Question about Acer Aspire 5500 5570-2609 Laptop
I beam jumps to location where the pointer is
When using programs like word or just typing (write now), the blinking beam jumps to the position where the pointer was. Sometimes it acts as I click on something when I didn't.
    Champion:
  • 258 Answers
Virus check need it friend
Posted on Jul 29, 2008
Logitech m 705 mouse pointer flickering
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens.
Type "Cursor blink" in the "Search programs and file" text box.
A list opens.
Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens.
Click the "Speed" tab. A list of options appears.
The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast."
Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale.
Click "Apply."
Click "OK." The cursor stops flickering on the screen.
hope this helps
Sep 12, 2012 | Logitech M705 Wireless Marathon Mouse,...
Jumping cursor on windows7
change ur driver, update os, and install antivirus, download reginout intel partner may fix it
Sep 03, 2010 | Sony VAIO Notebook
I don?t understand the use of pointers in C++
Pointers are variables which store memory address of other variables.
It is denoted by an astrix *
Pointers and normal variables must have same data types.
Need of Pointers:
As said pointers variables store memory addresses of other variables, this can be used when we want to perform some calculations on a variable, we pass the address of this variable to the function from using pointers, thus any changes made to the variable will directly affect the variable as it is pointed to the same memory location.
It can also be for pointing various memory locations e.g. video memory. In the days of Dos we could actually read and write directly on to the video memory using address 0xB8000000 hexa decimal address.
Declaring a pointer:
int a = 10;
int *p = &a;
Here are passing address of a to p. Make sure that the data types should be same.
When we use pointers as arrays, it is much faster then the usual array iterators.
int num[] = {43,52,54,53};
int i=0, *j;
j=&num[0];
while(i<=3) { cout<<"num ["<<i<<"] = "<<*j<<endl; j++; } // This peice of code is faster than following method
for (int i=0;i<=3;++) { cout<<"num ["<<i<<"] = "<<num[i]<<endl; }
As we are directly working on memory.
Pointers are most commonly used to allocate memory dynamically, using new operator.
int *p = new [10];
This code allocates for 10 integer type array dynamically.
Dont forget to release the reserved memory using new operator by delete operator.
delete []p; // Frees the reserved memory.
This is an overview of pointers, as it requires study and practice.
Please rate. Thanks :)
May 09, 2010 | Computers & Internet
I HAVE REPLACED THE BATTERY IN MY KEY FOB BUT IT IS NOT WORKING. IS THERE ANYWHERE I CAN BUY A NEW CIRCUIT BOARD FOR IT?
NOTE: If a double audible warning sounds during the programming procedure a system malfunction has occurred. Repeat programming procedure.
Obtain all keys fitted with remote control. Open driver's door. Operate headlamp high/low beam switch to flash high beam position and hold. Insert key into ignition switch, turn to ACC position. Ensure system LED flashes once and an audible warning sounds. Operate headlamp high/low beam switch to flash high beam position 5 times. Ensure system LED flashes once and an audible warning sounds. Programming mode activated: Press and release lock or unlock button on first key. Ensure system LED flashes once and an audible warning sounds to indicate correct programming. Repeat programming procedure for remaining keys. Switch ignition OFF and remove key. Close driver's door. Check operation of keys. Keys can also be programmed using diagnostic equipment.
Mar 21, 2010 | 2002 Jaguar S-Type
Key fobs not working i have changed the battries on both
Jan 31, 2010 | 2002 Jaguar X-Type
My cursor jumps around while typing in word 2007. Help this is really getting bad. Please send me a fix asap.
Not sure on this but check your mouse if its logitech make sure you have the logitech software on your laptop.
Jan 08, 2010 | Acer Aspire 5500 5570-4421 Laptop
Pointer on laptop jumps to a different line while typing.
This may be caused by weak batteries, or interference by some nearby appliance (the worst case is another wireless mouse, of course: happened all the time in an office with six identical workstations, even to the two that were beyond a wall. But also wireless - not cellular - phones may interfere). Also the positions of receiver and mouse may play a part. Once sure the batteries work, try placing the receiver and mouse in different positions and see if it helps.
Otherwise, the receiver antenna could be defective.
Nov 07, 2009 | Microsoft Wireless Notebook Optical Mouse...
Dell Inspiron B130
Hello, this normally happens on laptops. I think that it is from the sensitivity of the touch pad. You would have to check the position of your hands when typing since when your finger happens to touch the pad unexpectedly, the cursor quickly jumps to where ever the mouse pointer is: As a result, whatever you type next will rather go there instead of your current position.
Hope that helps
Thanks
Nov 08, 2008 | Dell Inspiron B130 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
