Question about Dewalt 18 Volt Compact Drill Kit
Dewalt DC925 Clutch Ring Jammed
I have a new (1 week old) DC-925 hammer drill. The main issue.... the clutch ring is jammed. I am not sure when it happened, or if it was always that way. I have only used it in the drill mode... No hammer function, and no clutch settings. I have drilled maybe 12-15 holes, and that is all. I went to adjust the clutch for driving a screw and the ring was jammed. I have tried to force it. It has the new type of chuck on it so I have been unable to remove it to try and release the ring. I know it is under warranty but I have jobs comming up that I need it for.
  • daver56 Jul 06, 2008
    How do I loosen those screws without removing the chuck?
    Champion:
  • 313 Answers
If your in hurry & away from the service center all you need to do is just loosen the 4 screw that holds the clutch housing & set it # 1 & back to drill mode couple of times. do not remove clutch if your not sure co'z its got tiny needle bearing on front of the transmission.this is just a temporary fix . it may happened again.
Posted on Jul 06, 2008
  • mr aicnelav Jul 09, 2008
    you dont have to removed the chuck.located outside close to the clutch setting 1 to 21.
I have a DeWalt DC925 type 1 hammer drill,took it apart to repair switch and clean. Four pin bearings fell out,I don't see them on a parts diagram,where do they go ?
You will find them in the transmission, remove the metal cover and they will be located just under it - sounds like it is either the gear posts or the clutch cams on the nose side of the transmission DeWALT DC925 Type 1 Hammer Drill Parts
Mar 23, 2015 | Dewalt DC925 Cordless Drill
It is very hard to turn the adjustable ring that switches from drill to hammer grill
Hi my 925 has had same problem right out the box it must be an allignment thing a find a tap with the old hammer sorts it out
Sep 15, 2012 | Dewalt DC925 Cordless Drill
Can't engage drill or hammer settings on de walt dc 925 xrp
Try turning the ring to 2 or 3 and run the drill holding the chuck so the clutch slips then try turning it to drill setting. Also try to do it in different speed settings. If not it sounds like a fault in the gear module. It might just be a metal clip just under the clip in side. Undo the 4 screws holding the gearbox onto the housing and carefully remove it, you might see the fault or loads of dirt that needs cleaning. Go to http://www.2helpu.com/world/map.aspx for a drawing.
Jun 01, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Dewalt dc925 drill, the chuck jaws appear to be jammed tight shut and will not open. any ideas?
Hi, soak the chuck in crc overnight then put the drill in low speed and reverse. Hold the chuck by hand or with multi grips and pull the trigger. Hope this helps, regards Phil.
Jul 23, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Motor works and spins but as soon as the drill touches the wall drill stops but motor keeps going.
Check the speed switch on top - sometimes it doesn't fully seat in the 1 or 2 position. Switch it to the opposite setting, run it, then switch back, until it seats properly. Also check the clutch control ring for the same issue.
Jul 21, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Drill works fine but wont engage hammer. the torque ring goes from 1 to 21 ok but i cant engage the drill or hammer setting
On my DW988 the ring would go past 21 a couple of clicks to a symbol that looks like a yellow T and that would be hammer mode when I press down to drill.
Nov 18, 2009 | Dewalt DC925 Cordless Drill
I want to switch the drill chuck.model dc 925.how to do it?
CONTACT YOUR NEAREST TOOLKING STORE THEY WILL ADVISE YOU
Aug 13, 2009 | Dewalt DC925 Cordless Drill
I have an 18v dewalt hammer drill dc925 and cant get it on the hammer setting?
It's one of the settings on the clutch ring. Or do you mean it won't turn there?
Mar 07, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 Volt Compact Drill Kit Logo
856 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
