Trailer brake control
Have 03 yukon awd and i need to install a trailer brake control for a trailer with electric brakes ,is there one that is better or one not recomended ?
    Genius:
  • 1,027 Answers
I use a AccuPower Pod brake controller, by Tekonsha. It is small, and easily adjusted. Most RV retailers can install them.
Posted on Jul 04, 2008
When i pull my trailer ahead the trailer brakes lock up
The brakes system is surge? Not electric?
Probable cause is corrosion from sitting.. Rock the trailer back and forth while hitched( Not crazy like please- be gentle. ) Hit the brakes each way which takes a knack. It should break free. Problem is long term storage( over winter). They may also be stuck in reverse.. The controller. may need a hammer whack( universal adjuster)
May 05, 2016 | 9030 Voyager Electric Trailer Brake...
Trailer wiring
OK ON SOME OF THE TRAILER BRAKE PLUGS ( THE PLUG FROM BRAKE BOX TO TRUCK ) THE POWWER WIRE IS IN THE WRONG PLACE ,THE PIN AT TRUCK SIDE MAY NEED TO BE MOVED IN THE PLUG,
Feb 05, 2014 | 2001 GMC Yukon XL
I have a 05 Denali XL 6.0 and i can't find the trailer brake harness under the dash. Please help!!
Hi, the provision for the electric brake controller is located in the electrical center , just to the right of the parking brake. There is a plastic nut, that holds the cover on, and beneath this cover are ports where a connector may be plugged in. A factory harness must be obtained from a Chevy, or GMC dealer for the install. This harness will be labled with wire locations, as it will be attached to your brake controller, then plugged into the slot in the upper l/h corner of the electrical center. The plug will only fit in the appropriate slot. You will then need to put the provided J- fuse into the underhood fuse block. Tis should be the only missing fuse. You should be well on your way, after these few easy steps. Good luck...Coop
Oct 15, 2010 | 2005 GMC Yukon Xl Denali
Installed electric trailer brake controler in 03 ford 150 not getting any power to trailer plug
Did you wire it with the instructions that came with the brake actuator? Check to see that yoir wiring is correct and if it is....check your fuse box for a blown fuse
Mar 20, 2010 | 2003 Ford F150 Regular Cab
Hi I am installing a trailer electric brake
I belive it would be the wire that actually sends the control signal to the controller?...correct? well the if so you would need to tap into the wire casing with a test light to see which wire is lighting the test light when the brake pedal is depressed good luck
Sep 11, 2009 | 2006 Toyota Land Cruiser
Electric trailer brakes are kicking out due to anti-lock brakes
The ABS will shut off the trailer brakes if it detects a problem. It sounds as if the problem is in the ABS control unit, or the trailer brakes may not be grabbing hard enough causing the trailer to push the truck when you are attempting to stop. This sometimes can be corrected by adjusting the gain up on the trailer brakes.
Jun 17, 2009 | 2008 Ford F 250 Super Duty 4WD
Brake controller not communicating w/ 7 pin connector
what type controller did you install? Is this a camper or trailer? Is the controller hydraulic plumbed into master cylyder? Important to know how to adjust rheostat for sensitivity. If set at minimum the system is basically on the edge of not sending any signal to towed unit. The intructions should explain how to make this adjustment. If set too sensitive trailer brakes will lock up before the tow vehcle starts to brake. Controller should be set so trailer starts braking just befor the tow vehcle. If not the trailer will tax the tow vehicle brakes by pushing. Its set right when you feel the combination stretching out. trailer first then tow vehcle. Good luck and remember, if truck brakes first and too hard you risk a jacknife. All light voltages should be system voltage. Brake voltage is variable depending on setting on controller. Understand your breakaway brakes and how they work. breakaway breaks require an auxillary battery. Again, good luck and you know where to find me if I can be of anymore help.
Apr 13, 2009 | 2003 Chevrolet Silverado 2500HD
Location of electric brake plugin under dash of 03 excursion
it is pretty easy to find,take off the fuse box cover and it's to the right of the steering colum,it's just a plug hope this helps
Mar 06, 2009 | 2003 Ford Excursion
Computers & Internet Logo
257 people viewed this question
David Payne
David Payne
