Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
The embroidery carriage
When I turn the unit on the carriage moves, but not into the standby position and the red lights flash while it continues to beep. I have turned it off, unhooked everything, restarted everything, retreaded everything, but nothing seems to work. Help!!!
  • rsumpter Jul 15, 2008
    Yes, I did try that. I also retreaded it, changed the bobbin out, restarted my computer, and anything else I could think of.
    Problem Solver:
  • 4 Answers
Wow, I finally get to have a solution.
1. Turn the machine off.
2. Remove the hoop.
3. CAREFULLY slide the bar on the embroidery unit to the left.
4. CAREFULLY slide the piece where the hoop attaches toward you.
5. Turn on the sewing machine. The machine should take the unit to "standby" with a click.
6. Attach the hoop with the power on.
7. Exit the Futura program.
8. Restart the software.
This "should" fix the problem, however, you may have to repeat this process more than once to get it to "stick".
Posted on Jul 31, 2008
  • Jonigirl Dec 22, 2012
    Liberty God Bless you! Thank you so very much!was so depressed bout this!i have a terminal child,was trying to some side work for her meds,when quit i lost it!this did it
  • 64 Answers
Which hoop do you have connected when you switch on the machine? It should be a large one, not small.
Posted on Jul 15, 2008
Have you tried moving the needle manually to a higher position?
Posted on Jul 14, 2008
My xl400 singer embroidery carriage has stopped working. Will not move at all when machine is turned on. Also keep getting msg error about hoop size but no hoop attached.
The switch for "sew" or "embroidery" must first be in the "embroidery" position.
Make sure the connections are very firmly pushed in.
If it still isn't functional it may require some small motors to be replaced. The motors are what makes the hoop move.
Sep 28, 2016 | Singer Futura Xl-400 All-In-One Sewing And...
Embroidery unit
This can happen, click back to tools option check whether hoops selection is correct. If this is not the problem, off your machine then put on again. If message remain pull out the embroidery carriage & push in again. Hope it can work.
In jam situation, just exit from your embroidery option, fix the jam by moving the embroidery carriage, work on a different design and see if it work. Sometime a design may not work fully.
Sep 29, 2013 | Singer CE-100 Futura Computerized Sewing...
Board
Close your futura file & exit, switch off your futura machine. Disconnect the embroidery unit from the machine,move the hoop carriage a bit to the left then to the right & it should be able to move. Connect back embroidery unit to your futura machine,ensuring the connecting point click properly. Re thread the machine & ensure needle is fully up position. Now you switch on the machine, you will see hoop carriage moving and stop at its zero point. If that is OK and the earlier led blinking gone, you should be able to operate the futura embroidery program again.
Jul 18, 2013 | Singer CE-200 Quantum Futura Computerized...
FQ-4 keeps beeping
it's possible that the motherboard that controls the embroidery
has a problem that needs servicing
Dec 22, 2012 | Sewing Machines
Embroidery machine is making grinding noise and carriage doesn't move. Then, screen says malfuntion, turn machine off.
Just because the hoop holder has been moved during transportation. Shut down the machine, manually bring hoop holder in central position in both X and Y, it will restart.
Apr 20, 2012 | Brother PE770 Computerized Sewing Machine
Hoop carriage is stuck
mine soes thissometimes, when you turn it on and it starts to beep, i move the presse foot lever up or down, and it should stop.
Aug 26, 2009 | Singer CE-200 Quantum Futura Computerized...
The carriage of the embroidery unit is not move automatically to the embroidering standby position.
Is the need in upright position ?
or have you fitted the embroidery hoop correctly.
If all else fails switch off and start up again - should then automatically go to correct position.
May 16, 2008 | Singer CE-200 Quantum Futura Computerized...
Futura ce 200
I had the same problem and found that the feed dogs must be in the lowered position otherwise nothing will happen,remove the embroidery unit and check the selector and try again,
Mar 24, 2008 | Singer CE-200 Quantum Futura Computerized...
Needle sticking on hoop
When you switch the machine on with the embroidery unit on, it is suppose to calibrate itself and move the bottom left position. If not, the problem lies with the embroidery unit. If the machine is still under warranty your dealer should fix it free of charge.
Jan 17, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer Quantum Futura CE-200 Problem
My machine did the same thing. I had several frustrated nights ans then it just started to work. Some suggestions that I had was that there may be dust where the units connect. Not sure what I did, but it worked.
Dec 27, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
254 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
