Question about Kenwood KAC-9152D Car Audio Amplifier
Music not playing from subs
I dont kno what could be wrong, i hooked up different subs the music cut out... i thought it was because i didnt have a capacitor but they wouldnt come back on....ive hooked up a entirely differnt system being cd player, amp, subs, and even changed rca bout to give up........please help
  • howdoiuhhhh Jul 09, 2008
    hell yea bought me a multimeter, and the power was 4 volts the problem was at the fuse block right off the battery........... anyways THANKS MUCH
  • 631 Answers
Do this for the sub amp...
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Jul 05, 2008
Static when playing music and speakers pop
try to clean the volume control with contact cleaners
May 05, 2010 | RCA RT2760 System
Sub not working
there might be transistors that went bad
May 01, 2010 | Kicker 06ZX750.1 Car Audio Amplifier
Amp goes dirctly into protect
ok well it could be two thing wrong your amp dont have a good ground or your amp is a smar amp and your subs must have to be hooked up so the power from the amp cn go to the subs so the amp can see that you do have subs hooked up to take it out of protect o and look at your fuses to to smal or to big will send it to protect to
May 19, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Audiobahn 15s smell and stoped working
google "subwoofer wiring diagram" that will help you out, put in how many subs, DVC, SVC, and the ohms of the subs.....good stuff to know b4 hooking up a system....hopefully you didnt fry your subs or amp.....let me kno.....
Mar 14, 2009 | DHD NTX-6612 Car Subwoofer
Amp or Stereo Cutting out...
I agree with what you think it might be. I really think its the deck that is bad and you should be able to take it back for a new one. Have you tried unplugging the RCA cables to the amp to see if that stops it? That would tell you if the amp is backfeeding or doing something weird.
Mar 02, 2009 | Dual Car Audio & Video
I bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
Aug 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
What could be wrong???????
The only thing left is the wiring, and or connectors from what you are describing.
You can try another amp and another set of speakers on the same wiring to see if they work. If not, the only thing you have left is the wiring and connectors (if connectors are used).
This suggestion is valid providing that substitution equipment is not defective.
Jerry G.
May 01, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Sep 11, 2007 | MTX RT202 Car Audio Amplifier
Kenwood KAC-9152D Car Audio Amplifier Logo
75 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
