Sony DCR-HC38 Mini DV Digital Camcorder Logo
Posted on Dec 21, 2010
I have sony hc38 and the error message c32:11 comes up and the door wont close...
Anonymous
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Feb 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
6159
Points
11
HERE'S WHAT WORKED FOR ME PER SONY TECHS:
Take? OUT the battery or disconnect the AC cord.
Turn the camera ON (tape, memory, edit settings) for 15 seconds.
Turn camera to off setting.
Plug battery or AC cord back in.
VOILA!
Worked for me and I had the stupid C32:11 error code for weeks! Door would not close. Followed the SIMPLE and SAFE instructions and IT WORKED! Just like magic. I couldn't believe it! Save your money TRY THIS!
Anonymous
Level 1:
Genius:
  • Contributor 1,812 Answers
  • Posted on Dec 21, 2010
Anonymous
Contributor
Level 1:
Genius:
Answers
1812
Questions
0
Helped
251646
Points
49
This is usually caused by a defective component in the tape detection circuitry or a faulty rotory mode switch and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sony handycam dcr-hc38 tape door wont close. fault code c:32:11
Try this if you are tech savy, if not you may want to take it to a person to have it fixed or send it off to sony.
1. unplug camcorder AC cord
2. remove fat battery from back of camcorder
3. remove slim battery from under the LCD (it's the size of a nickle coin)
4. wait 2 minutes
5. plug AC into the camcorder
6. flip the camcorder into VTR mode
7. tape should automatically eject
Found at : http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/DCR-TRV350_tape_wont_eject_C.32.11.html
I can not get the cassette compartment door to close.
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My tape wont close,the tape won't go down for the door to close
This is usually caused by a defective component in the tape detection circuitry and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Sony dcr-hc38. inserted tape. hear beeps. screen states to "reinsert the cassette". it continues and wont play or record --Solution #1- change the mechnical assembley of casete ...Can you explain how to do...
try it without inserting cassette if it closes correctly and doesnt load with cassette then 99% problem is with drum motor.look out for drum motor connector remove it clean it with pencil eraser and try again if it works, fine or just replace drum motor
3helpful
ERROR C:32:11
GO TO REPAIRING INTERNAL PROBLEM
2answers
DCR-HC38
Fail safe the drum may not be spinning free.
I have a dcr-hc38 that shows C:32:11 error and will not close?
eject mechanisum connect by a stip that one break u cant ching that strip u must u chaing mechanisum
Drivers
THERE YOU GO... http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/Sony_DCR-HC38_Driver
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
