Question about Hyundai ImageQuest ImageQuest Q770 17" CRT Monitor
Power issue Hi, Got this monitor sitting around now for nearly 16 months due to the fact it seems to have a power problem. I connect it to the PC and mains, switch it on, you get a small buzz, the LED goes amber, green, amber then off. I don't get a picture at all.
  • 298 Answers
Sounds like the Power Supply is gone or on the way out. This is caused by the Power Switch Transistor being too loosely clamped to heatsink allowing it to become too hot, and go into what we call 'thermal runaway' (2-3sec) and it draws too much current and the PS powers off to protect itself... or one of the capacitors responsible for filtering the recitified AC to pure DC (what electronics use) or frequency of oscillation of the switching supply (26-48Khz - ultrasonic) is drying up and changing value. A good tech can fix either. Most likely the big filter cap is bad, and AC (60hz) is getting thru and causing the transistor to switch erratically. This is a easy fix and the TRANSISTOR and CAP are $3.00 parts
Or the inverter in the LCD is biting the bullet. If you turn down the brightness, does it stay on or click on and off? THAT would be the inverter. Inverters take 5, 12 or 24v from the powersupply and run the itty-tiny pencil-sized florescent lamps that light up your screen. Lamps are $8.00 and inverters can be $50-80, but ebay has them for alot less
Hopes that helps
Posted on Apr 08, 2009
E248WFP (external) Monitor Won't Power Off when Laptop Screen does!
this is not a pc problem... this is because the connection loss between pc and monitor... not all pc's have sleep mode in externa vga connection.... it just cuts power off... u can configure monitor of possible to do that..
Jul 09, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
Hi, I have a Behringer EuroPower 2500 power amp that has done very little work, maybe 10 hours total at half capacity through 8 ohm speaker box. (It has never been pushed to anywhere near it's limit.) It...
Hello
Due to long time in storage, its internal plugin wire sockets may have rusted or loose contacted. You just open the set, and pull out the pluged in connection inside, one by one and reset it to the same slots, or pins. I think this may resolve your problem.
Nov 13, 2010 | Behringer EUROPOWER EP2500 Amplifier
Monitor light is green but display is black
your power supply board, probably has some bad caps in it
Jun 12, 2010 | AOC LM729 17" LCD Monitor
My summer infant video monitor's screen went blank
this just happened to mine too and i took the battery cover off and out of the handheld parent piece and put it back in, turned it on and it started working again. hopefully this is only a one time deal due to the fact that they are somewhat expensive (however the best ones supposedly) and i already replaced my first one that the screen stopped working on due to dropping it and replaced that for the little bit cheaper one and smaller one but has the talk back button. now that my daughter is getting older (16 months) i like having the option to be able to talk to her especially since i live in a 3 story house!! so anyone yea, just took battery out and put back in and seems to be working ok right now.
Mar 04, 2010 | Summer Infant Day & Handheld Video...
HP Pavilion z1420n won't even boot into CMOS
Unplug the hard drive power and cable.
Boot. See what happens.
Jun 15, 2009 | HP Pavilion a1420n PC Desktop
Blue tint...then unresponsive...only 5 months old
You're probably lucky that this happened now. You're most likely still covered under warranty. Contact Acer support and arrange a swap. If your pc works okay with another monitor there's no point in troubleshooting further. Get that monitor switched before the warranty runs out.
Apr 27, 2009 | Computers & Internet
E-Machine T6216 PSU fan runs, computer will not boot
Giving the fact that your fan is constantly running and you had an electrical spike you should take it in to be looked at. If it overheats then the motherboard will go and it will cost more to fix it than to buy a new one.
Don't forget to rate this solution before you log off.
Jan 26, 2009 | Computers & Internet
AL2423W flashes 'No Signal' and turns off and on
Hi Guys,
This is a common problem with this monitor but I have a fix. Sounds simple but try it it works. Turn your monitor off, then turn it off at the wall, turn your monitor back on to drain any stored power, now turn it back on at the wall and fire the pc up and see how you go.
Apr 13, 2008 | Acer AL2423W LCD Monitor
Compaq Monitor FS7600e - 17" monitoor
the -ve ground voltage decreased when u saw the screen goes white.if it flash too much then may be the front phosphorus coating burn due to excess whiteness suddenly. if that is ok then check the the G1 voltage , they are in excess, follow the track and replace the components after checking. also check the heater voltage and screen voltage (G2) ( do not touch the G2 voltage without insulation. they must be between 500-1000 volts. if they are disappears then check the EHT transformer. if the problem still prisist then inform me, i will guide u step by step.
Feb 08, 2008 | HP Compaq FS7600e CRT Monitor
Screen blacking in and out
Hi Esdee, Don't be too surprised if the monitor is having problems. The fact that it does the same thing on another PC is pretty good proof that is in fact the monitor. As far as what is going on the green power LED going on and off in conjunction with the blackouts indicates a power problem to me. - Does wiggling the power cords, plugs cause any change? - When the screen blacks out shine a flashlight on the screen and look to see if you can see any faint images. If you do then you have a backlight problem. If none of this works any further troubleshooting really requires some experience working around electronics and high voltage. Let us know how you want to proceed, as as always please don't forget to rate this posting.
Feb 05, 2007 | BenQ FP567s 15" LCD Monitor
Hyundai ImageQuest ImageQuest Q770 17" CRT Monitor Logo
189 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
