Question about Brother MFC 420CN All-In-One InkJet Printer
How to Override Ink Level Gauge When Using Refilled Cartridges
I've got a couple of refilled ink cartridges for my PIXMA MP160 Canon all-in-one printer. Unfortunately after installing them it says that the ink is still low or the cartridges need replacing (or both!) and I have been told I need to override the Ink Level Gauge to fix this. Any ideas? yellow ink cartridge after refilling it it keep showing ink cartridge low and someit show 1/4 full.  how can i overide the  ink gauge for brother mfc420cn printer
  • flomarbye Aug 16, 2008
    keep getting black low ink level when ink level is not low! replace with new cartridge & the same thing happens. have to push color button to get it to print black.
    Problem Solver:
  • 7 Answers
Above link great.
If you have a newer print cartridge cart, look for the little window. I put a sticker over the little window on the Brother (innobella) LC38 cartridge cart and it worked great :)
Despite finding a fix for this problem, I think this is a rip off setting on the brother printers and I will never buy another Brother printer for this reason.
Posted on Jun 01, 2010
Amazing solution:
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Brother ink empty cyan yellow magenta..
Posted on Aug 13, 2008
Refilled ink cartridges on pixma mp490 ...will not print
I know this is frustrating. I am all for recycling and using refilled ink and laser toner cartridges. However, the manufacturers make most of their money from ink and toner sales. So, from time to time, they will encode or datecode cartridge chips. The only times I've been ale to get around this is by using at least one genuine OEM cartridge to trick the printer. If that does not work, try another et of refills, or you will have to use only OEMs.
May 02, 2010 | Canon PIXMA MP160 All-In-One InkJet...
How to Override Ink Level Gauge When Using Refilled Cartridges on PIXMA MP830
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 08, 2010 | Canon PIXMA MP830 All-In-One InkJet...
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
The function detecting the remaining ink level is disable
Hi, are you using Original Canon supplies or are the cartridges you are using are refilled/ or non-canon supplies? If they are not original Canon supplies I'm afraid the use of the "ink gauge" is one of the features lost when refilling your cartridges or using non-original supplies. If you get a new set of supplies (Canon branded) the gauge should work again .
Oct 04, 2009 | Canon PIXMA iP6220D InkJet Photo Printer
I have a canon 480, how do I override to get the refilled ink cartridges to work??
there are no manual settings,, for refilled ink cad to work,, other than,, trying to give print commands,, and check if it works,,,even if it shows error or check ink levels,, it mostly prints jobs
Sep 28, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How to override printer for reset to use refilled ink cartridges.
you must be change printer cartridge
first time you try to clean cartridge OEM software some times you get successful
MP160 ink level won't reset
The only _bypass_ is to ignore the warnings/lamps, and keep using your printer until it runs out of ink.
The only _solution_ is to purchase "original" cartridges, i.e., do not use "refilled" cartridges.
Sep 10, 2009 | Canon PIXMA MP150 All-In-One InkJet...
This maybe in the manual under ink tank replacement, most cannons have this, but keep in mind that sometimes the ink feed tubes to the print head get clogged and then the printer will report no ink at all, these cansometimes be cleaned by soaking them in acholol
May 28, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
604
Oct 08, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Jul 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
2,585 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
