Question about Nikon Super Coolscan 8000 ED Film Scanner
Nikon 8000 film scanner problem
Nikon 8000 film scanner accepts film holder but doesn't go all the way in.
vuescan says no film inserted
  • 2 more comments
  • dbendo Jul 04, 2008
    nikon 8000 film scanner
  • davidmiller4 Oct 22, 2008
    None of the film trays will slide into the scanner.  I can push and pull, but they just won't be accepted any more.
  • Anonymous Jan 21, 2009
    I've the same problem. It seems that the scanner make some sort of calibration without the film holders, but it should make the calibration with the film holders inside. A sort of reverse behaviour.
  • Anonymous Mar 23, 2014
    When I power on the scanner I can hear the it mechanically moving internally but the holder is not taken into the scanner and the software says "insert film into scanner".
I If you use nikon scan you get a different error warning Update nikon scan and also gdiplus.ddll update from thre nikon web site. It worked for me.
Posted on Jul 27, 2008
Scanner doesn't recognise their is a slide loaded in the slide holder
The first thing I'd try is to run the scanner with the Nikon software. When you power on the scanner it goes through a variety of checks, and finally you should have a silent scanner with a solid green light at the front. Start the Nikon software and wait until it finds the scanner, if it doesn't you have a hardware problem with the scanner.
If it goes well to this point insert a card or plastic mounted slide and hit Preview. The scanner should then create and image you see on screen. Next step would be to make a scan. If the slide you're trying to scan isn't card or plastic mounted you'll need the Nikon made carrier.
Hope this helps.
Mar 22, 2014 | Nikon CoolScan V ED Film Scanner
Hi! My computer (Macbook pro) doesn't seem to recognize my Nikon Coolscan IV software and I get the following message
You've not said what the message is but I suspect that the software is too old to be used on the macbook if it is running OS X 10.7 (Lion) or if you are running snow leopard, it may be a non-intel version of the software. It may be asking you to instal rosetta which would be on your snow leopard instal disk.
If the Nikon website does not have updated software you could try vuescan which according to this page http://www.hamrick.com/vuescan/nikon_coolscan_iv_ed.html does work with the film scanner and you can download a demo version which you can trial before you buy. Hope this helps.
Jul 02, 2012 | Nikon Coolscan IV ED Film Scanner
I have an intel macintosh I have nikon coolscan 8000 scanner I have leopard, latest update I have nikon 4.0.2 update for scanner I can not get it to work. I double click on Nikon icon on my dock,...
Nikon 4.0.2 isn't supported on 10.5
I suggest you look at VueScan which does work under 10.5 and 10.6 with your scanner, and they have a free download to test first
Oct 22, 2009 | Nikon Super Coolscan 8000 ED Film Scanner
Nikon scan was unsable to find any active device
I may have a solution for the unrecognized film holder/clunking problem.  The fix is not for the faint of heart, but you can do it yourself and save a bunch of money.  The problem lies in the two rails inside the scanner that the film carrier rides on.  After unplugging you scanner, remove the 8 screws from the rear of the unit and slide the cover rearward about 3/4" and then lift it straight off.  Inside you will see two shiny machined rods running from front to back.  The problem is those two rods have dried up lubricant on them and the film carrier drags a bit during film carrier insertion and/or scans.  The easiest way I found to clean the rods is to remove the front cover (look for screws inside on each side), and then carefully slide those rods out (but NOT all the way) and wipe off what is exposed and then apply a little silicone lubricant to the rods (be very careful to not get any down into the lens area).  Then slide the rods back in and repeat for the portion that is exposed in the rear.  Carefully re-assemble everything and you should be all set.  This fix worked for me on an 8000ED that I purchased used on eBay.  Hope this helps someone.  Brian
Nov 24, 2008 | Nikon Super Coolscan 8000 ED Film Scanner
Film holder not regersting
I had the same problem. Go to nikon install the latest nikon scan and the security update for gdiplus.dll. It worked for me.
Feb 09, 2008 | Nikon Super Coolscan 8000 ED Film Scanner
Nikon Coolscan 8000 ED Film Scanner
Jim try looking into the vuescan software.  It comes highly recommended and is priced very reasonably.
Hope this helps, Rose
Oct 29, 2007 | Nikon Super Coolscan 8000 ED Film Scanner
Nikon coolscan 9000
Close the scan program --turn off and unplug the scanner---plug the LS9000 back in and turn it on----reopen the scan program--this is my method on my LS-8000--It does this quite often !
Aug 30, 2007 | Nikon LS-9000 Film Scanner
Coolscan 8000 Program Buttons not functioning
Have you changed computers -to say VISTA? Tell us more about your computer
Aug 08, 2007 | Nikon Super Coolscan 8000 ED Film Scanner
Nikon Super Coolscan 8000 ED Film Scanner Logo
798 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
