No video Hi this is ken again, I tried everything the board seems to be booting up I tried a different video board out of my computer that I knew was working with my screen just to make sure and this video card went in the PCI slots and I tried it in all three or four slots and nothing on the screen. The monitor actually knows that the cable is connected it just goes into sleep mode while the rest of the computer is running I can see all the lights come on the keyboard the dvd and cd drives and the 3 1/2 drive also lights up I just cant seem to find the bios. it just won't come up on the screen. I jump the bios pin and I even took out the battery for 5 minutes and checked it with a meter. If you have any other suggestions I sure could use the help I hate to buy a new board and cpu chip without knowing for sure thank you for all your help still trying
  • 983 Answers
Ok fine i think there exists some problem in the cable connecting from the CPU to the monitor just try removing that & inserting it again ....
if the same problem persists then there may be some problem in the port of the video card just take tester & test is there power supply or not ....
if there is no power supply then some of the capacitor on the video card might have burned out due to this ports will not be working ....
if there is power supply then there will be one IC(integrated circuit ) on the motherboard just near by the AGP or PCI express slot (i think in your motherboard there are 3 IC s near there)
in those 3 IC s if some IC goes means also you will not get the display ...
(the video must be inserted to the PCI express slot or AGP slot only) you must not insert it on PCI slots ...
you make a difference of PCI or AGP slot as this will be only 1 or 2 on every motherboard & it will be smaller in size than the PCI slots & there will be colour difference(may be the PCI slots will be white colour & AGP or PCI express slot in black or brown colour it depends on the motherboard)
check on which slot you have inserted it & insert it correctly if you inserted in some other slots ...
remove the video & insert it again & try check the cables the cable may be loose contact ...
any doubts you can reply me
i am always here to assist you
thank you
bye
dnt forget to rate my solution
Posted on Jul 04, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jul 04, 2008
    ok fine i think there exists some problem in the cable connecting from
    not ....
    thank you
    bye
STEADY AMBER LIGHT NO POST/BOOT UP/DISPLAY, but fans work. Already tried switching RAM, dusting, unpugging everything on motherboard and plugging in again, trying different video card, different cmos...
Since you have tried everything and seems you know your way around the hard ware, I would not write any precautions. That said, the only thing you missed in your question is the CPU. You can try taking it out, look for the buildup dust + cpu glue (this could look like mud). Try to clean off these with tissue paper. Apply new CPU glue (this you can find from IT hardware store/ radio shack) between the CPU and the heatsink (not too much). Put the CPU back in the socket, Plug everything back on and switch on. See what happen. If it does not work you are about to buy another CPU. Worse, mother board + CPU. Sorry mate. Baseball bat option is not recommended. :)
Oct 09, 2013 | Dell Studio XPS 9000 (DXCWPP12) PC Desktop
Very sluggish and terrible audio when playing MP3's
check your computer RAM (random access memory) may be its not working first try to replace your ram then change your video card....
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 25, 2010 | Intel D915GAV Motherboard
Sept. 28, 2009 (:24 PM EST The problem is that with no warning at times my monitor HP U1506 will go black and flash the message '' No Signal ''. As equally mysterious it will recover and work okay. I have...
The issue is not the monitor, it is the video card. It may be a driver issue (Download and update the display adapter with the latest video driver.) also try booting in the safe mode, See if the issue occurs in safe mode. If the driver update has no effect and issue occurs in safe mode, you may need a new video card. Also disable any screen saver (Set Screen saver to NONE) see if issue goes away. If none of that helps. replace the video card
Sep 29, 2009 | Computers & Internet
Problem booting into Windows.
This could be a hard drive problem. The hard drive is looking for the boot sector on it, but the boot sector is broken. Computer shuts down and tries again but your hard drive can't find the boot sector so it shuts down tries again etc.
Hank
Sep 24, 2009 | ECS C51GM-M Motherboard
What does it mean when different RAM is in
try to insert only one RAM then boot, but if doesn't try the other one then boot again but if the two doesn't work try raplacing your video card with a new one for testing but then again if it doesn't work check if your monitor is working maybe you have a bad monitor good with that...
Jul 10, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
T30 boot problem
Once again , bad ram will prevent your computer from booting , make sure you are using a known good ram module.
don001996
Mar 08, 2009 | IBM ThinkPad T30 2366 Notebook
I have a DFI AM75-TC motherboard, 3beeps, no video
Hi richardbyers, three short beeps means there is a problem with your memory. (Base 64K memory failure). Unplug the power from the PC. Open the case & touch the bare metal on the case to discharge your self.
Remove the memory & reseat it. Leave the case opened & re-connect the power cord & try booting again. If you still hear three short beeps, shut the system down again as mentioned above. Gather some house hold alcohol & a couple cotton swabs. Drip a drop or two onto a cotton tip & wipe the memory's contacts, both sides & do not touch the contacts with your fingers during re-install or cleaning. Blow the memory slots out with canned air or use a clean paint brush. Insert the memory again & connect the power cord. Boot the PC. Try this first. If everything works out than good. If the problem does not clear its self let me know.
Good luck richardbyers!
Mike
Jan 06, 2009 | DFI AM75-TC Motherboard
Monitor will not turn on after booting computer
if you have onboard video try a video card that fits in PCI or AGP slot or try a different video card in place of the one you use
with everything else seeming to be correct this seems like the only thing you have not done
Aug 03, 2008 | Intel Motherboard
Mother board asus A7V8X-LA
then that video adapter IC (integrated circuit ) in the motherboard which is located near the AGP or PCI express slot is in problem just visit the motherboard technician & get replaced that one ..
it will work ...
the cost of it is some what higher i think to repair .....
just once you visit the motherboard technician before you purchase the new board ....
Jul 04, 2008 | Computers & Internet
P4v8x-x bios dont boot
your problem is in video card, try to remove and clean the connectors (bronze color) with an eraser. then re-install, if the problem still occurs try to hear beep (warning sound). we have different sound for the installed hardwares such as the memory card, video card and the boot sound. if you have installed an expansion video card remove this and use your on board video card to determine if the video card you installed is defective. and if you are using the on board video card install a new video card
Oct 20, 2007 | ASUS P4V8X-X Motherboard
Computers & Internet Logo
123 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
