Question about Panasonic PV-V4611 VHS VCR
Funky recording problem
VCR plays tapes just fine and receives a perfectly clear picture from the DVR, but when we try to record the signal, the picture slowly pulsates from normal to oversaturated - almost like copy guard.
  • 1 more comment
  • 14oct1066 Jul 04, 2008
    Thanks for responding. No, nothing has changed from when it last recorded successfully from the DVR. No new or newly-located equipment. I cleaned the heads (first thing I tried) and it did no good. But here's the really weird thing: I swapped it with our bedroom (JVC) VCR. Now that it's in the bedroom, the Panasonic records just fine, and the JVC records just fine in the living room (attached to the DVR). So, normaly I'd say problem solved, except that the JVC unit is mono and the Panasonic is stereo, so we'd prefer to have the Panasonic in the living room. I'm mystified.
    Your question about rf interference got me wondering about cable routes. One of the signal a/v cables had gotten tangled with power supply cables. (They're pretty good a/v cables, but I guess the shielding wasn't quite sufficient.) I re-routed and ... PROBLEM SOLVED. Thanks!
  • Tim Babcock
    Tim Babcock May 11, 2010
    Do you have any computers or any appliances that may be causing an rf signal near your VCR?
    Have you cleaned your tape heads lately?
  • Panasonic Master
  • 2,794 Answers
I take it youre recording using AV cables and not coax?
Posted on Jul 04, 2008
My vcr plays commercially-recorded tapes fine, but tapes recorded on it or another VCR play with the sound distorted. The picture seems fine.
Sounds like its mechanism need some alignment. Guide pole alignment. Contact any service technician. This is technically skilled work. http://electronicshelponline.blogspot.com/
Jul 18, 2015 | Panasonic Televison & Video
Playback problem EP
Do you have a tracking control on the
vcr if you do it should be centered during
record It can be adjusted during playback
to clear up the picture adjust it for the best
If you dont have a tracking control on the
vcr then it may require a mechanical adjustment
of the backtension or guidepost which requires
special tools to perform
Nov 18, 2007 | JVC HR-A592U S-VHS VCR
Bunker hill 67139 dvr hard drive wrong year 2058
The issue may be is that you have a DVD in your dvr , that still shoes that date and time. Just a possibility, not sure,. try to see if you can take DVD out of dvr, and use a new one. I happened to me but, the case was a vcr,and I had a recorded video tape which while playing , was showing a blue screen, with "no data received" which actually it was when no data vcr was receiving from cable at the time it was recording . If the problem still is not solved then there is issue with some circuits, and processors. Also you may want to check if Bunker Hill has any customer support, to check with them.
May 18, 2014 | Televison & Video
Tv picture changes and recording is unwatchable when trying to rec one of 4 local channels
It is the signal from the 4 local stations that is the problem, because you can record all others ok. Borrow another VCR and try to record them, if its the same tell the people who run the local channels that they are losing viewing figures, because their channels cannot be recorded.
Dec 27, 2013 | Computers & Internet
I have a Toshiba D-VR16. How do I copy a VHS video onto a CD?
Just put the tape and a blank cd in and just press the Copy from the case.
Aug 10, 2010 | Toshiba Televison & Video
Rolling picture and blue screen
According to my Satellite provider tech support. More and more channels are being encoded so that recording equipment cannot capture the signals to prevent piracy. I know the premium channels use this technique now. I would call and ask tech support if there is any copy restrictions in place that would affect your VCR recording before doing any further trouble shooting on the VCR. If you can play pack a prerecorded movie fine with your VCR then it should also record fine. Also try watching the channel through the VCR tuner and I bet you will see the same pattern. The VCR can only record the signal it is given.
Hope this helps you,
Ron
Feb 24, 2010 | Samsung DVD-V5500 DVD Player/VCR
Trying to dub from dvr to vhs vcr
Is L2 for composite video (yellow) or S-Video? Try watching a video on L2 with the composite video plugged into the back of your TV, if it works, then do the same with the DVR, if that works, then run the DVR composite video into a receiver, then the L2 from the VCR to the video out on your receiver. It's possible that the VCR won't record anything that isn't an applified signal. That's what the receiver does.
Oct 01, 2009 | Sony RDR-VX555
Recording
Coax out from box into cable in on VCR. Coax out from VCR to Cable in on TV. Set TV and VCR to ch 3. Put in blank tape. Start show on DVR and hit record on VCR. Hope that works for you.
Feb 07, 2008 | Arris DCT6200 DTV Receiver
Records media but playback has no audio.
Are you absolutely sure that it is receiving an audio signal?
What input are you using? Try recording using alternate inputs.
Audio part of a VCR is normally way more reliable than the video.
The exception is on high-end stereo types where they record the extra audio signals using the video head cylinder in which case it can easily be lost.
Jan 24, 2008 | GE VG4054 VCR
Recording from DVR to Cassette using this?
Well, generally, you simply need a Cable of the RCA 3way A/V cable variety, usually with Red, Yellow & White RCA plugs on the end... there should be corresponding RCA Sockets on each machine.. Plug the leads in colour to colour, then insert tape in VCR and select the Auxiliary Input (Or whatever input it is actually called) to Record from... start "Recording" Then on the DVR start "Play" and ya should be all up & running. What I do first, is set it up on my TV first, using the RCA sockets, set it up so it is all playing clear picture etc.. then I connect up to the VCR. NB: There are "Other" types of "Inputs & Outputs" among them ones called "Composite Video" "S-VHS" "SCART" ALL of these have standard interconnect leads, so if on your machine you DO NOT have the RCA Sockets.. but have one of those "Other" simply procure a Male to Male Cable of that type & then simply substitute the alternate "Cable" for the "RCA" & the rest is the same.
Sep 05, 2007 | Sony SLV-D360P DVD Player/VCR
Panasonic PV-V4611 VHS VCR Logo
66 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
