Air conditioner compressor cuts in and out. - Heating & Cooling
  • 182 Answers
Many causes for this.low voltage,capacitor....low charge.have a pro check it.
Posted on Jul 04, 2008
Compressor cuts in and out
going out on safety. drawing to many amps or overheating.
May 17, 2013 | Dometic Rooftop RV Air Conditioner
I have a small frigadare a/c.a one room a/c.it comes on then right back off.what can i do about this.
Hello, here is what the problem may be. Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner.
May 25, 2011 | Frigidaire Heating & Cooling
The airconitioner will not work in the cooling or the heating mode ,it starts up ok and the compressor cuts in the fan is working ok.
Hope the compressor getting high amphs due to capacitor weak or loose wiring.Check and replace the capacitor. If still your compressor cuts off, the problem is with your compressor. Thanks.
Dec 12, 2010 | Dometic Rooftop RV Air Conditioner
Wont blow out cold air anymore?
hi...
Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner...
hope this will give u a clear idea..
thank u
rate me!!!!
Jul 19, 2009 | Pelonis Heating & Cooling
Air condition problem
What type of thermostat do you have? If the fan is not coming on and neither is the compressor, then is more than likely a problem with the thermostat of control units of the Air Conditioners. The fan will come whether the compressor does or not if the thermostat and control unit are working correctly. Check for twelve volt at the control unit of the air conditioner ceiling unit. (Red Wire, should be labeled)
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Compressor cuts in and then cuts out
sounds like compressor is locked up or bad compressor start components or could be tripping on a high pressure switch is condenser clean? .T
Jun 17, 2009 | Danby Portable Air Conditioner
Air conditioner keeps tripping breaker replaced the termostat do you think the compressor is gone its only 6 years old.
if this helps please vote me a fix ya
Jul 18, 2008 | Heating & Cooling
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
