Question about Epson PictureMate (C11C618001) Deluxe Viewer Edition InkJet Printer
Problem printing pictures
Picture Mate photo printer won't read my photo card.
should be able to place card in picture mate and print pictures.
works with another photo card
  • 1 more comment
  • delilahr Jul 04, 2008
    I can view pictures on my camera, card is 4GB
  • Tim Babcock
    Tim Babcock May 11, 2010
    How big is your memory card?
  • Tim Babcock
    Does your photo card read in your camera?
  • Epson Master
  • 2,794 Answers
That card is probably too big for that card reader in the printer to read. You have to have a card reader that can read Secure Digital High Capacity cards. The most you can probably get out of the card reader on the printer is either 1 or 2 gb secure digital.
You might be able to get away with using the pictbrige connection on the printer and print that way as long as the memory card is loaded into the camera.
If that doesn't work you will have to get a card reader that can read SDHC cards.
Posted on Jul 04, 2008
I have a epson picture mate photo printer I get a question mark when I put the SD card in
I know this is late, but in case someone comes looking...
The PictureMate only read standard, or "non-progressive" JPEGs. If you save the JPEGs as progressive (perhaps without knowing it), the printer won't read them and you'll get question marks.
The only solution is to open and re-save the photos, being careful to use the "non-progressive" option.
In Photoshop it looks like this when saving:
Jan 29, 2014 | Office Equipment & Supplies
PICTURE MATE IS ONLY PRINTING THE PICTURES IN PINK
On the printer, hit the Menu button, and then the Maintenance Menu. Run the print test, and then hit "NO" when it asks you if the design is correct (even if it is.) This will send the machine to an automatic self-cleaning which ended up solving my "printing in pink" issue.
Jan 10, 2011 | Epson PictureMate 500 InkJet Photo Printer
My pictures are coming out rosey color looking instead of bright, I've cleaned the heads, and changed the cartridge and still don't get good pictures, help, sorry, I have a epson picture mate personal...
try to set the resolution of your epson, to picture quality or something like that.also you have to identify if the picture you are printing is same or big as the papar you are using, its possible that is in the picture it self.hope it help, :)
Oct 04, 2009 | Epson PictureMate Photo Printer
It won't recognize the sd card adapter for mirco
THERE is a tweak with the cards you insert on your picture mate, to be honest these things dont recognize memory cards that are above 2 gig. they also dont recognize some brands. the most compatible as per experience is sandisk
Jun 23, 2009 | Epson PictureMate 500 InkJet Photo Printer
I have the picture mate personal photo lab and the error code 0x2 comes up when I turn it on and I am not able to do anything else
I had the same error and I could find no information on what it was or how to fix it so I decided to go trial and error. What I found is that this relates to the print head not being able to completely pass from the left to right side during startup. I had a plastic carriage on the one side that was stuck in a position that stop the carriage from make the complete run from side to side. When I forced the plastic carriage down and it clicked into place the error stopped and the printer started up normally with no codes. If anything is causing the print head to not travel completely from left to right during startup, this will probable cause the code. It will be hard to see if the print head is being obstructed if you don't remove the sides. I hope this helps.
May 17, 2009 | Epson PictureMate Photo Printer
Epson picture Mate --Black photo is printed in green
You are out of black ink and the red and yellow compensation produces green.
Mar 29, 2009 | Epson PictureMate InkJet Photo Printer
Kodak picture mate 240 prints with lines across photo
Yes. you should have recieved a cleaning disc with your printer accessories
Nov 22, 2008 | Kodak Personal Picture Maker 120 InkJet...
Want to print pictures from camera card.
I received my Brother printer today (11/5). I also go mine mainly for the scanner because my Visioneer 9320 doesn't have any drivers for VISTA, and Visioneer isn't making any updates.
My camra uses a SD card. This is how I got mine to print pictures.
I place my SD card into the printer
I then press the PHOTO CAPTURE button The display on the printer reads CONNECTING TO PC
Then the display reads PRESS (up arrow or down arrow) & OK
When you press the up or down arrow, the display will read PRINT IMAGES or PRINT INDEX
I selected PRINT INDEX and then you have to press the OK BUTTON
The printer display then will ask 6 images per line or 5 images per line.
You pick what you want then you hit the OK button.
Don't forget to put the photo paper in the tray, upside down.
Hopes this helps
Nov 03, 2008 | Brother Multi-Function Center MFC-240C...
Non-Epson cartridge
Yes this is a common problem. Go to Epsons web site and download any updates and this will usaully fix it. If not reinstall your printer and then again check for updates.
Aug 26, 2008 | Epson PictureMate (C11C556001) InkJet...
Canon Powershop ds600
Ok, there are two options I'd suggest here. First option is to get a card reader, and copy the files onto a memory card this way. With many cameras it's possible to use the camera as a card reader, but many Canons don't support this function.
The alternative is to burn the pictures onto CD. Most photo labs will print images from CDs for you.
Hope this helps.
Nov 20, 2007 | Canon PowerShot SD600 Digital Camera
Epson PictureMate (C11C618001) Deluxe Viewer Edition InkJet Printer Logo
127 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
