Question about Sewing Machines
Motor spins, but doesn't sew
I have a singer inspiration 4220. I've been trying to sew some seat cushions with fairly heavy fabric. It was sewing ok, but now it won't sew. The motor spins, but the needle doesn't go up and down. I turned it off and waited, thinking that it was overheated. But then it sewed about 2 inches and quit.
Any suggestions?
Oh, mine did that a while. Then, I dropped a needle in it. I turned it upside down and shook. The one I dropped came out, along with another rusty one. I tried it, the needle worked again, but it didn't sew. Now it works, but again, doesn't sew. Try turning it up-sde down with the place where you put in the bottom thread and the other pannel exposed. My model id very, very old. It's an ELNA Transforma.
Posted on Nov 16, 2008
  • RickRack69 Oct 30, 2010
    My Kenmore Ultra Stitch 12 is quite old as well. The motor works fine, in fact, I have been using it quite a bit lately, until it all of a sudden sounded like something clicked into place and then it stopped moving.
How can I replace bobbin case on Singer Inspiration 4220
Download the instruction manual free from the Singer Sewing Machine site, and go to page 62. It will show you how to reinsert your bobbin case.
The flat part goes UNDER the needle; there is a projection on the right side of the case towards the bottom that must rest against a silver part that is actually a cushion spring and prevents it from spinning. It's pictured in the manual.
It's helpful when reinserting it to insert it slightly clockwise of where it should go--that is, placing the flat part slightly to the right, then twisting it counterclockwise into the correct position, with the case's projecting resting against the spring.
Jun 21, 2014 | Singer 7442 Mechanical Sewing Machine
Singer 4220
try changing the needle
rethread the machine top & bobbin
check to see if the thread has come off the thread take up lever
clean under the needle plate & in the bobbin area for lint & thread
May 02, 2012 | Singer Inspiration 4220 Mechanical Sewing...
What bobbin should be used for a singer inspiration moder 4220
Normally it is a #15 or 15J. Your manual should tell you or you can go online at singerco.com and look under support for a free download of you manual. I checked the Singer site and you may have to have a "surefit" bobbin that is exclusive to Singer. You can call them at 1-800-4singer
Sep 08, 2010 | Singer Inspiration 4220 Mechanical Sewing...
WHEN TRYING TO PICK UP THE LOWER BOBBIN THREAD - HAVE NOW BROKEN TWO NEEDLES. THEY BEND AND SNAP AS IF THE MACHINE IS OUT OF SINK WITH ITSELF.MY MACHINE IS A SINGER INSPIRATION 4220 . (I DONT REALLY KNOW...
Make sure the needles are installed with the flat side facing the back of the machine.
Open the bobbin area and hand walk the needle down to see what it is hitting.
Check the bobbin case and shuttle to be sure they are in place.
Needles can also bend and break if they are too small for the thickness of the fabric.
Feb 28, 2010 | Singer Inspiration 4210 Mechanical Sewing...
Singer 4220 bobbin thread wont raise
To learn how to solve the bobbin problems and select the correct needle, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides Singer sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Oct 23, 2009 | Singer Inspiration 4210 Mechanical Sewing...
Sewing Machines Logo
190 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
