Question about Estate TGDS840JQ Gas Dryer
Estate gas dryer
Drum turns, but no heat
  • 2 more comments
  • Anonymous Sep 02, 2008
    Dryer goes on and drum turns - no heat - cool air
  • rickchlst Sep 02, 2008
    Estae dryer turns and blows but no heat
  • Anonymous Oct 25, 2008
    Dryer starts ok drum turns - no heat
  • Anonymous Nov 14, 2008
    First it was taking 1-2 hours to get a load of clothes dry. Now it gives out NO heat at all.
    Novelist:
  • 163 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
My dryer has heat but does not dry
is the drum turning? if not you must replace the strap that turns the drum. if it is heating and the drum is not turning , that could cause a fire.
Sep 30, 2014 | Estate by Whirlpool EED4100XQ Estate...
Drums turns but no heat
check, to see if the gas line is open to the dryer, if there's a shut off valve, make sure it's in the "open" condition. Check your electronic igniter----that's sounds like the most likely problem.
Sep 24, 2012 | Estate TGDS840JQ Gas Dryer
Dryer drum rotates but there is no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 18, 2011 | Estate TEDX640JQ Electric Dryer
Whirlpool Estate gas clothes dryer runs but the heat only lasts for about 10 minutes. the drum will be turning the heat will be on but only for about 10 minutes.After 10 minutes the drum will still be...
The gas coils have failed. These are the two round devices on the gas valve. You would need to open the dryer to access and replace the gas valves. Every make and model is different.
With the model number I would be able to better assist you.
Mar 31, 2011 | Whirlpool Dryers
Dryer turns on, drum rotates, clicks like it did to let gas start but does not ignite. Gas line is functioning. Does not get hot. LPG conversion kit used
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 21, 2010 | Estate TGDS840JQ Gas Dryer
Air blows drum turns but no heat in dryer
Hi,<br /> If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.<br /> <br /> Check out this tip that will give more details&hellip;<br /> <br /> Gas dryer not working gas dryer not heating<br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><a href="http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not" target="_blank">http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not</a></span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat. <br /> Check out this tip to see the things that can fail to cause your electric dryer not to work.<br /> <br /> Dryer Troubleshooting Electric dryer wont heat<br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><a href="http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won" target="_blank">http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won</a></span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">heatman101</span>
Aug 26, 2010 | Estate TEDX640JQ Electric Dryer
I have and electric estate dryer. The drum is turning but the clothes are't getting dried in the automatic cycle or timed cycle
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 14, 2010 | Estate TGDS840JQ Gas Dryer
No heat, timer not moving
Yes you need to replace the duct fuse and clear all air obstructions. I have repair photos HERE
Feb 17, 2010 | Kenmore 63942 Dryer
Drum will not turn
YOUR BELT ON YOUR DRYER IS BROKEN. THAT IS WHY YOUR DRUM WON'T SPIN. YOU CAN BUY A NEW BELT FOR YOUR DRYER AT ANY PLACE THAT SELLS APPLIANCES.
RODNEY
May 15, 2009 | Estate TEDS740JQ Electric Dryer
Drum does not move
dryer...there is no way to lubricate anything...all bearings are sealed. Get in there and look around. Turn off the gas and remove the line of you can't get access... and disconnect the power. Remove the back. Chances are you'll find that the motor, drum or belt is somehow jammed. Make sure any fan is turning freely with the belt off. It is possible that the timer is bad. This would keep the motor from receiving power. To test...remove the motor belt and turn the unit on.
Dec 16, 2007 | Estate TGDS740JQ Gas Dryer
Estate TGDS840JQ Gas Dryer Logo
125 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
