inside the lamp box. Next take out the old bulb, put the new one in (be sure to use the gloves installing new bulb or else any finger oil will cause the bulb to fail when it gets hot) and reverse steps to close.
Nov 14, 2008 | Mitsubishi WD-57732 Projection Television
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-57732 Projection Television Logo
198 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
