Question about Samsung Televison & Video
We are having trouble connecting our dvd player to our samsung tv.
  • 51 Answers
Couple of ways but the easiest way would be connecting the video and audio out from DVD need rca connections yellow red and white)
Yellow --- Video
white and red is audio out left and right.
find in your tv set inputs with similar colors its going to be input 1
or input 2 (as an example)
once you conect the cable matching colors yellow to yellow red to red and white to white make sure you select the same input on your set (video 1 or 2) that its throu input selection in remote control from tv or set itself.
Posted on Jul 04, 2008
I just bought a Samsung HT-C5800 Blu-Ray DVD player and connected it to my TV. (Which is also a Samsung) I am having trouble with my remote control. The remote for the DVD player will not work for the...
Make sure nothing is blocking the front of your DVD player. You need a clear line of sight between the lower right corner of the DVD player where the sensor is and your remote. If your DVD player is sitting high on a shelf or lower than you are when you are sitting in front of the TV, it may be at a bad angle to "see" the remote.
This will sound crazy, but it often works: While standing up, point your remote at the wall opposite your DVD player at about the same height, and see if it works! This is a sure sign that the angle between where you are using your remote and your DVD player needs to be adjusted.
FYI- this often works because bouncing the remote beam off of an opposite wall spreads it more than pointing toward it, and is a good way to test your remote.
Feb 24, 2011 | Televison & Video
I got a new Samsung DVD player (1080) and when I put on brand new discs in it, it just kept whirring inside, but nothing came up on the screen ! I have it connected via HDMI cable to a Samsung LCD TV, so...
If a new DVD player ur tv dose recgonises the DVD disc and not reading the DVD disc,it might be dirty or scratches and cracks on the DVD disc itself.Tries It with other DVD discs,if have the same problems,than it is the DVD player itself,newly bought,yes return it get another one.
Dec 15, 2010 | Samsung DVD-H1080 DVD Player
Connecting samsung dvd to Philips 47PFL6704D LCD TV
Hook up your cables from your DVD player to these input on the back of your TV. 6131e0b.jpg The group of ports should be labeled as video 1 input. Use the Yellow, Red and White on the back of both DVD Player and TV. Then, change the input on the TV remote to input or video 1 to watch the DVD Player.
Sep 28, 2009 | Philips 47PFL6704D LCD TV
Samsung dvdv4600 dvd/vcr: I'm having trouble with dvd. It only plays sounds but no picture in dvd mode.
Check that the scart lead is fully in on the dvd and tv,if ok then try another lead
Sep 19, 2009 | Televison & Video
Trouble connecting DVD
NEWER TV SETS REQUIRE THE RIGHT CABLES, USE S-VIDEO OR AN HDMI CABLE WILL SOLVE ANY PROBLEM
ALSO SOME T.V SETS ARE JUST LIKE THE PLUG AND PLAY YOU HAVE WITH COMPUTERS, ONCE THE RIGHT CABLE IS CONNECTED AND YOU CHANG TV INPUT FROM YOUR REMOTE IT WILL PICK UP YOUR DVD
Jun 12, 2008 | Samsung Televison & Video
Dvd connection to cable
Connect cable on combo player cable in post to time warner cable box cable out post. and connect the combo player to TV with audio and video patch cords.
Jan 16, 2008 | Samsung DVD-V3500 DVD Player/VCR
Compatibility Issue with HDMI Switch?
anytime your talking about a switch your talking about a temporary connection. The issue with using a switch is that for HDMI you want best quality and you will not get that using a temporary connection. The unit may be recognizing a weaker signal and turning the port off. However since the output on that particular unit is 1080i you should be fine using composite, just get a nicer monster set.
Dec 26, 2007 | Samsung DVD-R135
DVD recorder -- displays blue horizontal lines only
Most DVD players today are very inexpensive.
If your system is working well otherwise, I suggest purchasing a new DVD player. Try that solution. If for any reason it does not work then another problem may exist which may include an issue with your TV!
May 02, 2017 | Samsung DVD-R4000 DVD Recorder
Open Questions:
Televison & Video Logo
75 people viewed this question
Henry  Thomas
Henry Thomas
