Question about Garmin StreetPilot C330 GPS Receiver
Screen freeze and unit has gone dead -C320
The dreaded screen freeze happened on my C320 unit. As per the manual, I reset the unit. However, I am unable to power back up again. Pressing the power button has no effect. I tried connecting the unit to my laptop through USB thinking the battery might need recharging. However, the unit still does not respond. Its just dead!! Any suggestions??
  • usrika Jul 07, 2008
    Jerry G:
    Thanks for the suggestions. I did try checking the battery - the DVM indicates that its not a battery issue. Maybe a hardware failure; like you have suggested. Garmin tech support says they will fix it for $125. I have decided to get a new GPS unit.
    Genius:
  • 1,673 Answers
If the unit is out of warranty, you have nothing to loose by opening it.
If you open the unit, look for its battery. I cannot remember if the battery is soldered in or is on contact connectors. If the battery is solder connected you will need a small soldering iron, the skills, and some proper tools.
Disconnect the battery on one side, and wait about 30 seconds. Now connect (solder) the battery back again. This will make it do a hard re-start.
If the unit is still failing, or does not start, check the battery with a DVM to see if it is at the proper voltage. Read the label on the battery to know the voltage.
It is also possible that there is a hardware failure. Inside many of these models there is an inverter board. Sometimes this inverter board can fail, and need to be replaced. The cost of the board for this model is about 50% of the cost of a new model unit. Also, if the inverter board has failed, you would need to be able to do some tests to know if there are other faults. This you cannot do without the proper set-ups, service information, and training.
Jerry G.
Posted on Jul 07, 2008
  • Jerry Greenberg
    Jerry Greenberg Jul 07, 2008
    You did exactly what I would do in your case!
    I suggest the Garmin nuvi 460W or equivalent. I tested many of these. I had a supplier loan me a number of them to try. I found that this model gave the most for the price, if you do not need Bluetooth or the MP3 Player. I use a GPS for what it is supposed to do.
    In your area, you may need to get a different equivelant model type in the Garmin.
    I used to sell GPS's. I found that Garmin on the average had the best performance for the price, even though it did not give as many options for the price. I prefer performance and accuracy, because that is what is going to take me where I am going!
    Jerry G.
A couple of days ago I turned on my brand new (about 6 weeks old) Samsung 50'' plasma pn50b650 I noticed an imperfect picture at the top of the screen. Upon closer inspection, there were about 4-5...
U freeze video games 10-20 mins in video game alot of time.Never pause or freeze any kinds of video image in Plasma tv.It very easy cause to burn in Plasma tv problems alots.
Feb 25, 2010 | Samsung PN50B650 50 in. HDTV Plasma TV
Flip Video Mino keeps freezing up, can't shut down or upload
At least the following works on my first generation Flip Ultra camcorder (not Mino). Remove battery, put it back next morning. After that be careful not to touch "on" slider switch on the side of the camcorder while Flip logo is still on the screen. I mean turn the device on by using the slider switch and do not touch that switch again until Flip logo on the screen is gone. Doing the opposite (trying to use the "on" switch again while device is still "booting" and Flip logo is on the screen) will lead to the Flip Ultra freeze.
Jul 27, 2009 | Pure Digital Flip Video Ultra Camcorder
MioC320 acts like connected to computer when using car charger
i hate when this happens but the main thing is pretty much let it reset it self by letting it run out of battery till it shuts off and plug it in i really dont understand why these units do it but it worked for mine
Dec 28, 2008 | Mitac Mio C320 Car GPS Receiver
Bad freezing and screen crash
Suggest reseting to factory settings.Hard reset..as per your manual.if no manual download one at factory web site.RICHARDM69
Dec 08, 2008 | T-Mobile MDA
Creative zen v problems-frozen
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Aug 25, 2008 | Creative Labs ZEN V Plus MP3 Player
Black screen
This problem has happened to me before turn the gps unit over and clean off the gold colored conductors on the bottom take a paper clip and touch the 1st and 4th pins together this resets the unit be sure it is the 1st and 4th pins on the opposite side of the little power connector though.
Jun 26, 2008 | Mitac Mio C320 Car GPS Receiver
My garmin c320 wont track any satalites
hi, my garmin c320 has a clear view of the sky but it cant track any satalites i don't know what to do. or if there is anything to do. can some please help me. thanks
Apr 29, 2008 | Garmin StreetPilot C320 (010-00401-00) GPS...
Nuvi 610 - External charging causes screen to freeze.
Don't disconnect it just because the screen freezes. This can happen if the battery is depleted too far, because the load is too great for charging AND running the device simultaneously. Leave it connected for 20 minutes or so, to see if the screen returns to normal appearance. If not, then you will be needing a new battery. Be sure to charge the new one BEFORE it is fully depleted. They are not NiCd batteries, so there is no need to fear ?memory effect". With NiMh and Lithium batteries, those days are gone, thank God!
Mar 30, 2008 | Audio Players & Recorders
Touchscreen offset
Here's what you do: Turn off the gps. Then, hold the power button for approximately 30 seconds. The calibration screen will appear. Follow the instructions to re-calibrate the touch screen.
Feb 26, 2008 | Garmin StreetPilot C320 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
107 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
