Question about Adobe Photoshop 7.0 for PC
C V joint + grinding noise
What is a cv joint?
  • 1,314 Answers
That is your constant velocity joint, specific to front wheel drive vehicles.
Read more about it here.
Includes pictures and diagrams.
Posted on Jul 04, 2008
Grinding noise stops when I turn right.Is it rhe right axle?
Most likely one of the drives or cv joints
Oct 12, 2014 | Cars & Trucks
Mazda 6 grinding noise when turning
Grinding noise upon turning is normally one of two issues. First, and most often, it is caused by a worn out outer CV joint. If your vehicle has more than 50000 miles on it and the axle shafts have never been replaced, this is what I would suspect first. In addition, CV noise will be louder when turning under power (gas pedal pressed) than when coasting into a turn. The other possibility is a front wheel bearing assembly. These are not as common, but do wear out as well. The wheel bearings will usually make no noise when going straight, but will make noise upon even the slightest side to side turn. CVs on the other hand, usually grind only when going into corners or making left or right turns. If you suspect a CV joint, but don't have high mileage, you could have a torn CV boot that resulted in the grease that lubricates the joint being depleted and causing the noise. You can inspect the out boots visually for tears....grease leaking out usually leaves telltale spatters in the wheel wells also. Replacement of the CV joint can be done, but it is usually cheaper to replace the entire axle shaft as they are serviced as a unit.
Nov 03, 2013 | Mazda MAZDA6 Cars & Trucks
I have a 2002 Chrysler Town and Country van. While driving, the van gave a couple of sudden jerks. Shortly after, a very loud grinding noise and the loss of drive train. Now I have no reverse or forward...
Yes a CV joint could cause it. Look under the car with someone putting it in gear. If any of the shafts are turning it is a joint if not the diff in the transmission is gone. Good luck.
Feb 08, 2018 | Dodge Cars & Trucks
I have a golf gti automatic. It makes a grinding when comming to stop and when frewheeling at low speed. i've checked brake pads and there fine
cv joint going bad, grease and boot may fix, probably caused by a cracked cv boot, and now the grease is gone, first thing to check is the boot on the cv joint (that's the shaft/joint that turns the wheels)attatches by a single nut in center of your front wheel (outer joint) if not the outer, then ck the inner (attatches to the transmission) (inner joint). most likely is the outer joint though
Sep 04, 2012 | Volkswagen GTI Cars & Trucks
Full lock grinding noise micra
Jul 30, 2012 | Cars & Trucks
Grinding sound when turning
if its a grinding/knocking type sound then it could be the cv joint gone bad.the side that makes the noise when you are loading during turning(turning left you are loading the right cv joint and vise versa)that is the side the bad joint is will happen whether or not your foot is on the brake.if the noise happens as strickly a grinding noise like when brakes are metal to metal when applying the brakes then it could be brakes need replacing.also have seen were if the inner fender is loose or oversize tire is on it can rub sounding like grinding.
Apr 08, 2011 | Nissan Frontier Cars & Trucks
2002 Daewoo Lanos. Grinding noise that started
Suggest it is a Constant Velocity (CV) joint that is bad.
(Maybe more than one)
You have Front Wheel Drive. Your transmission is connected to two axles. One on each side of the transmission.
The other end of the axle is connected to a wheel. (Basic description. There are other components before it connects to a wheel)
At each end of the axle is a Constant Velocity Joint.
(There are 4 CV Joints)
I don't know if you have observed a U-joint before, but basically a constant velocity joint is made up of two U-joints. (Basically)
Front wheel bearings make a constant noise.
Should you decide to repair the problem yourself, I have to state that this is not a job for a novice. (No offense intended)
But I will give you the tip, that buying the complete axle with constant velocity joints installed, is the way to go.
It takes a special technique to change the joints out. Also you need a special tool to install the clamp, which seals the dust boot on.
The aftermarket dust boots aren't worth a darn.
The dust boot keeps the grease inside. If the dust boot leaks, and the grease is lost, the CV joint will soon fail.
It costs a little more for the axles, and CV joints installed, at first.
After you see what a headache it is to replace the CV joints, and the place/s you have to take the axle to, to have the joints installed, it is cheaper to buy the CV joints already installed on the axles.
Nov 22, 2009 | Computers & Internet
Mercury Sable makes noise when turning left and backing in? It sounds like a grinding noise.
Sounds like a CV (Constant Velocity) joint. I can't completely solve this for you, but you can re-post with the CV problem. The sound - grinding and or popping - should be coming from only one side of the car - but it could be the inner or outer CV joint on that side. Check the rubber boots around the joints - they are located on each end of the drive shaft on the transaxle. If you have a torn boot, that will probably indicate which joint is bad.
Jul 07, 2009 | 2002 Mercury Sable
Grinding noises when 4x4 is engaged
Most likely wheel bearing or cv joint issue. look for a ripped open cv boot. I believe that year used cv joints instead of regular u-joints. Hope I helped. Thanks
Apr 06, 2009 | 2001 Jeep Grand Cherokee
CV joint has gotten debris and moisture inside. The CV boot is bad and not protecting the joint. Now its metal on metal grinding. This happens when turning as there is more pressure on the joint. Please fix this ASAP as it can be dangerous to drive on a bad CV joint. While I have seen people drive with a bad CV joint for over 4k miles, it is NOT recommended!
May 14, 2008 | 1998 Nissan Altima
Adobe Photoshop 7.0 for PC Logo
Top Adobe Computers & Internet Experts
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
