Question about Samsung HCL4715W 47" Rear Projection Television
Samsung HC-P4752W No power
The LED comes on and blinks three times. No power, but I can hear the high voltage flyback at startup. I suspect one of the low-voltage supplies. This set has a half dozen low-voltage regulators. I guess I'll have to purchase the service manual. Anyone have a solution?
Thanks,
-Dan
  • 1 more comment
  • Dan Smith
    Dan Smith Jul 04, 2008
    Thanks for the advice:
    Yes, I have disconnected the covergence yokes. When I do, one of the tube filaments lights up for a few seconds, then goes out and still no power.
    Thanks again!
  • wd401979 Jul 18, 2008
    no power timer led light comes on blinks three times and shuts off you can hear something in back come on
  • Dan Smith
    Dan Smith Oct 11, 2008
    Turns out one covergence IC was blown. Two pairs of 3.9 fusible resistors were open. Replaced both IC's and resistors. Unfortunately, the set suffered a bit of phosphor burn, two 3" lines at the top of the screen. I unplugged all connectors going to the yokes which may have caused the burn. Thanks very much for the help!
    -dan
  • Samsung Master
  • 8,617 Answers
Have you tried unplugging the convergence yokes and then try powering up the set? Its not uncommon for that chassis to shut the set down when the ICs are bad.
Posted on Jul 04, 2008
Toshiba 32'' tv no power no sound red led in front on and blinks also hearing hissing from flyback model#cx32f60
for sure your tv has power as indicated by your flyback hissing it also indicates leaking high voltage that might destroyed your vertical or any other parts near your flyback ,the flyback itself should be replaced for its high voltage arcing can ruin so many components
Oct 13, 2009 | Toshiba Televison & Video
Sony KV-32FS12 32" TV
This condition be directed us toward pin modulator transistor Q504 which may shorted. Parts necessary to fix this unit may be D501, D504 and Q504.
Check this site if you need the schematic diagram: //http://www.eserviceinfo.com/downloadsm/19977/SONY_KV32FS16.html
Good Luck.
Jan 28, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
When turning TV on it would click a few time, then you would hear a hissing sound, but no picture. Would have to unplug TV, as it would not power down. Unplugging and plugging in would eventually get...
The hissing sound could be high voltage leaking from a tripler. Observe in a dark room for blue arcing. Look at tripler and connections to the projection tubes. If the tripler is leaking replace the tripler.
Oct 13, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung hc-p4752w
look for trouble in the low voltage and or high voltage power supply circuits. the popping sound could be an exploded safety capacitor in the horizontal output to the flyback transformer. the horizontal output transistor maybe damaged. chances are the low voltage regulator is also damaged.
Aug 11, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-R4755W 47 in hdtv will not come on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
May 27, 2017 | Samsung HC-R4755W 47" HDTV
SAMSUNG HC-P4752W 47
There are three main reasons that convergence can still be inoperable after replacing the convergence amps. One, when the amps failed they blew the fuses protecting the power supply from shorts. Two, when the amps failed the yoke return biasing resistors burned open. And Three the Digital Convergence Unit has failed. Once things have gotten to this point it is usually time to have a professional have a look at the set.
Jun 02, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC
Replace the Power deflection board that should solve your problem. You can get a replacement board for your model at the following link.
http://servicemanuals.vstore.ca/product_info.php/pName/p59a-pwr-def-board/cName/samsung-parts
Apr 27, 2009 | Samsung HC-P4752W 47" Rear Projection...
I have a samsung hc-p4752w rear projection
Not simple at all it require a Technician yes it very common problem in the high voltage output you can replace the whole printer circuit board but it require to adjust a few thing after replace the new PCB such high voltage for 3 picture tube and convergence
Part No. is BP94-01249G or L
Nov 18, 2008 | Samsung HC-P4752W 47" Rear Projection...
Hc-p4752w will not turn on.
you will need to trouble shoot the power supplies most likely a low voltage regulator isnt functioning.
May 29, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung hc-p4752w
Not sure of the part number most use STK392-110 or 120s . You will need to look at the ics in your set they will have the IC numbers stamped on them they will have STKxxx-xxx whatever that number is thats the sanyo part number for those ICs
Mar 14, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
