Question about Dell DJ Ditty MP3 Player
How do i reset it.? i charged it on the computer fully now it wont turn on please help
I fuly charged my dj ditty on the computer and now it wont turn on can i reset it?please help
Yes you can reset it but i have the same problem. To reset you need a paper clip. Insert the tip of the clip into the small hole beside the head phone jack and gently push.thats it.Good luck.
Posted on Sep 06, 2008
Dell DJ Ditty fully charged but shutting off due to "low battery"
charge your player and reset and try again if not works
then replace battery of your device that is damaged
Dec 25, 2009 | Dell DJ Ditty MP3 Player
Files on Dj Ditty won't show up on computer..
Sounds like you need to reformat the player, but here is my Dell Ditty troubleshooter:
Dell DJ Ditty
http://support.dell.com/support/edocs/systems/P97347/om/OM.pdf - manual
http://www.dellcommunity.com/supportforums/board/message?board.id=dce_djmusic&thread.id=47830 – How to Troubleshoot the Dell DJ Ditty – from Dell
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PDA_MP3_DJ_DITTY&os=WW1&osl=en&catid=&impid= - Firmware for Ditty
Did you run the installation CD first? If you don't, Windows will load its own, possibly wrong, drivers.
Make sure you didn't accidentally press the player's lock button:
The keys on the Dell DJ Ditty have been locked.
Unlock the keys by pressing in on and holding the
Volume/Scroll/Select dial until the lock icon disappears.
Reset method - Insert the end of a thin object, such as a straightened paper clip, into the reset button (near the headphone jack).
Also make sure your operating system is Windows XP - it won't work on anything before or after.
The Musicmatch service that this player was tied to was discontinued in October 2007, so you’re going to have problems even if we get it working again.
The DJ Ditty does recognize DRM-encryption for WMA files – make sure the license is up to date, or convert the file to mp3 format if you are experiencing licensing issues.
If you are experiencing frequent freezing, or a file system/corruption error, or getting the “Warning! Reformat with Firmware Updater!” message, there are two ways to format the DJ Ditty:
Format using Windows Media Player:
Run Microsoft Windows Media Player.
Connect the DJ Ditty to the computer.
Click the Sync button on the top of the menu.
Click the "Format storage media" button on the right-hand side of the screen.
Disconnect the DJ Ditty and power it back on.
Reload or upgrade the Firmware:
Download and install the latest firmware from http://support.dell.com
Run the firmware upgrade program with the "Format Data Area" checked.
-Tha Mp3 Doctor
Dec 14, 2008 | Dell DJ Ditty MP3 Player
Dell DJ Ditty froze
I waited for the Dell DJ Ditty to run out of power then a charged it again and it worked!
Nov 13, 2008 | Dell DJ Ditty MP3 Player
My dell dj ditty has frozen
Dell DJ Ditty
-Tha Mp3 Doctor
Oct 06, 2008 | Dell DJ Ditty MP3 Player
Dell DJ Ditty will not turn on, battery shows charged, and can connect to pc and all songs show.
HOLA, my name is Daniel Garcia, I have the same problem, have you the drivers for my DJ Ditty
Jul 07, 2008 | Dell DJ Ditty MP3 Player
My dell dj ditty wont turn on
Dell DJ Ditty
-Tha Mp3 Doctor
Jun 27, 2008 | Dell DJ Ditty MP3 Player
Dell DJ Ditty
We may be in luck - I actually found an owner's manual for this one. Did you run the installation CD first? If you don't, Windows will load it's own, possibly wrong, drivers.
The Musicmatch service that this player was tied to was discontinued in October 2007, so your going to have problems even if we get it working again. Use Windows Media Player 10 instead (downgrade if you have the current version 11 installed).
Let me know how everything turns out.
-Tha Mp3 Doctor
Jun 13, 2008 | Dell DJ Ditty MP3 Player
Dj ditty
Reset, make sure lock is not engaged, then
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Nov 15, 2007 | Dell DJ Ditty MP3 Player
DJ ditty wont work
Connector bent = replace the player
May 02, 2007 | Dell DJ Ditty MP3 Player
I charged my MP3 Player, but it won't turn on!
Hi Katie The problem is the battery. I have had the same problem as you and I found only one way to fix it. I don't know if you want to try this your self but I did it and it worked for me and know my DJ Ditty works great. This is what I did. I took the dj ditty apart and cut the battery out but I left the little circuit board between the battery and the ditty I then bought a battery that goes in a ipod shuffle and soldered it in. The battery is a little smaller but works great. If I can be of any help please let me know.
Dec 29, 2006 | Dell DJ Ditty MP3 Player
Dell DJ Ditty MP3 Player Logo
260 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
