Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Ft light still flashing after emptied tank
What do i do know that i have emptied the tank? the ft is still flashing and the unit will not turn on again. their is no more water coming out of the tank from the back
  • Anonymous Aug 13, 2008
    I have the same problem, the ft flashes yet the tank is empty. How do you fix it? They want me to find the receipt and send it to some far away place.
  • 182 Answers
Float switch stuck?
Posted on Jul 04, 2008
2 Suggested Answers
SOURCE: Full Tank
I had the same error and the tank was not even full. I took the cover off of the unit which consisted of removing 10 screws. The water tank is on the bottom left side. I then removed the float which was a small sensor with a styrofoam float. I removed the float (2 more screws) and moved it up and down. It did not appear to move very smooth but after moving it back and forth a few time it seemed better. I put the float back in ensuring it was at the low point, screwed it back in and then tested the unit. It came on and appears to work fine now. I unplugged again putt the cover back on it has now ran 30 minutes no problems.
Posted on Sep 07, 2008
Fan and tank lights won't run
I would look at the floating switch actuator. It's common for the float to bind up in the holder which keeps it in place. If the actuator is floating free, then look at the switch itself. Could be corroded or otherwise malfunctioning.
Nov 26, 2013 | Bemis 447 301 Humidifier
With code Ft at delonghi pac c100
Ft = normally means empty the internal tank, this is normally done at end of season cleaning storage. On some units there is a small ''bung'' low on the rear which will empty the tank - the unit should then reset when powered up. Hope this helps
Jan 24, 2011 | DeLonghi PAC C100 Air Conditioner
I have ft error on delonghi air conditioner and I've emptied the tank and the filter is clean. nothing to empty as the the unit is brand new .ft won't go away. how do i fix this
Theres a little floatation type device in the removable tank that triggers a switch just above the tank on the unit itself. Just check that that isn't stuck in the "Full Tank" position. I had the same problem and jiggled the switch to make sure it could move and my A/C was back. Hallelujah!!! Hope it works for you...
Jul 10, 2010 | DeLonghi CF210 Portable Air Conditioner
New unit installed when turned on "FT" light displays
Remove the tank if it is removable and see if you can determine how it is sensing the tank level. Maybe it's a float switch that is stuck or maybe it works by the weight of the tank. Either way your problem will be with whatever senses the tank level.
May 02, 2010 | DeLonghi PAC C120 Portable Air Conditioner
How do reset this unit when the filter light flashes ?
You still need to empty the water out of the unit. There are two hoses at the bottom on the back of the unit. Empty both of them and hopefully, the unit will reset and start back up. It worked for me.
Apr 18, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Solis Palazzo Descaling (?) Problem? Please Help!
Hi
He has the first part correct, but when you rinse the machine with fresh water the machine needs to quit on its own and you will know this when the descale light is off, but you will have a flashing green light and a steady red light over the water drop. Refill the water tank, the close the steam knob and then open it again. This will clear the red light and then the machine will start heating. IMPORTANT on any automatic machine is when the water tank is off the machine don't do anything with the beans. A chip of bean in the water receptacle can be a big problem for the machine.
Jan 28, 2009 | Solis Palazzo Espresso Machine
Newair ADS-300 Dehumidifier
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Nov 12, 2008 | NewAir ADS-300 Dehumidifier
Full Tank
Jul 13, 2008 | DeLonghi Pinguino PACL90 Portable Air...
The "tank full" light flashing
You can find a user manual at http://www.toyotomiusa.com/products/manuals/TID-2400%20(Type%20A,%20B)%20-%2020456095%20-%20Multi%20Lingual.pdf
Jun 08, 2008 | Toyotomi TID-2400 Air Conditioner
Red light wont shut off
check to make sure your fill bucket is correctly placed back into the unit. there is a safely switch that will not let the unit work without the bucket in place..hope this helps let me know?
Aug 24, 2007 | Danby DPAC10031 Air Conditioner
Heating & Cooling Logo
793 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
