Question about Car Audio & Video
Help is the front window - Car Audio & Video
    Sergeant:
    Champion:
  • 330 Answers
What?
Posted on Jul 04, 2008
  • Frank Chen Jul 05, 2008
    do you want to changethe speakers or you want to find out how to?
No power to the left front window 1996 honda crv
Motor works but window doesn't?
Remove the inner door panel & replace
the broken window regulator
Switch over motor to new one
No voltage to switch?
Some other issue?
Nov 24, 2012 | Cars & Trucks
My driver side electric window assembly collapsed and the window fell down inside the door. The motor is still very good, but I need info and/or a diagram of how it is assembled in order to repair it and...
  1. Lower the window halfway.
  2. Remove the front side door trim panel.
  3. Remove the water deflector.
  4. Support the window in a position needed to access the window rivets by inserting a rubber wedge door stops (1) at the front and rear of the window between the window and the door inner panel.
  5. Drill out the window rivets (3) with a 1/4 inch drill bit.
  6. Remove the window (1) by lifting out of the door. Important: Inspect the window bushings, window bushing retainers, window front up stop, window stabilizer pins and window wedges on the window for damage.
  7. Remove the window bushings and window bushing retainers if necessary, using a flat-bladed tool covered with cloth body tape.
  8. Remove the window front up-stop screw if necessary.
  9. Remove the window front up-stop, front up-stop nut and front up-stop washer if necessary.
  10. Remove the window stabilizer screws, if necessary.
  11. Remove the window stabilizer pins, stabilizer pin nuts and window wedges if necessary.
Installation
  1. Install the window stabilizer pins, stabilizer pin nuts and window wedges if necessary. Notice: Refer to Fastener Notice in Service Precautions.
  2. Install window stabilizer screws, if necessary. Tighten the window stabilizer screws to 7 N.m (62 lb in).
  3. Install the window stabilizer pin nuts, if removed. Tighten the window stabilizer pin nuts to 8 N.m (71 lb in).
  4. Install the window front up-stop washer, if removed.
  5. Install the window front up-stop screw, if removed. Tighten the window front up-stop screw to 7 N.m (62 lb in).
  6. Install the window front up-stop nut if removed. Tighten the window front up-stop nut to 8 N.m (71 lb in).
  7. Install the window bushings and bushing retainers, if removed.
  8. Install the window (1) into door so that holes in window bushings line up with holes in channel.
  9. Install the window rivets (3) in sequence.
  10. Install the water deflector.
Hope this helps
Oct 15, 2010 | 2002 Chevrolet Camaro
How do you replace the regulator for the power window on the 2002 ford explorer
Regulator - Power Windows - Front Door
  1. Remove the front door trim panel as follows:
    1. Remove the front door handle bezel.
    2. Remove the front door window/lock control switch bezel.
    3. Disconnect the window/lock control switch electrical connectors.
    4. Remove the 3 front door trim panel screws.
      CAUTION To avoid damaging the trim panel, do not pull directly outward to carry out this step.
    5. Lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
    6. Remove the exterior mirror control switch from the front door trim panel.
  2. Remove the front door speaker.
  3. Remove the interior molding.
  4. Disconnect the door lock actuating rod at the door handle assembly:
    1. Release the door lock actuating rod clip.
    2. Position the door lock actuating rod aside.
  5. Remove the front door weather shield.
    CAUTION Make sure the holes in the glass bracket do not become enlarged during the rivet removal process. If the holes become enlarged, the new rivets may become loose, resulting in clicking noise concern.
    NOTE Some vehicles may use rivets to attach the window glass to the window regulator assembly. Use a 4.5 mm (0.1772 in) drill bit to drill out the glass-to-regulator rivets.
  6. Remove the 2 front door window glass-to-regulator bolts or rivets.
  7. Position the front door window glass as necessary to access the front door window glass-to-regulator bolts or rivets.
  8. Secure the front door glass in the full up position with tape.
  9. Disconnect the window regulator motor electrical connector.
  10. Remove the 4 window regulator assembly nuts.
  11. Remove the window regulator assembly.
    Fig. Exploded view of the front door and power window components-2005 Explorer and Mountaineer
To install:
  1. Position the window regulator assembly.
  2. Install the 4 window regulator assembly nuts. Tighten to 89 inch lbs. (10 Nm).
  3. Connect the window regulator motor electrical connector.
  4. Remove the tape securing the front door glass in the full up position.
  5. Position the front door window glass as necessary to access the front door window glass-to-regulator bolts or rivets. Install the bolt and tighten the bolts to 62 inch lbs. (7 Nm), or install new rivets.
  6. Install the front door weather shield.
  7. Connect the door lock actuating rod at the door handle assembly:
    1. Position the door lock actuating rod into proper location.
    2. Attach the door lock actuating rod clip.
  8. Install the interior molding.
  9. Install the front door speaker.
  10. Install the front door trim panel as follows:
    1. Install the exterior mirror control switch from the front door trim panel.
    2. Position the door trim panel onto the armrest to engage the panel clips.
    3. Install the 3 front door trim panel screws.
    4. Connect the window/lock control switch electrical connectors.
    5. Install the front door window/lock control switch bezel.
    6. Install the front door handle bezel.
  1. Raise the front door window glass to the full up position.
  2. Remove the interior door handle.
  3. Support the front door window glass.
  4. Disconnect the front door window regulator motor electrical connector.
  5. Remove the equalizer bracket nuts.
    Fig. Remove the equalizer bracket nuts-2005 Explorer Sport-Trac
  6. Remove the front door window regulator by removing the rivets and nuts.
  7. Remove the front door window regulator motor retaining bolts and then remove the motor.
    Fig. Remove the front door window regulator motor retaining bolts and then remove the motor-2005 Explorer Sport-Trac
To install:
  1. Installation is the reverse of the removal procedure.
  2. Tighten the regulator motor mounting bolts to 8 ft. lbs. (11 Nm).
Hope this help (remember rated and comment this).
Mar 24, 2010 | 2002 Ford Explorer
The windows front and rear wont work. The front
Change your master power window switch in the drivers door.
Aug 03, 2009 | 2000 Dodge Caravan
2003 honda accord Power window
have the window regulator checked. If you are hearing clicking from both sides, your regulators are worn/damaged. Hopefully this helps
Jul 23, 2009 | 2003 Honda Accord
Instructions on how to install window regulator on 99 Expedition
Answer
Here is the procedure, the "dimples" are on the metal surface of the inside of the door. With the waterscreen off you can locate the motor to help you tell where the dimples are. Drill holes then use a socket to remove window motor bolts.
Front Door Window Regulator Motor
Removal and Installation
Remove the front door trim panel.
Remove the door speaker.
Position the watershield aside.
CAUTION: Make sure the electrical connector is positioned aside before drilling.
To access the power window motor bolts, use a 19 mm (3/4-in) hole saw with a 8 mm (1/4-in) pilot to drill three holes at the existing drill dimples on the door.
Disconnect the front door window regulator electrical connector.
Remove the bolts and the front door window regulator motor.
To install, reverse the removal procedure.
Cycle the window glass to make sure the gears engage
Jun 22, 2009 | 1999 Ford Expedition
Fallen driver's side window
probably need a new window regulator. ebay. 93 to 98 should fit.
Section 01-05: Trim, Interior 1998 Villager Workshop Manual
REMOVAL AND INSTALLATION Trim Panel(s), Door Front
Removal
  1. Disconnect the battery ground cable (14301) if equipped with power locks or power windows.
  1. swv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the front door inside handle escutcheon (22620). Failure to do so can result in damage to the component.
    Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942) .
  1. If equipped with manual windows, slip a clean shop rag between the window regulator handle (23342) and the front door trim panel .
  1. Pull the shop rag back and forth to release the window regulator handle clip.
  1. Remove the three cover caps and front door trim panel screws.
  1. Remove the one front door trim panel capped screws from the door pull handle.
  1. If equipped with power windows, remove the door pull handle. Disconnect the electrical connectors.
  1. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124) .
  1. Remove the front door trim panel.
Installation
Window Regulator, Power Front Door
Removal
  1. Disconnect the battery ground cable (14301) .
  1. Remove the front door window glass (21410) . Refer to the front door window glass removal procedure in this section.
  1. Remove the two front door brace bolts and the front door brace.
  1. Disconnect the front window regulator electric drive electrical connector.
  1. Remove the four front door window glass regulator track bolts.
  1. Remove the three front window regulator electric drive bolts.
  1. Remove the front door window glass regulator track and the front window regulator electric drive (23394) as an assembly through the opening in the front door (20124) .
Installation
  1. Install the front door window glass regulator track and the front window regulator electric drive as an assembly through the opening in the front door .
  1. Install the three front window regulator electric drive bolts. Tighten the front window regulator electric drive bolts securely.
  1. Install the four front door window glass regulator track bolts. Tighten the front door window glass regulator track bolts securely.
Apr 29, 2009 | 1998 Mercury Villager
Power window problem. engauges then disenguages
Section 01-11: Glass, Frames and Mechanisms 1997 Windstar Workshop Manual REMOVAL AND INSTALLATION Door Glass and Regulator, Power Windows Removal
svw~us~en~file=ani_caut.gif~gen~ref.gif WARNING: IF THE REGULATOR COUNTERBALANCE SPRING MUST BE REMOVED OR REPLACED FOR ANY REASON, MAKE SURE THAT THE REGULATOR ARMS ARE IN A FIXED POSITION PRIOR TO REMOVAL TO PREVENT POSSIBLE INJURY DURING C-SPRING UNWIND.
  1. Remove front door trim panel (23942) and front door inside panel sound insulator (20394). Refer to Section 01-05 .
  1. Remove inside door belt weatherstrip.
  1. Remove front door window glass (21410) as described in this section.
  1. Remove two nut and washer assemblies attaching the window regulator equalizer arm bracket (23230).
  1. Remove four rivets retaining the front door window regulator base plate to door inner panel.
  1. Remove front door window regulator (23200) and front door window channel bracket (23288) from vehicle.
  1. Working on a bench, carefully bend tab flat to remove front door window regulator arm slides from front door window channel bracket.
  1. NOTE: Use care not to break tab; if tab is cracked or broken, replace front door window channel bracket. Make sure rubber bumper is installed properly on new front door window channel bracket, if replacement is made.
    Install new front door window regulator arm plastic guides into front door window channel bracket and bend tab back to 90 degrees.
Installation
NOTE: The front door window channel bracket and window regulator electric drive (23394) are installed into the vehicle as one assembly. The front door window channel bracket may be disassembled from the window regulator electric drive as described in Door Glass and Regulator, Power Windows .
  1. Install window regulator electric drive with preassembled front door window channel bracket into vehicle. Set the regulator base plate to door inner panel using base plate locator tab as a guide.
  1. NOTE: Two 1/4-20 x 1 inch bolts and two 1/4-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (35-44 lb-in). Equivalent metric retainers may be used.
    Install four rivets to retain front door window regulator to door inner panel.
  1. Install window regulator equalizer arm bracket.
  1. Lower front door window regulator arms to access holes in door inner panel. Install front door window glass as outlined.
  1. Install inside door belt weatherstrip.
  1. Adjust front door window glass to make sure it is properly aligned with glass run. Check window for smooth operation.
  1. Install front door trim panel and front door inside panel sound insulator. Refer to Section 01-05 .
Item Part Number Description 1 21410 Front Door Window Glass 2 23288 Front Door Window Channel Bracket 3 23394 Window Regulator Electric Drive 4 23230 Window Regulator Equalizer Arm Bracket 5 222A00 Front Door Glass Run Latch Side Retainer 6 N621906-S36 Nut and Washer 7 N800510-S36 Screw 8 23200 Front Door Window Regulator 9 W525172-S Rivet 10 W525175-S Rivet 11 — Wire Connector (Part of 14630 Wire Assembly) A — Tighten to 7-10 Nm (62-89 Lb-In)
Apr 13, 2009 | 1997 Ford Windstar
How to replace window regulator
you will need to drill out some rivets. Replace with ntus and bolts and washers & lock washers. Make sure they don't hit glass going up and down. Otherwise you will need a heavy duty riveter.
please rate as fixya if this helps.
Motor —Front Door
Special Tool(s) swj~us~en~file=st1132a.gif~gen~ref.gif Heavy Duty Riveter
501-D011 (D80L-23200-A) or equivalent
Removal
NOTE: The window regulator and motor are removed as an assembly.
  1. Remove the front door trim panel. For additional information, refer to Section 501-05 .
  1. Remove the front door radio speaker.
  1. Remove the latch remote control. For additional information, refer to Section 501-14A .
  1. Remove the front door watershield.
  1. swj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Support the window glass to avoid damage.
    Raise and support the front door window glass to the full up position.
  1. Disconnect the power window motor electrical connector.
  1. Remove the window glass to regulator nuts.
  1. Remove the motor and window regulator assembly.
    1. Drill out the rivets.
  1. NOTE: Prior to motor removal, make sure the regulator arms are in a fixed position to prevent counterbalance spring unwind.
    Remove the power window motor.
    1. Remove the bolts.
    1. Remove the power window motor.
Mar 21, 2009 | 1998 Ford Expedition
Driver side window
look around the seal theres like plastic retaining clips if they come undone or break ur window will do this 38480part number @rockauto.com should help
Jun 14, 2008 | 1998 Pontiac Grand Am
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
