Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Hunter Fan Company 5 + 2 thermostat #44110 Set and Save/Energy Star
The above mentioned model makes a distinguish click sound every time the fan comes on or goes off. Is this normal, and if not, is it dangerous?
  • Anonymous Mar 29, 2014
    Ac will not come on
    Problem Solver:
  • 5 Answers
I would say normal, between my family have 3 different hunter models, and they all do it.
Posted on Jul 11, 2008
Hunter Programmable Thermostat
My Hunter Programmable Thermostate #44110. I set it for regular clock time. But in the middle of the day and night it goes to military time. When I hadn't added military time. Is it time to buy a new one. I've had it for 8 years.
Apr 15, 2015 | Hunter Fan Company 7-day programmable...
Hunter thermostat 44110
This sounds like a split system, the condensing unit outside and the evaporator coil and fan inside. You must be referring to the indoor fan, since the compressor and outdoor fan are controlled by the same contacter. The indoor fan relay contacts sounds to be welded shut, and needs to be replaced.
Aug 24, 2013 | Heating & Cooling
Not working
"G" terminal is for the fan, typically using a green wire. "C" terminal is the common, basically a ground, typically using a blue wire. Also, leave in the jumper between "RH" and "RC".
May 19, 2010 | Hunter Fan Company 5/1/1 Programmable...
Auto recovery mode raises the temperature above
Hummm... how far is your Thermostat from your heater? I am reading your extensive manual but there is no mention of that distance? There was a early mention of batteries? Are yours fresh?
Is this a 'new' problem? Has it worked properly before?
Then there is this from the manual:
The installer can set SYSTEM functions once the thermostat is installed. The
default settings are shown in bold in the following list. Options are listed inside the
parentheses. Example: the default SYSTEM TYPE is CONVENTIONAL with (HEAT PUMP) as a second option. See pages 28-29 to change these settings.
Have you tried resetting your Thermostat?? Sometimes these basic 'onboard' computers get confused... especially true with lots of 'options'...
It's a little hassle to get a DIGITAL copy of your manual (I am not a Robot ~ etc) ~ but here it is:
Download manual
TROUBLESHOOTING begins at Page 68
Anthony
Dec 22, 2017 | Hunter Fan Company 5/1/1 Programmable...
I believe the digital hunter thermostat say energy moitor 1
Find the 5-digit model number (example 40170) on your thermostat. Go to http://www.hunterfan.com and paste the number into the search field at the top of the page. If Hunter still supports this product, you should be taken to the support page for it which has a link to the product manual PDF.
Oct 15, 2009 | Hunter Fan Company 5/1/1 Programmable...
I need a new manual for my 44360 Hunter programmable thermostat.
Try this URL. Should be able to download it for free.
http://homeappliance.manualsonline.com/manuals/mfg/hunter/44360.html
Click on the above link. If that doesn't work for you, copy and paste it into your browser's URL line.
Oct 13, 2009 | Hunter Fan Company 5/1/1 Programmable...
Need help with wiring on Hunter 44110
There is no real color code for wiring but the standard is red wire to r, yellow wire to y,white wire to w, green wire to g, blue wire to c. since there's no c on your t- stat its probably battery operated, but in your case im betting white wire to w, and blue wire to g.
Mar 08, 2009 | Hunter Fan Company 5/1/1 Programmable...
THERMOSTAT INSTALLATION
I am trying change from a Honeywell ct701A1001 to Hunter 44110 the old one has 7 wire and new one 5wires
Nov 01, 2008 | Hunter Fan Company 5/1/1 Programmable...
Location of reset button on model 44110
There is a little reset button right under DAY/TIME. You will need a pencil/pen tip to press this little switch in to reset your unit.
Hope this helps.
Good luck.
Mac =)
Feb 09, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
296 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
