Question about InVion 5 GPS Navigation
Can't find satellites
My GPS was working just fine, then last week when I turned it on, I kept receiving the message "Signal too low". I thought since it has been rainy and clouding that was the reason for the message. Well, we finally had a nice sunny day yesterday and still no satellites.
Now what?
  • 2 more comments
  • jamescdodge Jan 06, 2009
    cant find satellites
  • Anonymous Jan 08, 2009
    SAME PROBLEM HERE...
  • dziadzi Feb 26, 2009
    invion can't acquire sattalites
  • Anonymous Apr 06, 2009
    I have same problem. Waiting for satetillites signal.
    Problem Solver:
  • 7 Answers
There are two solutions to your problem. #1, It's possible your power cord is too close to the GPS Antenna on the back of your unit. Moving the cord away from the top of the unit should solve this problem... this is in cases where you get a "few" Satellites, but not enough to generate a "Valid" GPS Signal.
#2, The SD card and/or the Software is corrupted. In which case, you'll need to reinstall the software from backups. It's not uncommon for this to happen, as the unit typically sits in a blazing hot car interior. There is usually one file that causes a lot of troubles... and it typically gets corrupted when the unit is still "Navigating" to a route when the machine is turned off. That file is located in the Favorites Folder under User Data (DestinatorApps/Destinator/UserData/Favorites) The file within the Favorites Folder you need to get rid of is "FAVORITES.INI". The file isn't all that useful... the GPS unit will function without in and generate a new one after rebooting the unit. If you're worried about deleting it, you can always copy it onto your computer (I don't recommend putting it back in the GPS though).
The best way to prevent this problem in the future is to make sure to "Cancel" Navigation before turning your unit off. Good luck.
Posted on May 08, 2009
Receiver is dead
Posted on Jul 21, 2008
My tomtom one gps can't get signal
When was the last time you updated the QuickFix of your TomTom? It helps your GPS to find the satellites.
Please, do the following:
1) Install "TomTom Home" software in your computer from www.tomtom.com
2) Start TomTom Home in your computer
3) Plug in the GPS dock to your computer's USB port and place the GPS on the dock. The green light on the bottom right of the GPS should turn ON to indicate that the GPS is getting power from the dock and charging
4) Start your GPS while being in the dock. If the GPS asks "do you want to connect to computer" answer "YES"
5) The TomTom Home software will detect the GPS and check if there are any updates for it. Then you'll be offered updates to install. Some are free, some are not. Be sure you choose to update "QuickFix".
Please, report back if you need further assistance
My ID: alexocuello_
Mar 19, 2010 | Tomtom ONE GPS Receiver
My tom tom says no gps signal for the last two weeks. How do I fix this.
Did anything change in your environment (new car?) two weeks ago?
What happened immediately before you lost signal?
Is everything else working okay on the unit?
Have you updated everything with Tom Tom Home?
Have you tried resetting the unit (paperclip in the small hole on the bottom of the navigator)?
Have you tried resetting factory defaults? (Menu item under Change Preferences; you need to Show All Menu Items to see this one.)
BTW, nobody's satellite got hit by anything.
Nov 21, 2009 | Tomtom ONE GPS Receiver
Can't get a GPS signal for last 24 hrs
I had a similar problem and did solve it with the soft reset (pressing reset button). I have a One XL and there is a small reset button that you push with a paper clip. On the XL 330 you press and hold the on/off button for 15 seconds and the unit should reset.
My symptoms: Would not find a GPS signal. When I looked at the GPS Satellite status (press on the GPS signal strength bars, again on the GPS/battery status) you can see it locking on up to 8 satellites but would still not show a gps signal lock. Normally it only takes 4 satellites to get a gps lock. My other sympton was that when I attached the GPS unit to the computer and operated it with TomTom Home, it worked fine and locked on to the gps signal quickly (even inside my home). But it would never (at least for 30 minute trips) lock on to a gps signal. After doing a reset it began working normally and locked on to a gps signal after finding 4 or more satellite signals.
Aug 06, 2009 | Tomtom XL 330 Car GPS Receiver
Recently when returning from a trip my C550 giving keptme the message "satellite unable to locate" (not the exact words) This went on for a week or more but suddenly started locating me from the satellite....
Low battery power is generally r4esponsible for loss of signal or low signal. Charge itr fully before use and plug into car power source ONLY AFTER staring the engine so as to avoid spike deamage. The car charger cannot fully charge the battery it is justn sufficient to maintain a level of charge . If the battery gets too low it cannot maintain a constant signal.
Jul 24, 2009 | Garmin StreetPilot c550 GPS Receiver
When I turn on my TomTom, it says GPS signal lost for about 3-4 minutes before it picks a signal up. This happens everytime no matter where I am. Then it works fine.
Does your GPS have a good view of the sky?
i.e. not mounted low on the dash of your car.
it really only needs to find 3 satellites to work but it might take a while to lock on if reception is low.
When you say every time you turn it on. I assume that you don't go days without turning it on. A GPS stores information about satellites and their orbits across the sky and keeps it for about 6 days. The download process of this information is fairly slow. If you run it most days the information gets updated while the gps is running so you tend not to notice.
Just some ideas to think about.
Jul 08, 2009 | Tomtom ONE GPS Receiver
No valid gps signal
battery may be too low recharge it
Jun 28, 2009 | Tomtom ONE GPS Receiver
My unit just flashes on the last position that was stored and wa
It may simply be trying to load the almanac and ephemeris from the satellites. This can take up to 1/2 hour with a strong GPS signal outdoors.
Jun 03, 2009 | Lowrance LCX-25c GPS Receiver
Lost satellite reception
I have the same problem, and so far the only solution is patience. If you are in a cutting, or between tall buildings, and the satellites are low down on the horizon, then it seems reasonable that reception will be between poor and zero. But in wide open spaces mine too sometimes loses the signal. Hang in there, and contact is restored.
LocoTorque
Aug 11, 2008 | Garmin nuvi 200W GPS Receiver
Gps signal
Solution to the original problem above.
You need to connect TomTom to a computer and run their 'TomTom Home' program. Let it check for updates. It will download a file called "QuickGPSfix data". This file updates your TomTom with the latest satellite positions and ensures your TomTom will find its coordinates very quickly after switching on. A new file can be downloaded at least once a week. Generally, the longer you left it since downloading this file, the longer it will take to find its coordinates (ie. find a signal).
Hope this help.
Chris.
Jun 02, 2007 | Tomtom ONE GPS Receiver
Problem with Magellan GPS 315
I own Two Magellan 315. They both have failed in exactly the same way as yours, will not lock on too a satillite. I have concluded that this is their design life and that is the end. I did post one to the Magillan repair centre in France but that disappeared. I have replaced the two of them from EBay and will see how I get on with those
Oct 19, 2006 | Magellan GPS 315 GPS Receiver
InVion 5 GPS Navigation Logo
231 people viewed this question
Top InVion GPS Experts
Will Halftowaite
Are you an InVion GPS Expert? Answer questions, earn points and help others
