Question about Toshiba Satellite A135-S2276 Notebook
Toshiba laptop key came off
I need to put back on but I don"t see how. I see post - which goes down and selects the proper key, and 4 small pin like posts - two with little hooks and two with round circles, all in a sort of square configuration ?
    Genius:
  • 2,028 Answers
There's no type of guide for this. The best thing you can do is take another key off and see how it goes back on. Be carefull and try to take the key off leaving the retainer.
Posted on Jul 03, 2008
My toshiba laptop is completly locked out and i need to get in thead how can i unlock me laptop?
hi...
its bios password.you have to open the laptop.to open laptop see in youtube how to open.just put your model number of laptop in youtube saying how to remove mainboard...after you open ur laptop you will see battery in it and a small jumper with battery trun ur laptop on and remove that small jumper and put it back ... there will be 3 pins..you will remove jumper from 1-2 so put it back in 2-3 ..the laptop will shut down..then put the jumper back to 1-2 ..and trun ur laptop on inshallah the password will go...
hope it solve ur problem...
Jan 19, 2014 | Toshiba Computers & Internet
Check system then press f1 key
Try this:
Instructions
    • 1
      Insert the Toshiba A60 recovery disc into the CD/DVD-ROM drive.
    • 2
      Power off the Toshiba (with the recovery disc still loaded inside the optical drive).
    • 3 Hold down the "F12" key, at the same time hit the "Power" button to turn the system back on. You don't have to hold down the Power button, but keep holding the F12 key.
    • 4
      Release the "F12" key when the" In Touch with Tomorrow TOSHIBA" screen is displayed. This will open up the BIOS.
    • 5
      Change the boot order by using the arrow keys to select "CD/DVD ROM" icon in the menu. The Toshiba will now boot from the recovery disc and restore the system. Follow any additional on-screen instructions.
Aug 19, 2012 | Toshiba Satellite A60-S166 Notebook
What if disk drive does not open during system says reboot and selesct proper booot device
Sounds like you may have a CD/DVD in the drive that is stuck and/or not inserted properly. There should be a small, pin-size opening on the front plate of the CD drive. Find a large paper clip, bend out one end of it then insert into the pin-hole. Push it until the drive pops open.
Aug 10, 2012 | Toshiba Satellite P755-s5320
Toshiba Satellite L655D s5050 when turn on power comes up charging light comes up disc drive works but nothing on screen and the vga port didnt work as well
Nothing on internal monitor screen, and nothing on external VGA monitor?
You have a bad graphics chipset. This = replace motherboard.
Before you rush out to buy a motherboard, let's review on how to properly connect a VGA monitor to that Toshiba Satellite L655D-s5050;
1) Laptop OFF, monitor OFF, connect the VGA monitor to the RGB port on the side of the laptop.
2) By DEFAULT, the display should show on the external VGA monitor.
DOES NOT mean it will.
No display on external VGA monitor?
Press, and hold down on the Fn key, tap ONCE on the F5 key.
(O-N-C-E. NOT repeatedly!)
Still no?
Hold the Fn key down again, and tap once more on the F5 key.
Still no?
Hold the Power On button down until the laptop turns off.
Remove the VGA cable, and all external cables/devices.
Close the laptop, turn it over on the table in front of you.
(I recommend a soft, static free cloth on the table, to prevent scratching the table, and laptop)
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Remove the Memory Compartment Cover.
(Middle of laptop on bottom. Rectangular cover with three Philips head screws)
Make SURE your body is free from Static, and remove all ram memory modules. (Slot A, and Slot B, IF, there are two ram memory modules)
Handle the ram memory module by the BODY. The body is everywhere, but the gold plated contact pins on the bottom.
The body is coated with a see-through protective plastic.
Refrain from touching the gold plated contact pins.
Clean EACH gold plated contact pin with a pencil eraser.
BOTH sides.
If using a pencil eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band contact the gold plated contact pins.
Just rub up, and down on each pin.
When finished use air to remove the eraser dust. You can use a can of compressed air for computers if available, or air pressure from your mouth will be sufficient.
Reinstall just one ram memory module, (If you have two), in Slot A.
Make SURE it is in Slot A. The Processor reads Slot A first. If no ram memory module is in Slot A, the laptop will not work.
Put the Memory Compartment Cover back on.
Reinstall the Battery. Turn the laptop over, and open it back up.
Plug the AC adapter (Charger) in.
WAIT 1 minute, turn the laptop on. Still no?
Turn the laptop off, and attach the external VGA monitor again.
Try it. (Don't forget you may have to use the Display Toggle-Over key)
Still no?
I suggest the graphics chipset is bad. Motherboard replacement.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 23, 2012 | Toshiba Satellite L655d-s5050 2.1ghz 3gb...
I GOT A NEW LAPTOP AND WHEN I OPENED IT, A MESSAGE APPEARS STATING " RECOVERY OF FACTORY DEFAULT SOFTARE" AND IT JUST STAYS THERE NOTHING HAPPENS CAN U HELP ME WITH MY PROBLEM ???
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
May 26, 2011 | Toshiba Satellite A665 Notebook
Don't know BIOS password
Here's how to reset password
Resetting a Toshiba BIOS Password KeyDisk will reset the BIOS password on Toshiba laptops.
Older Toshiba laptops can be convinced to boot without their power-on BIOS password by attaching a dongle to the parallel port which crosses a number of the pins. The pin out is:
Pins 1-5-10 2-11 3-17 4-12 6-16 7-13 8-14 9-15 Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
Jul 25, 2010 | Toshiba Satellite A105 Notebook
How do you put a key back on a laptop keyboard. It is a plastic key with a sissor latch and a small diameter metal rod bent into a wide square bottomed U. My daughter pulled it off can't get it to latch...
You have to get the sissor part back on first,
there are 4 small i-holes in a square on the keyboard,,
on the sissor part there is 4 small nubs on each corner, thay clip into the 4 i-holes,,
the key itself just clips down on the sissor part.<---Make sure its lined up b4 pushing
May 16, 2010 | Toshiba Satelite A135-S2286 Notebook
Toshiba a135-s2356 laptop no bios screen on power up
There are 2 ways you can reset your bios2_bing.gif.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery2_bing.gif and plug in2_bing.gif your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
This is a great troubleshooting2_bing.gif step for those of you having POST issues or no POSTing at all. Like other troubleshooting2_bing.gif steps, this will not always work but usually will depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
May 05, 2010 | Toshiba Satellite A135-S2276 Notebook
Removing power password from TOSHIBA LAPTOP L300-2CC
Thanks.
May 03, 2010 | Toshiba Satellite A100-S8111TD Notebook
Describe your RESETEAR BIOS LAPTOP TOSHIBA Problem
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in2_bing.gif your system. Your reset is now complete
This is a great troubleshooting2_bing.gif step for those of you having POST issues or no POSTing at all. Like other troubleshooting steps, this will not always work but usually will depending on the problem.
Thanks.
Oct 15, 2009 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
