Question about Creative Labs Zen Micro MP3 Player
Hard Disk Problem Message.
What do I do? When I upgrade firmware I get this message. When I reformat I get this message.
I tried to load new firmware. and the download stops 1 bar from the end. Am I screwed?
    Problem Solver:
  • 9 Answers
You need a new HD, search ST1 5GB on ebay.
Posted on Jul 04, 2008
Unable to format Seagate ST9500423AS
Have you tried reformatting your hard disk? this happened to me when i tried to us PartionMagic tool. my hard disk stopped working tho' it's still showing up when i plug it in another PC. this is how i get it working again:
i plugged my hard drive to another PC and i used DiskPart to clean it and i formatted it in Windows Disk Management.
it worked for me and i doubt, there was an error partitioning my hard disk so i needed to make it fresh again.
Apr 18, 2013 | Seagate 500GB ST9500423AS 7200rpm SATA2...
Will reformatting my hard drive save it the disk from going out?
There isn't any way of fixing a failing hard disk (it is nearly worn out).
You need a new hard disk, but in the mean time backup your data regularly before the hard disk fails completely.
Dec 29, 2012 | Computers & Internet
I tried to restore my sister laptop..but i got a message saying restore failed..so when i tried to restart the computer...i just got a black screen with the message NTLDR IS MISSING...Press ctrl+alt+Del...
Hi there, I did a bit of research on this for you and this is what I found:
First off, there are numerous causes which could be giving you this message. Odds are it's because reformatting wasn't completed properly, which means something on your computer hasn't been set up properly.
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and/or NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32. New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS.
Jan 06, 2011 | Acer Pink 101 Aspire One AOD2602571...
I keep getting the message 2010
After a BIOS upgrade or installation of a new hard drive, the following error message may appear at POST: ERROR
2010: Warning: Your internal hard disk drive (HDD) may not function correctly on this system. Ensure that your HDD is supported on this system and that the latest HDD firmware is installed. Press <Esc> to continue
Press <F1> to Setup
The system appears to boot normally after escape is pressed and the operating system will load.
Solution There are three possible workarounds to eliminate the error:
  1. Update the hard drive firmware to the latest level. Download the hard drive firmware update, and then apply to your hard drive.
    Note: This update requires a floppy disk drive.
  2. Replace the hard drive with one supported by the system being used.
  3. Use the hard drive, producing the 2010, error in the Ultrabay of the system or a docking station with the second hard drive adapter instead. The interface to the Ultrabay is parallel ATA. For more information visit, ThinkPad Second Hard Drive Adapter for Ultrabay Slim - Overview
Additional information This error is purposely generated to alert the user to potential problems with diagnostic or copy tools. There are known issues with several of these listed below.
  1. Disk Fitness Test (DFT) version 3.xx provided by Hitachi GST which uses vendor specific commands on the hard drive. These may not be correctly interpreted since they must pass through the serial to parallel ATA bridge. However, version 4.00 or later of the Disk Fitness Test (DFT) will work.
  2. HDDTEST version 0.28 by Hitachi GST does not function properly for similar reasons. Instead, use HDDTEST version 0.29 or later.
  3. DOS-based copy tools may function slowly or produce incorrect output, specifically previous versions of Norton/Symantec Ghost. These versions are not compatible with the Serial-ATA interface of the Intel ICH6M chip set. Documentation on this problem may be found at www.symantec.com. It is recommended to use either a newer version of Ghost, Norton Ghost 2003 (version 2003.789 or later) or Symantec Ghost 8.0 or later, or to use the -FNI switch when invoking Ghost from the command prompt (For example, Ghost.exe -FNI with the current version of Ghost).
Other disk copy tools and related applications, such as some backup programs, may also have similar behavior. The hard drives shipped in the affected systems will not display the message because they already have firmware that recognizes this new Serial ATA bridge chip. However, a similar drive from an earlier ThinkPad system or an OEM drive might cause the error message to be displayed. Customers may also notice the POST error message after applying a ThinkPad BIOS update if a drive without the firmware update is installed in the system. Some early systems were shipped with a system BIOS version that did not provide this POST error message. Updated BIOS has been released to provide this informative POST error message to users.
Apr 30, 2009 | Computers & Internet
Corrupted mp3
This is the message that the player gives when the hard drive fails. You can try upgrading the firmware.
Go RCA at the following link and download the 'hard drive upgrade utility'
http://support.rcaaudiovideo.com/downloads.aspx?product=202
When ready turn player off then press and hold the center toggle while connecting the USB cable.
Run the install program.
If the player still fails and you want to save it contact Sansaworld.com, They can replace the hard drive with flash memory. The player will load faster with 4x the battery life.
Apr 08, 2009 | Audio Players & Recorders
Display 2010 error message
POST warning message 2010 after BIOS upgrade or hard drive installation - ThinkPad General
dblue_rule.gif c.gif d_bold.gif Applicable countries and regions c.gif dotted_rule_443.gif c.gif Symptom After a BIOS upgrade or installation of a new hard drive, the following error message may appear at POST: ERROR
2010:Warning: Your internal hard disk drive (HDD) may not function correctlyon this system. Ensure that your HDD is supported on this system andthat the latest HDD firmware is installed. Press <Esc> to continue
Press <F1> to Setup
Affected configurations This message may occur on any system that uses the Intel 915 Expresschip set. This new chipset uses a different hard drive interfacetechnology (Serial ATA) to address the hard drive. Models specifically included are of the following systems:
  • ThinkPad R52 systems
    Machine types:
    • 1846, 1847, 1848, 1849, 1850, 1858, 1859, 1860, 1861, 1862, 1863, 1870
  • ThinkPad T43 systems
    Machine types:
    • 1871, 1872, 1873, 1874, 1875, 1876, 2668, 2669, 2678, 2679, 2686, 2687
  • ThinkPad X41 systems
    Machine types:
    • 1864, 1865, 2525, 2526, 2527, 2528
  • ThinkPad X41 Tablet systems
    Machine types:
    • 1866, 1867, 1869
  3. Usethe hard drive, producing the 2010, error in the Ultrabay of the systemor a docking station with the second hard drive adapter instead. Theinterface to the Ultrabay is parallel ATA. For more information visit, ThinkPad Second Hard Drive Adapter for Ultrabay Slim - Overview
Additional information This error is purposely generated to alert the user to potentialproblems with diagnostic or copy tools. There are known issues withseveral of these listed below.
  1. Disk Fitness Test (DFT) version 3.xx provided byHitachi GST which uses vendor specific commands on the hard drive.These may not be correctly interpreted since they must pass through theserial to parallel ATA bridge. However, version 4.00 or later of theDisk Fitness Test (DFT) will work.
  3. DOS-basedcopy tools may function slowly or produce incorrect output,specifically previous versions of Norton/Symantec Ghost. These versionsare not compatible with the Serial-ATA interface of the Intel ICH6Mchip set. Documentation on this problem may be found atwww.symantec.com. It is recommended to use either a newer version ofGhost, Norton Ghost 2003 (version 2003.789 or later) or Symantec Ghost8.0 or later, or to use the -FNI switch when invoking Ghost from thecommand prompt (For example, Ghost.exe -FNI with the current version of Ghost).
Other disk copy tools and related applications, such as some backup programs, may also have similar behavior. Thehard drives shipped in the affected systems will not display themessage because they already have firmware that recognizes this newSerial ATA bridge chip. However, a similar drive from an earlierThinkPad system or an OEM drive might cause the error message to bedisplayed. Customers may also notice the POST error message afterapplying a ThinkPad BIOS update if a drive without the firmware updateis installed in the system. Some early systems were shipped with asystem BIOS version that did not provide this POST error message.Updated BIOS has been released to provide this informative POST errormessage to users.
Jan 07, 2009 | IBM ThinkPad T43 Notebook
"RESTARTING"
I encountered the same issue with my Nitrus. After following instructions to upgrade firmware, I had the "restarting" message on screen. I then took the unit apart once again. I could hear the drive making a noise. I tapped on the back of the drive with a screwdriver and the player started working properly.
Mar 27, 2008 | Rio Nitrus MP3 Player
DV2130 Firmware upgrade.
Where did you get this firmware?
Dec 06, 2007 | GoVideo DV2130 DVD Player/VCR
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
Creative Labs Zen Micro MP3 Player Logo
44 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
