Question about Whirlpool Heating & Cooling
Whirpool furnace model fs643-125cr can you change bloerw speed
  • harpy03 Jul 04, 2008
    put 3 ton unit a/c in and a coil icing up charge is okblower seems very slow on gas furnace
  • 182 Answers
Changing blower speeds can often cause bigger problems somewhere else in the system.More is not always best.What do you hope to do?
Posted on Jul 04, 2008
Atwood 1522 LP furnace fan operates at one speed only
Furnace only works at one speed, high and low fan is usually used for AC. It never has had 2 speeds on furnace correct? Furnaces usually only have 1 speed, except for some home models.
Mar 14, 2014 | Atwood 38591 Excalibur XT Furnace 1522 15K...
Tip
Furnace Troubleshooting
On some natural or LP gas furnaces, the blower motor has to come on 1st
and then shuts off. This process starts the inital call for heat. If you find
yourself without heat and the blower does not run, turn the furnace to on
at the thermostat.
When changing the fan to on, you are changing the speed, if the heat comes on, that means you have a burnt out speed on your blower motor.
If nothing happens, change the fan speed at the control board.
In some instances they may be using the same blower speed in both the
heat and cool mode.
on Jan 19, 2010 | Heating & Cooling
Can I change airflow direction with Goodman GMS8?
I would probably use a furnace for the correct application. However some motors do have a reverse speed connection. Besides the blower speed taps,
capacitor wires and the nuetral wire. There are two wire sets that you can switch that can do this if your blower motor is equipped.
You might experience some airflow problems, probably a lack of airflow, if the furnace was installed
as an upflow model instead of a counterflow.
Feb 17, 2010 | Goodman GMS90703BXA Heater
What is the efficiency rating on the Trane model BLU055E936B1 upflow furnace and what new furnaces are available to replace this old Trane furnace without having to change the venting system.
Chances are you need to replace both the condenser and furnace, then you you should get a varaible speed blower with the new furnace, get at least a 90% gas system with a 16 SEER condenser, save on energy cost as soon as it's installed. Go Get IT
Jan 28, 2010 | Ruud Central System Air Conditioner
My intertherm furnace (old model) has recently getting quite loud and clunky during its heating cycles, sound like the blower maybe??
Your blower motor has several speeds to it and by the problem you are having it sounds as though the blower motor may be going out. The motor has a slower speed for the heating cycle and since you have the noise in the heating mode I suggest having the blower motor changed as soon as possible since it could cause other problems in the heating section of the furnace( possibly burning out the high limit switches). Good Luck on your repairs hope this helped
Dave
Oct 20, 2009 | Intertherm P3RA-048K Air Conditioner
The furnace send signal to the fan in about 30 seconds, now this fan is set in auto from my termostat, my problem is the fan is starting slowly and some time it don't start, but if I use the option manual...
Depending on the model of the furnace, the blower is either a 2 or 3 speed. When the furnace operates in heating mode with the thermostat in the auto position, the furnace starts the fan when the furnace reaches a specific temperature or after a set time delay, but it operates the fan in low or med low speed on heat mode, when you put the thermostat fan switch in the "ON" position, the furnace operates the fan in "HI" speed, the same speed used for cooling mode. You may have a blower moter that is starting to short. I would recommend having a professional replace the motor before now before it becomes an emergency in the middle of the night during a cold spell.
Oct 10, 2009 | Heating & Cooling
1994 Carrier 58 PAV
sounds like the relay for the unit may be bad, usually if a blower motor goes it stops or has a very loud humm and only goes slow
Aug 03, 2009 | Heating & Cooling
Why is my Whirpool Window AC fan speed not changing? I have replaced the switch already!
possible that the fan motor speeds have gone out.. On the cooling cycle the fan speed is set for higher speeds and heat cycle slower speeds. it is possible that the fan motor in that speed you are needing is burned out
Jul 11, 2009 | Whirlpool ACQ108XL Air Conditioner
Fan speed setting of my Carrier furnace model 58wav091-14
most time, you don't have to do anything because the default setting for wiring with fan speed already. if not, trace the motor wires from motor with red , white and black from motor fan to PL2 and PL1. the best is look at a diagram from your actual furnace.
Sep 29, 2008 | Haier HWR06XC5 Wall/Window Air Conditioner
Heating & Cooling Logo
44 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
