Question about Maytag SkyBox MBV1976A Beverage Dispenser
Skybox pop machine
Mine works great,,but one of the slots will not let the cans go down,,its like its stuck or just quit workin,,,i want to sell it due to hard times but not sure how to and what i should ask for it,,it also has a stand with it
    Problem Solver:
  • 7 Answers
(assuming you want to try to fix your problem) then did you read the other posts regarding dispensing problems? it is possible that ice buildup on the back of the dispensing mechanisms at some point has pulled the cable for that dispenser out of its connector.
it isn't hard to take the entire dispensing unit out far enough to see all the cables/parts on the back...this is better done with 2 people, but can be done with one: unplug the machine, open the door, un-velcro the cloth band on the left and if I remember there are 4 or 5 screws deep inside the far left (where the cans fall where you un-velcro'd the band), 3 or so at the bottom face of the unit, and one in the upper right corner face near the top child lockout switch. don't start taking out all the other screws you see as they are just holding each bay of the mechanism to each other. if you got all the right screws the entire mechanism should move pretty freely to come out, so if it doesn't then don't force it...just find the last screw or two you didn't get and try again.
once you can pull the dispensing unit out, then get it out far enough to see its back...there will be a bunch of motors, wires, etc plugging into a board back there. hopefully you will find if you follow the motor wire from the non-working bay, it will be unplugged or not connected well...push all connections in on this board to be sure they are tight - hopefully it will start working. if not, you have a different problem which I don't know much about troubleshooting as I really haven't had problems in that area...the only other easy thing to try is on the outside back of the machine (where the sticker is with the serial number, etc), take the back vent panel off, then the rectangular panel off on the right (4 screws) and see if all the cables on that board are properly connected. if one wasn't connected well, you may have found your problem...good luck.
Posted on Jul 04, 2008
Skybox is not dispencing any pops,when you push the button noting
Check the wiring harness at the bottom of the door AND the child lockout switches at each bin. The switches disable the bin in the down position.
Jul 24, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox beverage dispenser. will dispense one can
I had the same problem. Found the cover where the beverages dispense to be rusted and not resetting. After the can dispenses, just push the cover back into position and this should help.
Jun 09, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
How to replace overload relay in Maytag Skybox
I'm not sure what you mean by "overload relay". I designed the electronic controls for Skybox. I have some parts, all of the schematics. I do not have any of the refridgeration components.
I just ran across your question looking for Skybox graphic panels for mine. I'm not sure how I can get you what you need.
Gary
Jan 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Mike - my Skybox is having the same issues - not cooling
thats the relay --- the relay controlls when the compressor works
some places try to sell you a capacitor and transformer
thats not the problems
capacitors store power and transformer steps power up or down for circuits
the problem was the overload relay--replaced and works just like new
maytag had no clue about the repair, only could say it was discontinued and they dont sell parts
Dec 30, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox dispensing chut
well, the middle 2 chutes are not the same part number as the top or bottom...what is the part number of your assembly? where are you located?
Nov 03, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Bogus Skybox
Sorry, I don't have this problem.
My skybox flashed all lights and did not deliver.
I cleaned mildew off the photo eye on the left side of the tray flap
(very small) and my skybox continues to work to this day.
Aug 06, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Dispensing
Samething here check straight in and see if you see ice. I could see isce in the slots. Unpluged an defrosted and works fine again.
Aug 02, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
3/4 buttons work
mine did the same thing. apparently, if the internal unit gets too cold, it freezes operation in some of the buttons. try turning up the temp to let it thaw, then try the button again. the downside is that when you turn down the temp again, you are likely going to face the same problem.
Jun 06, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox
Looks like I found the answer to the problem of Skybox not dispensing. I replaced the sensor in the dispensing door and my Skybox now works great!
Part is available from partselect.com just look up your Skybox model number, mine was Skybox model MBV1976AAB. The diagram on the website should show you the exploded view of the door section of your Skybox. You are looking for partselect.com part number 901892 or on the exploded view it will be number 21. The Maytag part number is 11001182, board flipper sensor. My Skybox had been down for two years and now works again!
Mar 27, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox Beverage Dispenser/Refrigerator
TroJo, Try PartSelect.com for Skybox parts. I ordered a part on Monday night and installed it on Wednesday night. The parts are not that hard to find. Appliance repair services can replace your compressor or add freon. Be sure you have plenty of ventilation behind your machine. Jonmon
Mar 23, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
610 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
