Plastic headlights can i use lime away to clean my headlights?
    Novelist:
  • 177 Answers
No find a plastic polish @ a local automotive store!
Posted on Jul 07, 2008
Can I put a 40x microscope lens into an ultrasonic cleaner? My boss said the microscope guy told her the urine from our samples gets on the lens and "warps" it. How can that happen and I think it is just...
Soak in a product like lime away first. Glass lenses cant warp without heat. Plastic even crystal type can absorb minerals. Ultrasonic can help clean all of them. The lime away will remove almost all trace minerals, lye or powdered drain cleaner will remove organics. Gool luck let me know how these ideas woek for you.
Nov 29, 2017 | Science & Laboratory
Whirlpool dishwasher model GU2275XTVQ1 cleans poorly on top only
Check your hose, pump and all water lines for lime scale build up. Sometimes if you dont use some kind of lime away product every few months your machine will/can get lime scale build up from hard water causing it to not properly dispense the water through out your machine. You can also try to run a load with no dishes and no soap but put just lime away in your machine. It might just clear any clogs you might have or starting to get.
Jan 27, 2013 | Whirlpool Gold GU2275XTVy Dishwasher
My LG top Loader WF-T9235TP is 2 years old in between the inner and outer drum I have a greyish brownish build up that comes into my clothes, i have tried the drum clean, vinegar, washing machine cleaner,...
the best way to clean your washer is use a pruduct called lime away on the hottest wash put the lime away into the machine fill up with hot water let it wash for 15 mins leave it to soak for a hour empty out and put on a nomal wash with no cloths let it finnish and check it might take a few goes but its the best stuff for the job if you cannot get lime away b&q does a remove lime for washers but not as good lime away comes from the usa i get it from the comisary at the usa base
Nov 26, 2011 | Washing Machines
Soap isn't rinsing clean. It looks like there's a
Hi this is not salt or detergent. This is likely to be lime/calcium. Go to home depot or a similar hardware store and buy a gallon of lime-away or similar product. Start the dishwasher on pots and pans then once the dishwasher has filled with water open the door and pour around 2 cups of lime-away in. Let the entire cycle run and then repeat this once a week until the problem clears up. Once the problem clears up repeat this once every 3 months to prevent the problem returning. If you have any other questions please feel free to comment. Mike
Feb 14, 2010 | Maytag MDB9600A Jetclean II Built-in...
I NEED TO KNOW HOW TO GET BATTRY ACID OUT OF TV/RADIO
LIME AWAY OR CLR does a great job cleaning these connections and the plastic . use a q tip and leave it on the connection for a few mins to let it work , then wipe off and dab a little clean water on the connection to rinse the lime away -away good luck
Nov 04, 2009 | GPX TVWB534SP 5 in. Portable Television
Side by side ice maker tray has water stains
Use Lime Away. It helped with mine as the white spots were due to lime in the water. Be careful not to get the lime away on your marble, stainless steel sink, etc. as it will cause discoloration. I found out the hard way. Good luck.
Mar 31, 2009 | KitchenAid Superba Architect KSCS25INSS...
Removal of headlight housing to replace lowbeam bulb.
found this online- haven't tried yet though--
How do you change a headlight bulb on a 2003 Toyota Celica GT? Under the plastic covering the headlight there is a lot of fog and condensation and I want to clean it off, so how do I take off the plastic that covers the headlight?
  • 9 months ago
Seem to be seal is wear off
already on the front cover
The way to open that
1. There is four screws at the back of
the headlights and unscrew them
2. Pull the headlight and dry it
by wiping or heat of the sun or
anything that can release the fog
3. Buy silicon and seal the headlight
gap with silicon and let it dry for a hour
This will help kept away fog
and condensation for sure
Aug 24, 2008 | 2003 Toyota Celica
Headlights are foggy inside how do i clean them
the fogginess is caused by oxidation on the outside. normal wear and tear.
This is what i did on my honda civic 1996- bought three sand paper 600-1500 and 2000. Bought plastic shine from autozone and some plastic gloves.
1) I cleaned it with diluted soap to get all the dirt out. Use soft cotton cloth to do this.
2) get some clean water and dip sand paper(600) and start sanding the headlight. sanding should be done in the same direction throughout. I used horizontal strokes. Don't let the sandpaper dry out.
3) clean it out with water so all the sand particles from the sanding is cleaned out.
4) start with the next grade sand paper and repeat the process till you are satisfied and the fogginess is gone.
5) clean it thoroughly with water and let it dry fully.
6) put in gloves and rub plastic shine all over the headlight and leave it to dry. Make sure it does touch the paint!! you can mask the sides to avoid that.
7) clean it with soft cotton or polishing cloth. It really works!!!
Also, stay away from direct sun while doing this. Having the hood up is helpful.
Lis
Jul 12, 2008 | 2001 Mercury Grand Marquis
The hinge to the door is very stiff with limescale
clean off the lime scale with a lime away product, be very careful Limeaway is an acid. READ the products directions.
Jun 05, 2008 | Siemens Washing Machines
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
