Question about Apple iPod MP3 Player
Apple ipod nano
Im trying to get the volume to go up all the way but it wont let me until i unlock it with a password. I have no clue what the password is. Ive tried holding down the menu button and middle piece at the same time for ten seconds and that doesnt work. The only other way that I've read online is to reset the ipod and I do not want to reset it because I will lose all of my songs. Do you know of any other way to unlock it?
  • CRIMENAL443 May 11, 2010
    HOW CAN I MAKE MY IPOD WORK WHEN IT DONT WANT TO TURN ON AT ALL
  • 864 Answers
Unfortunately the password is whatever you set it as but you can do this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs.
Click "Get Info"
Click "Yes"
Click the "Options" tab
Check "Volume Adjustment"
Put the Curser all the way to "+100%". Select Ok!
Hidden Folder for Mac's
Enable hidden folders.
If you go into Terminal and run these two commands all the hidden files appear when you open Finder.
defaults write com.apple.finder AppleShowAllFiles TRUE
killall Finder
To get back to hiding hidden files use these commands
defaults write com.apple.finder AppleShowAllFiles FALSE
killall Finder
Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Hidden folders for windows PC
In Windows explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders".
Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, copy the file named "_volumelocked" to a folder on your hard drive then delete it from the iPod.
Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. If using an iPod Nano, hold down the center button and menu button simultaneously for about 10 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Warning: Note that some methods may not work on all iPods. Not all ipods have the file called "_volumelocked" it is impossible to get better sound on some of the ipod gens, for example the 5g 60-80 gigabyte ipods. Don't Listen to musictoo loudly. It will destroy your hearing. Don't delete any more files than necessary as it may prevent your iPod from working
Posted on Aug 26, 2010
Volume limit password reset on ipod nano
Hi
How to Unlock iPod Volume Limit
Your iPod volume can be limited, and in many instances, a PIN number will be necessary to remove the limit. If you've forgotten or misplaced your PIN, you can still unlock your iPod volume limit using your computer.
1 Connect your iPod to your PC. Make sure your hidden folders are visible.
2 Navigate to the "iPod_control" folder. This will be a hidden folder. Once you've found the "iPod_Control" folder, navigate to the "Device" folder.
3 Locate the file named "_volumelocked" in the "Device" folder. Delete this file.
4 Eject and restart your iPod.
5 Navigate to "Settings" on your iPod. Select "Volume Limit." You'll be able to reset your volume limit with a PIN or password.
Tips & Warnings
Do not listen to your iPod at high levels for long periods of time; doing so can damage your hearing.
Nov 23, 2011 | Apple iPod nano
How can i unlock my ipod nano when i forgot my password
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
Please rate me
Sep 10, 2010 | Apple iPod nano
How do i unlock an ipod nano 4gb because forgot password
the only way is to restore ipod
http://support.apple.com/kb/HT1339
Apr 12, 2010 | Apple iPod nano
My dumb ipod volume code:(
use itunes to roll back/reset ipod you will have to replace all info back on ipod after it resets but should take care of it my sister gave me an ipod without giving me code
Aug 18, 2009 | Apple iPod nano
Ipod volume control
use itunes and restore your ipod to factory default. Thats the only way to fix your password issue. I hope this helps.
May 17, 2009 | Apple iPod nano
Ipod nano volume locked forgot password
Basically you cant unlock the voulume if you dont know the password. You would probably have to reset your iPod in order to adjust your volume and when you put a new password in be sure to remember it.
Feb 25, 2009 | Apple iPod nano 3rd Generation
Ipod nano volume control
Try
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Jan 26, 2009 | Apple iPod nano 4th Generation
I forgot password of my ipod model no: A1137,2 GB
HELLO!!!!
I've been using iPod nano for 1 year.I forgot password for volume limit lock. so i can't change the volume.Plz tell me how 2 unlock the volume limit. Reply @ early as possible.
Jan 10, 2009 | Apple iPod nano
Ipod nano lock forgot password
First, try to restore using iTunes. If this doesn't work, place your iPod in disk mode (hold the menu and center buttons down togther) and as soon as you see the Apple symbol come up hold the center and play (bottom) buttons down together until you see a check mark (disk mode). It may take a few trys.
Now connect your iPod to your computer. Go to my computer and right click the drive associate with your iPod (for example F: ) and scroll down to FORMAT. THIS IS VERY IMPORTANT - CHOOSE FAT32 and then check the "Quick Format" box. After you do this then use iTunes to Restore your iPods another time.
Jan 31, 2008 | Apple iPod nano
Apple iPod MP3 Player Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
