My Surrond sound seems to be hooked up correct but the rear speakers as well and the front center will not play audio no matter what i do.... I tested all the speakers and they work fine when hooked into the front..
  • 682 Answers
Please reinstall setup for all speaker and confirm that all speaker are in on status according to the setting.
Posted on Jul 04, 2008
  • mohamed eltoni
    mohamed eltoni Jul 04, 2008
    you must check cables it self for good condition and change bad one with new good quality cables
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Can't hook up to a flat screen tv
I can only guess as to the nature of your problem, but I'll try. If you're trying to hook up your amplfier and its a 5.1, or 6.1 amp you need to hook up the audio by using the orange output on the flat screen, it may be labeled "coax" or "hd audio out" or surround out, this is the one wire you need to reproduce the surrond sound with left, right, center and rear speakers, and also the sub woofer. The other outputs on your tv will be red and white or red and black, these are the analog audio out and you plug them into your amplifer too, but they won't be 5.1 sound, although your sub woofer will still work. I hope I have helped some.
Mar 12, 2011 | Audio Players & Recorders
All speakers work on sound level test but i have no music coming from rear, center and sub when playing 5.1 dvd. also i am unable to use any of the surrond sound modes. richard
What cable did you hook up your dvd? The 5.1 sound works only with optical cable or HDMI. Check in the input settings wich one is selected. With the analog cable ( Stereo RCA) is not working. Good luck!
Jan 29, 2011 | NAD T762 Receiver
Lg lht854....wont play sound out of rear and center speakers
Try setting it first on surround mode because it is normal for the rear speakers not to come on when it is the surround mode is off. For the center speakers make sure it is hooked up properly. Follow the instruction if you have one. Lastly I never heard of center speakers have two speakers in it but if it does and you only have one set of wire to it then one of the speakers is no good.
Jun 26, 2010 | LG LHT854 Theater System
I have a Dell 5.1 surround system that I bought for my computer. It has three cables, yellow, black, green, that connect to make it a single jack for the computer. I would like to hook up this system to...
well you can connect white and red to green connector(Front Speakers) the yellow connector is subwoofer speaker and the Black connector is for Rear Speakers) is not connected. The Tv dont have any Surrond decoder so to have full surrond needs surrond decoder
Jan 08, 2010 | Audio Players & Recorders
No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Feb 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Surrond sound
For Stereo Mode (Front L & R Speaker), you must plug RCA cables (match up red and white) from Output on DVD player to DVD Input on the back of the receiver. Then with speaker wire, run from receiver speaker output (Front Speakers) to designated speaker (make sure + and - match up to both input and output). As for hooking up surround sound, I'm currently trying to figure that one out with just using the L, R and Center. I don' t want wire running all over the place just for rears. Hope this helps
Sep 04, 2007 | KLH R5100 Receiver
ASUS P4S800D sound card problem
Check to see if your audio header is hooked up correctly on your motherboard if your using the front panel audio, if your not using the front panel audio then make sure the audio header has the two jumpers on them!! Check your mother board manual for proper procedure to hook up! If that still doesn't help then it could be a faulty sound device! You can fix this buy purchasing a new sound card! hope this helps! regards, babb
May 05, 2007 | ASUS P4S800D-X Motherboard
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
121 people viewed this question
