Question about Whirlpool Washing Machines
Water temperature on an whirlpool accusensor washing maching is warm even when set to cold/cold. Hoses are connected correctly.
    Genius:
  • 1,028 Answers
Probably normal ck owners manual ..newer machines tend to have temp controls that confuse us all .. temp controlled by thermistor and control bd are supposed to conserve energy and aid in detergent disolving some have a "faucet cold" setting these are uncontrolled temps
Posted on Jul 05, 2008
Why does my hot water on my washing machine not work?
Make sure you have the hoses connected correctly. There will be marks on the back of the washer indicating which one is hot.
Feb 21, 2016 | Whirlpool Washing Machines
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Washer Model No. LXR-1564039, Serial No. CM-1564039, Type 107, Year 2006. Went using the extra large setting the washer leaks water from the bottom, however went filling for the rinse...
Although its difficult to say the problem may not be caused by the amount of water but the water temperature.
Most often rinse tempertaure is cold only, however the wash might be warm /hot. A great place to start would be when the machine is filling in wash watch the connectons from the taps to the machine for any leaks in the hoses or connections.
Hope it helps.
Nov 23, 2010 | Whirlpool Washing Machines
Water mixing improperly set on cold and warm or hot water is being dispenced
Did you check to make sure the hoses are connected to the correct temperature spigot? They may have been swapped when the washer was hooked up. Really easy to fix, just unscrew the hoses that go from the faucets and switch!
Aug 19, 2010 | Kenmore 24032\24036 Top Load Washer
Hot water connected but does not fill into the drum? The machine will provide us with a cold wash but on the warm and hot settings the hot water dies not pull through the connection
Turn off the water valves which supply the water to washer hoses. Switch the hot and cold water supply hoses and tighten. Turn the water valves back on and try to run a wash cycle using cold. If hot water only is entering the wash tub the water supply is ok. If this is the case you can unplug the washer and turn off the water valves. Remove the washer back cover and follow the water connection for the hot water. The water solenoid valve will have two electrical wires connected to it. Interchange the hot water solenoid wires with the cold water solenoid connection. Connect the water supply hoses hot to hot and cold to cold then plug the unit then test the washer on the cold wash. If the problem persists it could be a water hose restriction or the timer circuit could be defective. If you have hot water at the normal pressure purchase a new hot water solenoid valve. With the electrical cord unplugged be sure to restore the correct wire connections on the hot and cold water solenoid. To replace the hot water solenoid remove the hose clamp and hose to replace the old valve. Connect the unit to the water and electrical outlet. Turn on the water and test the unit for leaks being careful not to touch any electrical and moving parts. If all checks ok and the correct temperature work, unplug the unit and reassemble.
Jun 21, 2010 | Admiral AW22 Top Load Washer
Whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Sep 12, 2009 | Washing Machines
What is the F20 error code?
F-20 error code in Whirlpool Duet Sport washing machine is indication of inadequate water supply. Check both hot and cold water supply lines to make sure machine gets enough water intake. If you do not have a hot water supply to the machine you can only run it with the cold temperature setting. This machine does not have an internal water heater and relies on the hot water supply from the house water heater.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Only hot water in washer on all settings
Are the hoses connected to the correct inlet valve on the machine?
If so, then the inlet valve itself may be faulty.
Jun 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
MACH DOESANT FILL ON HOT WATER SETTING JUST WARM AND COLD
willing to bet even on warm its cold. on the back of machine where the water hoses attatch to that is a valve assembly/solenoid needs to be replaced after you take back cover off its just a couple of screws and connction for water easy to do. on GE's they are pretty generic and most appliance parts dealers have them in stock not real expensive either when disconnecting hoses dont do like i do and forget to turn water off and have bucket ready there will be some water left in hoses hope this helps you
Aug 23, 2008 | GE Washing Machines
Washing Machines Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
