Question about Planet Audio VX1502 Car Audio Amplifier
Amp sound i checked all of my wiring and fuses also my levels and my amp is turning on but no sound it started cutting in and out last week and plays nothing now
  • 631 Answers
You need to do the following. Fuses don't always look blown. They can fail in other ways.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know what you find.
Posted on Jul 06, 2008
Zx750.1 kicker amp cutting out
Also check your fuses. there may be a fuse for the in-tank fuse.
Jan 05, 2014 | Kicker (ZX750.1) Car Audio Amplifier
Wekjo Think I need to replace the fuse in my Husqvarna Model yth2146, 960450026. Ive followed all the wires coming fom the ignition harnes, but cant find anuything thats looks like a 20 amp fuse. Do y
a 20 amp fuse should be yellow they use a blade fuse so it will be flat about a 3/4 long and about a 1/4 wide after repairing the wires place drier sheets around the wires this will keep them from being around as much you should also remove the top cover from the engine and inspect under there for a nest and chewed wires as well
Aug 04, 2012 | Husqvarna Garden
Reciever Shuts Off
chances are the speakers are the problem. try disconnecting the speakers and turn up to the level where it cuts out,if it does not cut out chances are a defective speaker or speakers,usally midrange or tweeter
Apr 10, 2010 | Pioneer SX-315
Have a Crate V50-112.Have had it for 1 year. Replaced tubes 2 weeks ago, turned amp on tonight, started to play, amp went dead. Checked fuses, they're good. Any ideas?
Check for bad tube... it HAPPENS that brand new ones fail... USUALLY if they last 50 hours, they will last for the expected life. The bad tube would likely NOT be the main power tubes, as the amp would still run on one cylinder...
Feb 02, 2010 | Crate Music
10a ignition fuse blowing
check wires under seat and around frame sounds like you have a bare wire somewere.
Jul 01, 2009 | 1995 kawasaki ZX-9R Ninja
Car amp turned off in middle of play
make sure and check all the fuses including the one under hood also check all wires to see if they are well connected
May 13, 2009 | Alpine MRD-M1000 Car Audio Amplifier
Blown fuses
I agree with the last answer- your amp has built in fuses that should be rated at 30 amperes each which should be sufficient as the amp only pulls 60 amperes at full power-however you may want to upgrade your power /ground wires to a good 4 gauge set if you dont already have it set up like that-throw an 80-100 amp fuse up front by the battery in case your running another amp for mids and highs just to cover the current draw of the amps combined. If the amp is still blowing fuses after that check to make sure that your subs are wired to no lower than a 2 ohm load as the amp is only stable to 2 ohms.
May 11, 2009 | Kenwood KAC-9152D Car Audio Amplifier
CDA 9885 No idea why it suddenly stopped working
It sounds like you have a bad ground connection. You need to take the radio out and check all the connections. I bet you have a loose one somewhere. That is what the problem was with my bronco
Sep 08, 2008 | Alpine CDA-9885 CD Player
Sony xm-1652z 1000 watt amp
a loose or corroded connection can cause this problem...do not overlook possible loose fuse holder...also look into remote control line...also check speaker line for a loose or shorted connection...a loose connection in any of these locations can cause a spike in the current drawn from the power supply... a bad speaker can play at low volume but short at high volume; if the flex wires from frame to cone on the speaker start to fail, it happens at high volume first, and sounds like a crackle, and gradually becomes present at lower levels; a voice coil can warp at high signal levels, causing it to short intermittently, in addition, you might check the cooling capability of the amp...i don't recall whether you have a fan on this amp...
Jan 11, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp doesnt work
If you've only had it for 3 weeks and it's under warranty, you need to send it to a warranty station.
If there is no warranty and you want to try to find/repair the problem yourself, let me know.
Oct 23, 2007 | Alpine PDX-4.100 Car Audio Amplifier
Planet Audio VX1502 Car Audio Amplifier Logo
121 people viewed this question
Top Planet Audio Car Audio & Video Experts
Tygh Duval
Tygh Duval
michael galang
Are you a Planet Audio Car Audio and Video Expert? Answer questions, earn points and help others
