Question about Sony KP-65WS510 65" Rear Projection HDTV-Ready Television
Sony KP-65WV600 My picture has horizontal lines that are more visible the darker the picture
  • smissmarie Jan 14, 2009
    i have the same problem, WHAT IS THIS FROM??
    Problem Solver:
  • 3 Answers
I did fix it but if I told you I would have to charge you a premium
Posted on Jul 04, 2008
T.V. comes on show blue then goes out after 3 second and only hear sound
When it comes on with a blue screen is it rather bright and or has curved faint trace lines in the picture?
Dec 12, 2012 | Sony KP-65WV600 65" Rear Projection...
TV FADES TO BLUE AND THEN PICTURE DISSAPPEARS- AND SOMETIMES TV SHUTS OFF AFTER GOING BLACK WITH CONCENTRIC GREEN LINES
Turn your screen drive down to green and blue tube.
You have a focus/screen drive control block that you can adjust each tube R/G/B
Mar 17, 2010 | Sony KP-65WV600 65" Rear Projection...
My Sony KP-65WV600 65 in. Rear Projection Tv after turning on for a while the picture will turn cloudy blue. How do i fix this problem?
It is not unusual for the CRTs to cause this problem. In this case the Blue CRT. The problem is that you cannot get them anymore. You must send the CRT assembly to Sony for them to rebuild it. Due to the age of the set and the cost of this process, I do not recommend repairing if it is the Blue CRT causing the problem. The only way to be sure is to have a professional check it out.
I hope this helps,
Sky Assoc
Aug 25, 2009 | Sony KP-65WV600 65" Rear Projection...
Color lines out of focus
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru sony.gifSony Expert
Rating: 89%, 674 votes
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Did you think this was helpful? Yes No
new MessageRate('spn1737581','spn1737581cnt','spn1737581stats','spnRateWord1737581','div1737581_yes','div1737581_no','imgStar1737581','ancChangeRating1737581','divChange1737581',1737581,0,0,0,false); Solution #2 posted on Jul 04, 2008 Asker's Rating 0%20stars_w.png
noavatar_s.gif gator149
Rank:nonexpert_s.gif Apprentice sony.gifSony Expert
Rating: 0%, 0 votes
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
May 15, 2009 | Sony KP-65WV600 65" Rear Projection...
Very fine blue lines veiwable when the background has black in it
You need to adjust (actually bit decrease) G2 volts (calls Screen volts) of Blue gun.
If you are familiar with big TV repair and have electronics knowledge then let me know to guide you further.
thank you.
Dec 13, 2008 | Sony KP-51WS500 51" Rear Projection...
Blue rainbows lines
I can help you out because I have circuit details of KP-65WV600but let me know what does it mean of blue rainbow lines?
I would appreciate if you post picture of those blue lines to understand problem of TV.
Thank you.
Nov 24, 2008 | Sony KP-51WS500 51" Rear Projection...
Curved blue lines on screen.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kp-65wv600 blue arch line on left side
in the menu does it have a convergence menu? try doing that.
Feb 20, 2008 | Sony KP-57WS500 57" Rear Projection...
SONY GREEN CONV OUT BLUE/GREEN OK,SONY KP-65WV600
Red,blue and green each have an amplifier IC--Stk392-560 x 2
Replace both IC's for reliable repair.Also,check  fuses,location sometimes ps5003-5008. fuse value 3.15 amp. ......T.
Oct 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-65WS510 65" Rear Projection HDTV-Ready Television Logo
77 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
