Question about Bushnell Sportsman 4x32 Riflescope (4x32 mm)
I have a chipped lens on the inside of the scope how do i get it fixed
  • 115 Answers
This will need to be sent to bushnell for repair and they can be reached at 800-423-3537 option 1.
Posted on Oct 06, 2009
HOW DO I ADUST THE LENS ON BARNETT 4X32 SCOPE
4x32 mm Illuminated Crossbow Scope Owner's Manual - Crosman
https://support.crosman.com/hc/en-us/article_attachments/.../432RGMK-515.pdf
E. Windage (horizontal) Adjustment. F. Objective lens. 2. EYEPIECE FOCUSING. Without using your scope, look at a distant object for several seconds.
[PDF]4x32 Crossbow instructions - Mission Archery
missionarchery.com/wp-content/uploads/2014/07/4x32-Crossbow-instructions.pdf Keep the protective lens covers in place when the scope is not in use. ... This optimum adjustment may also require the rings to be moved along the scope rail.
Barnett Crossbow Scope Review - 4x32mm - HuntingOptics.net
huntingoptics.net/crossbow-scopes-reviews/barnett-crossbow-scope-review-4x32mm/ This is a bit above the curve for 32mm objective lens scopes, so I'd call the field of ... The Barnett 4×32 multi-reticle crossbow scope is very easy to sight in, once ... Thanks for reading my review of the Barnett 4x32 multi-reticle crossbow scope.
How to zero a crossbow scope (Tutorial) - YouTube
? 7:55
https://www.youtube.com/watch?v=Td-qESCt7Gw Nov 7, 2013 - Uploaded by Weaponsandstuff93
How to zero a crossbow compatible scope to shoot accurate groups with bolts. ... Some of them crossbows ...
Sighting in a Crossbow Scope - YouTube
? 3:03
https://www.youtube.com/watch?v=TnOIy1ZTe1U Aug 23, 2012 - Uploaded by Ghostkamo
Easy steps to sight in a Red Dot Scope. ... Just bought a Barnett Ghost 410 and needed to check how to ...
HOW DO I ADUST THE LENS ON BARNETT 4X32 SCOPE - Fixya
www.fixya.com/support/t26743320-adust_lens_barnett_4x32_scope 25 mins ago - If your rifle is taped for scope rings this is a easy thing to do, if you do not have any screw holes on top of the barrel you will have to have a smith ...
Sighting in my Barnett scope - HuntingNet.com Forums
www.huntingnet.com > HuntingNet.com Forums > Archery Forums > Crossbows Sep 1, 2009 - 10 posts - ‎7 authors
I have the Barnett 4x32 Multi Reticle scope and as per the instruction it tells me to set the top reticle line at 10 yards. So after about 10 shots I ...
barnett 4x32 scope Questions & Answers (with Pictures) - Fixya
www.fixya.com > Forum > Tags Get free help, tips & support from top experts on barnett 4x32 scope related issues. ... I have a chipped lens on the inside of the scope how do i get it fixed this will need to be sent to ... How do I adjust the reticle for a Simmons Mag 4X32 ...4X32 ... ADUST THE LENS ON BARNETT 4X32 SCOPE Google Search
Sep 18, 2017 | Optics
How to tighten loose front glass lens on pentax gameseeker rifle scope
You have to remove the front element carrier from the scope body and tighten the ring inside the carrier Now the funpart remove the thread protector then the gold ring making sure that the element carrier don't rotate while doing that Then count the rotations till you get the element out as that is important for the parralax free setup or you could just remove it and after repair reparrallax it your self YouTube has some vids on how to do that Threadloc the ring to hold lens tight inside the carrier reinstall carrier to maintube but you have to purge the tube of air and moisture to stop condensation inside the scope and fill with an innert gas Reparrallax scope if required and test zero
Feb 06, 2016 | Pentax Optics
Lense n my v9-IIw is loose inside
how did the lens come loose ?
if you dropped it shell out for a repair or replacement
or if it was through normal use try to get bushnell to fix it for free due to a defect in manufacture
Oct 31, 2013 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
Scope is fogging up and appears to not be clear. Tasco 3x16
Fog in the scope means moister inside. You can try and dry it out, take the rear lens off and using a hair drier heat the tube and the lens separate. Do not blow air inside it may damage the cross hairs. You can try and pressurize the tube so it will not happen again. You will need a large clear zip lock baggy the biggest you can find. Once your scope has been heated with the hair drier. Put the scope in the bag. and try to draw out all the air inside. You can use a Vacuum cleaner. if you get enough air out you can reinstall the adjustment lens on and the tube should stay in a vacuum for a season or two. You can also put vasiline on the threads to help seal the vacuum. You can also try to use gas, you can use gas from a paint ball gun cylinder to pressurize the scope. Put the scope in the bag pressurize the bag and reassemble the scope with the gas inside.
Jan 09, 2011 | Tasco Optics
Bushnell elite 6500 scope mark when looking through
i think you have a fungus growing on the lenses inside of the scope all you can do it have it striped and cleaned then re-gased,,and thats pricy
Jul 23, 2010 | Bushnell Elite 6500 Rifle Scope 2.5 - 16 X...
Hawke HK3102 internal ocular lens unseated
You probably can't fix it, and I don't know if it is worth fixing. There is a guy on ebay that fixes scopes, but like I said, this might not be worth fixing. you can buy a new one for what it will cost. So considering it a total loss, it won't hurt for you to try. You can take off the rear just by unscrewing it, and then the cross hair tube will come out, all different, but usually a cylinder screw driver, ( a tube with 2 notches on it, or a flat piece of steel the diameter of the inside tube. ) Take it out and see what happens next, going in from the front will release the seal, but it might already be broken. If you end up with a basket case, put it on ebay for parts. Hope this helps.
Jun 05, 2010 | Hawke Sport Optics Hawke® Endurance MAP 3...
My scope on my rifle is foggy on the inside
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trash can size. You will need to get your hands on some nitrogen gas or you can also use carbon dioxide gas. You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off your scope, let it dry out a day or so. Now ck for any o-rings and try to find new if you can, put the grease on the screw threads. Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Dec 09, 2009 | Optics
Rifle scope fogging
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trashed can size. You will need to get your hands on some nitrogen or you can also use carbon dioxide. You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off your scope, let it dry out. Now ck for any o-rings and try to find new if you can, put the grease on the screw threads.Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Dec 03, 2009 | Optics
Tasco Rifle scope repairs
Try calling Customer Service at 1-800-423-3537. They should be able to assist you with your needs.
Sep 22, 2008 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Nite Vision scope
Unscrew front lens front of intensifier tube should have an even bronze tinted coating on glass if it is grey and blotchy the tube is degassed. common fault with this model nightvision
wayn
May 12, 2008 | ATN Aries 390 Paladin Weapon Sight
Bushnell Sportsman 4x32 Riflescope (4x32 mm) Logo
206 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
