I have a Maytag Neptune Front Loader. I am trying to replace the door seal because it leaks but can not get the machine apart.
  • 246 Answers
For replacing the nuptune boots, I belive these are all of the steps. First, take the 2 phillips screws out of the door hinges. You should be able to lift slightly on the door and pull it towards you to remove it. Also remove the 2 phillips screws straight across from them. This will let your front panel come of (grasp up top and twist slightly to get it off the clips. Lower the front down and you can remove it from the washer and set it aside. Remove the 4 phillips screws from your soap/ fab softner dispenser. Next, remove the 2 5/16 screws that hold the top on to the front of the washer.
To remove the boot, first, pull the front part of the boot towards you. It will actually pull off without much effort. On the bottom (depending on model) there will be a tube at the bottom of the boot that is either stoppered up or connected to a black hose. Squeeze the green clamp to remove the hose if it does have one. To take of the back half of the boot, we're back up top. Lift the top of the machine (you may want someone to hold it or just slide the machine far enough forward the top can stand up by itself). You will see a large spring connected to what looks like a piece of cable coated in clear plastic. Pull the cable towards the front by the spring. It will quickly contract.
Reinstalation time. Take your new boot and install the back half. As you work the boot on, you will see some triangles all the way around to help you line it up correctly. Once it is on, it's time to re-clamp. This is the tough part. Typically what I do, is I make sure the cable is wrapped around the boot from the bottom with the clips at the top. (there is a nice notch for it to fit into) Next I take one side of the spring and attach it to the clip on the cable making sure that the hook side of the spring points up. Now, grab the clip on the cable (without the spring attached) with a pair pf pliers. I use a pair of needle nose pliers to grasp the spring. Now I stretch the two of them together. This will not be easy and the spring will be under some tension. Once the spring is on the clip, lower the lid. (there will be a black wire harness on the right hand side that needs to be tucked back into place for the lid to close properly. Screw the lid down. Re-connect the hose at the bottom of the boot if your machine was equiped with one. Push the front part of your boot back on. Put your door back on the clips where it sits. Lift slightly on the door and swing it closed. Run a test cycle (fill, tumble and drain) while you are standing there to check for leaks. Once you have verified there are no leaks, replace the front panel and your screws. If you run into troubles, message me back.
Posted on Jul 04, 2008
How to fix a seal on matag neptune
if the front door is leaking you will need to replace the door seal.
Jan 02, 2012 | Maytag Neptune MAH5500B Front Load Washer
We are having a leak on the bottom of the front loader door on the wash cycle
Check the door seal. There is a boot drain on the seal that may be clogged. This drain allows the water to drain out of the seal when water gets in there. You may need to replace the seal. HEre is a link to the part you will need.
Happy Holidays The FixYa Team
Dec 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune leaks water from the bottom (immediately) as it fills with water
usually this is from the front door seal going bad remove the front panel and door to replace it
Apr 30, 2009 | Maytag MAH6700AWW Neptune Front-Load...
We have a Maytag Neptune washer Model # MAH4000 AWW it is leaking from the front at the bottom of door. Water pours out like a water fall when it wants to rinse. Any ideas?
TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT: CJA931@FRONTIERNET.NET , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
My Maytag Neptune fnt loader Model# MAH9700AWW
I have a Maytag neptune mah8700aww
With mine the large grey rubber seal that seals at door slipped off! When this happens if you do not put back on correctly it will leak or even poor out the front center bottom of the door! My husband fixed it. But it still leaked really bad! I just took a couple of min. to refit the seal and it does not leak at all now! maybe your seal is not placed around the edge correctly! as it is easy to place it wrong! good luck!! keep my email address if I was helpfull!! We can always share problems and solutions for our neptunes in the future ! good luck
Anne Marie
Feb 27, 2009 | Maytag MAH6500 Neptune Front Loading...
Rubber on machine disintergrating
If you google partsselect.com and enter in your washer number then type in front door seal it will give the seal and break down the front door in a schematic that you can see for your self what is involved with putting it in. It will also give you the price.
Jan 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag front loader washing machine. Mould
How old is the washer? Did you try straight bleach on a towel and placed over the "mold" spot for about 5 minutes, be sure to wear gloves. Then scrub with a small brush being careful not to splatter bleach on yourself and rinse well. May need to replace the seal. I always leave the door cracked open after every use to "dry" out the inside and the boot. I also leave the drawer pulled out when not in use for that area to dry out as well. I have never had mold on the door seal of my Neptune washers, only the water holes above the dispenser drawer.
Sep 08, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
