My rio is stuck in saving settings screen - Audio Players & Recorders
  • tmgrandillo Oct 04, 2008
    i have the same problem, please help....my rio is stuck in "saving..."
    What can I do to resolve this?
    Thx.
Had the same problem. I opened it up by removing the screw under serial # and then 2 other screws through holes. The power button had broken on the circuit board not the plastic clip. I pried silver clip off and removed the toggle - removed the plastic button on the shell and use a mini screw driver to turn on and off. Works like a champ as long as I have something to insert there a short the connection to power on.
Posted on Jan 05, 2010
My rio phone was on orange, i got it unblocked so its o2 but i cant get internet on iv rang o2 they cant help.
bsically the rio had an orange language pack on it, that had all the internet settings on it.... ask 02 if they cn sewnd u the message settings, they wont support that fone so say that is a smsung s5230o and see if the settings come thru in the form of a text and then click options and save or input.
Mar 26, 2011 | Cell Phones
Engin shake at idle and engin light is on but it is smoth in speed driving,checked the vacc.leak system no broblem with it,its 2002 Kia Rio
check and see what engine codes are set.you could have a egr valve stuck open. tps shorted open.idle air control valve dirty stuck open,fuel injectors dirty may need injector flush.hope this helped
Oct 28, 2009 | 2002 Kia Rio
Kia rio rear seat belt got stuck ?
have to change seat belt
Oct 03, 2009 | 2002 Kia Rio
Rio carbon
Insert a paper clip end into the small hole to the right of the headphone socket. This will reset it (if it's not already gone flat!)
Mowcius
Jul 04, 2008 | Rio Carbon MP3 Player
Can not copy files from Rio Karma to PC
Files can be copied to the computer from the karma although it doesn't work all that well.
You'll need to use Rio Taxi. I think you can get that if you connect the karma to your network using the dock then browse to the karma's ip address and get it. If not you may have to try and find a place to download it.
Nov 07, 2007 | Rio Karma MP3 Player
Rio Carbon stuck "WRITING"
The writing message may appear for a good forty minutes after completing the firmware upgrade - make sure your player is fully charged and just let it sit for an hour on that writing status - it will stop eventually.
Sep 10, 2007 | Rio Carbon MP3 Player
Saving Settings
1) Make sure that you use your MP3 Player carefully. Don't drop it. and put it in a safe place. 2) Charge your Player only when its battery nearly empty. 3) leave some storage available, like 10% of your storage. 4) Unplug it from your PC when you aren't using it. 5) Use safe removal when removing it from your PC. 6) When you don't use it, Shut it down. Good Luck
Jun 03, 2007 | Rio Nitrus MP3 Player
Need help with rio forge mp3!! its messed up
Same problem here. No amount of updates or battery removal will help. Purging, re-downloading, reformatting...all failed. I'm afraid at this point there is nothing left to do but toss it.
Mar 29, 2007 | Rio Forge Sprot MP3 Player
My rio used to say upgrator and now its not turning on at all.
I think when you hit the on/off power button (on top near outlet for headphones) AND hit the menu button (on side below volume dial) at same time...it puts the Rio CE2100 into "Upgrader" mode aka "Recovery" mode. From what I've found online, basically, the firmware to the device is deleted. Trying to reinstall firmware, or reflash the device is nearly impossible. The tiny hole near the earphones is for resetting the device--use a needle (about the only thing that will fit-ouch)...but that only lets you turn it on/off if u get stuck. The tiny hole on face near display is where audio recording mic WOULD be if Rio CE2100 had one. If ANYONE knows how to escape "Recovery mode" or "Upgrader" mode please share. This is a common final result for many owners of this otherwise great mp3 player. There is some notation in online help site that says ce2100 requires 500mA from USB and says u can go to Device manager, check ur USB Root Hub, check Power tab to see how much power is being supplied to the device. Mine said 100mA, and doesn't work...but I don't know how to resolve this. =) Maybe tomorrow...or just wait for sales post-christmas. =)
Sep 08, 2006 | Rio CE2100 MP3 Player
Frozenj
The reset button is the tiny hole on the top of the player to the left of the volume wheel. Use a paper clip to stick in the hole and push in the reset button for a second. Your screen should turn black and then turn off. Hopefully that will work!
Jul 08, 2006 | Rio CE2100 MP3 Player
74 people viewed this question
 Grubhead
Grubhead
