Question about Marantz PMD660 Digital Voice Recorder
Unformat i see that unformat means something like my cf card is formatted is formatted other than FAT16 or FAT32. however i have already recorded an irreplaceable interview on it. earlier the computer was recognizing it in the flash card reader and asking if i wanted to format. now it's not reading at all. and as for putting it in the marantz, it won't even respond when i press shift and menu to format. can my files be saved?
I have a PMD660 as well and from time to time a memory card will become "corrupted". During a recording last evening the battery ran out "prematurely" and when replaced, the 660 had the unformat error. Fortunately the card was readable in my Hummingbird card reader.
Normally when I have had UNFORMAT problems in the past I would just FORMAT the card with the computer and the 660 would then be happy with it. Not this time! The 660 still stubbornly displayed UNFORMAT! This time I ended up having to use Partition Commander to wipe out the partition on the card and then DISK MANAGEMENT in the XP's Computer Management program to re-create the partition and format FAT32. Normally when you FORMAT all data is lost so this would end all hope of recovering data from the card.
In the case of hoping to recover lost recordings I would have tried QUICK FORMAT and then tried to "recover" the data with a program like Partition Magic or Partition Commander or some other program that could re-link the blocks and create directory entries.
Posted on May 30, 2009
We have a lot of these machines here at the university and on the two occassions we have had this error message it has meant that a student has put the card in the machine incorrectly and bent some of the pins inside the machine
Posted on Sep 29, 2008
I believe in the end that my card was actually physically damaged -- got a little dent in the card reader. i think that's my problem and i never did fix it. better luck to you.
Posted on Sep 05, 2008
  • RackRoom Oct 28, 2010
    I just encountered this with a new CF card. I tried formatting in a computer, I updated the PMD660 firmware, still had the unformat error. The Volume label on working cards were blank. The Volume label on the troublesome card said LEXAR. I formatted the card in the computer again except this time I made the Volume label blank. The card now works in the PMD660
  • jkalwa Feb 02, 2011
    I have the same issue with my PMD660 and I tried what you recommended. My Mac Disk Utility does not allow me to make the Volume label blank. Is it maybe a PC solution only?
This seems to be a firmware issue and Marantz have resolved it on this page ( http://www.d-mpro.com/users/folder.asp?FolderID=3629&Tab=FAQ ).
Simply download the firmware file and drag it onto your cf card and click update. ALL THE INSTRUCTIONS ARE ON THE WEBPAGE ABOVE.
Posted on Aug 31, 2011
I have the same problem, do you have any suggestions?
Card error???
Depending on the size of the xD card, your camera may need a firmware update to be able to read xD cards larger than 256mb. If the card used to work but now doesn't, try formatting it as FAT16 or FAT32 while it's inserted into the camera. If you still get an error and you have a card reader on your PC, try formatting it from there as FAT16 or FAT32 file formats.
Feb 24, 2012 | Olympus EVOLT E-410 Digital Camera
My memory card can not be formatted
Hello
It is more likely a card error. SD cards for all except the newest cameras must be formatted FAT16. Windows version 9x through XP format FAT32 by default. Some cameras cannot reformat FAT32 to FAT16, so when using a reader, do not format the card on the reader unless FAT or FAT16 is specifically selected. Cards can become "corrupted" if a file is opened for editing directly from the card, i.e, the file was not copied to the computer before editing. Temp or working files can be left on the card if the card is dismounted from the reader before the edited file or the program itself is closed and the working files deleted. Some cameras cannot format in the presence of temp files. Always copy all files to the computer before doing any editing.
A "corrupted" card that cannot be formatted in camera might be resurrected by formatting FAT16 in a reader.
To format using Windows XP, Vista and 7
1. Open 'My Computer' 2. Right click the Drive assigned to the CF Reader 3. Select Format 4. Select the appropriate File System from the drop down list (Either FAT or FAT32; FAT is FAT16, the default for most cards of 2GB or less) 5. Select Default Allocation Size from the Allocation Unit Size drop box 6. Ensure that Quick format and Compression are Disabled 7. Click Start
Good Luck, Hope this helps If so do rate the solution
Jan 10, 2011 | Cell Phones
Canon A10 - "CF card error" with new 4GB card
You need to format new cards in the camera before using.
Apr 05, 2010 | Canon PowerShot A10 Digital Camera
Nikon 4300 CF Card Erro
The Nikon Coolpix 4300 only supports the FAT16 filesystem, so it can only support a 2GB partition. To support 4GB you need a FAT32 filesystem.
Put the card in a CF writer and attached to a PC or Mac. Partition 2x2GB partitions, then format them as FAT16. Now put it into the Coolpix 4300 and it should work.
Jul 29, 2009 | Nikon Coolpix 4300 Digital Camera
My c902 has suddenly stopped recognising the m2 card
This may have something to do with how the m2 card is formated. PC systems such as FAT32 and NTFS do not work with cameras or telephones as the data cards in these devices are formatted to FAT16 or lower. In order to read the card when you placed it in your PC FAT32 would have been used.
If you are prepared to loose the data on the card I suggest you use a PC to re-format it to FAT16, your phone should then recognise it again!
Jul 06, 2009 | SanDisk 1GB Memory Stick M2 Memory Card
Motorola k1 cannot format unformatted memory card
sometimes there are sd card errors make you format failed. you may get messages like
"Unsupported media card inserted, format now?" error in your smart phone,
"Media is not formatted would you like to format now?" error,
you need to fix sd memory card errors first and them format you sd card.
Jun 04, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Nikon coolpix 2100- out of memory- After installing 4gb CF card
4GB requires FAT32. Camera firmware only supports FAT16. 4GB won't work because FAT16 has a 2GB maximum size limitation. 1GB CF card is Nikon's "approved" maximum for this camera.
Catch: 22 1GB -and lesser capacity- CF cards are no longer manufacturered or generally available in 2010. When the current CF card dies, the still working camera also becomes throwaway unless you can source a CF card 1GB or under. 2GB may work, but with 'issues' per caution below.
CAUTION: Anecdotal evidence suggests the final release -& current- firmware for cameras of this generation is also encumbered by with a maximum picture number limitation of 999, realistic at the time of original manufacture when 256MB was a the largest capacity CF card but completely nonsensical now.
Summary: This is my first NIkon Digital camera and also my last.
Apart from the noteriety of the ubiquitous broken Nikon plastic battery latch, a major design flaw Nikon refuse to acknowledge or accept liability to rectify -since self-repaired better than OEM, Nikon policy on firmware support is complete abandonment of product within an unacceptably short service window. ie: a deliberate poilicy of enforced obsolescence.
Suggested Problem Remedy: Do buy a new camera supporting SD Cards of current capacities. Don't buy anything branded Nikon.
May 24, 2009 | Nikon Coolpix 2100 Digital Camera
Formating 64gb pen drive
some memory cards / items do not work with FAT32, you should try to re-format using your PC to FAT16 format.
Dec 31, 2008 | Electronics - Others
How big of memory cards will work with the FUJI S7000
The easy answer is..... 2 Gb.
The longer answer entails fat16 vs fat32 abilities, and the posibility of reformatting your card on the computer in an attempt to possibly get the s7000 to recognise it with mixed success. Since the s7000 is fat16, it can recognise only 2Gb of data.
The xD cards max out at 2Gb. CF goes much higher, but only 2Gb will be recognized.
On a related note, if you do continuous shooting or movies and use an xD card, make sure you get the H-type (not M or M+) as this is higher speed and will avoid timing issues. All of the newer CF cards are plenty fast already.
HopHead
Nov 03, 2008 | Fuji FinePix S7000 Digital Camera
Hp photosmart 8150 printer.
Could be a few things. First thing to ask is if this happens with multiple cards or with just one card?
Also, what format are the pictures on the card, jpg? gif? tif? bmp? Are there other files on the card that might conflict with the printer?
Is the card formatted as FAT16 or FAT32? How big is the card? Is it an SD card, CF card, etc...?
May 13, 2008 | Office Equipment & Supplies
Marantz PMD660 Digital Voice Recorder Logo
3,631 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
