Question about Symbol LS1908T Wired Handheld Barcode Scanner
Symbol ls1908 USB scanner scan, but no field input to computer
Why can't my Symbol LS1908T scanner transfer data that it reads? For instance I will scan a barcode and the field that the cursor is on remains blank on the computer. This is true for notepad as well as quickbooks.
Thanks for your help
kb2iqs@hotmail.com
  • Anonymous Jul 08, 2008
    I did not get the scanner with a manual. Where can I find a manual for the Symbol LS1908T scanner?
Why does Symbol LS 4000i put an X before data?
Someone mistakenly added a character before the data during the configuration.You may try factory default setting using configuration barcode.
Jul 07, 2014 | Symbol LS 4000i Handheld
Tip
How do I read Barcodes in Microsoft Excel?
<p>Bar code symbols are composed of a number of adjacent bars and spaces of different widths of pre-defined codes. A barcode scanner is used to read or scan the bar code symbol to represent the information to decode. Once the symbol is scanned by a handheld reading device or another, can then be used by computer software to track inventory and perform other functions. Microsoft Excel is a computer application that use bar code information can make the business perform. <br /> <p><br /> <p>1. Insert bar code scanner to your computer using the "interface cable keyboard wedge". The keyboard wedge interface cable looks like the printer port of your computer, and differs only in that a connection between the scanner bar code and serial number of your computer or USB port. The cable is provided as a peripheral pattern with hand-held bar code scanners. <br /> <p><br /> <p>2. Open Microsoft Excel on your computer after the bar code scanner connected to your computer. <br /> <p><br /> <p>3. Links on the Excel cell to the bar code to enter and bar code scanning to load it into Microsoft Excel. <br /> <p><br /> <p>4. View the data in Excel file is translated into a vision of the bar code information. <br />
on Jun 26, 2011 | Computers & Internet
I have a Symbol 1908T-1200 which works fine, but I need it to send a line return code after the data. How do I accomplish this.
Hallo Jason,
yes, this can be done automatically, just by scanning three programming barcodes. Please follow the steps in the attached document.
https://docs.symbol.com/attachments/ADC-01244.doc
Oct 11, 2010 | Symbol LS1908T Wired Handheld Barcode...
Symbol ls2000 hand scanner won't read barcodes. The laser lights up and it beeps when I scan but it takes in no data. I have tried the sets all defaults programming barcodes but all it does us make a...
If the scanner beeps just once after a scan, than he recognize the barcode and sends the data to the computer. If you dont receive any data, you are waiting for them on wrong interface. Data from USB or KeyboardWedge do come to Notepad/Word etc. The data from Serial RS232 Connection can you see only in Hyperterminal or similar application.
Sep 26, 2010 | Symbol LS2000 (ls-2000-i000ag) Handheld
I have Symbol scanner(1908T-I300) USB Type. It can read bar code but can't move next cell or line when testing Excell or Note Pad.
In the barcode is usually no order, which would say to the computer to change to new line or cell.
You would need to add an suffix to the barcode, check the manual for the procedure or use the following tutorial http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12295&sliceId=SAL_Public&dialogID=189588227&stateId=1%200%20189576907
Aug 16, 2010 | Symbol LS1908T Wired Handheld Barcode...
My Symbol LS4278 will not transfer data to the computer. I have the PS2 cable and added a PS2 to USB. I get a beep as if the barcode is read, but it's not transferring the data to the program.
Be sure to use a full PS2 to USB adapter not just the plug adapter. The one to use has the cable and a small encoder box in the middle, usually for keyboard and mouse together. We have seen some of the cheaper adapters not pass the proper voltages to the scanner for a good read. The ones we suggest to our customers is made by Belkin part # F5U119VE1SN
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 30, 2009 | Symbol LS 4278 Barcode Scanner
Hello! I have a problem with scanning bar codes by ls2208 scanner. This device uses rs232 serial port, and when I try to read some bar code, the scanner is reading, but there is no number in notepad. How...
The scanner is sending the data to the serial port. You need an application to pull that data in off of the COM port. You can test using HyperTerminal. The scanner defaults to 9600 baud, 8 data bits, 1 stop bit, no parity and no hardware or software handshaking. Point HyperTerminal to the correct COM port (most likely COM1) and set it to the settings I just listed. When you scan you should see the data show up in the window.
If you want the data to go into Notepad or any other program expecting keyboard strokes I would recommend the Motorola (formerly Symbol) USB cable CBA-U01-S07ZAR or the CBA-K01-S07PAR keyboard wedge cable.
Jul 13, 2009 | Symbol LS 2208 Barcode Scanner - P/N...
Anything is being transfers to PC
Do you test with the notepad of Windows ?
Did you scan the appropriate barcode ?
Sep 02, 2008 | Symbol LS1908T Wired Handheld Barcode...
Symbol Spark LS 1004 Problem
What barcode scanner do you have? USB, SERIAL or ps2.
by the way. the old computer is it like NCR, SIEMENS or IBM because then you need to re-program your scanner.
i found a manual where you can set your pc type with barcode scanner. be careful not to scan reset defaults. because you will loose your settings.
look at chapter 4-9 and 4-10
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3380601bpdf&sliceId=&dialogID=33708056&stateId=0%200%205522749
If you don't know ask me. we don't want to lose al the settings.
good luck
Nov 29, 2007 | Symbol Spark LS 1004
Symbol LS1908T Wired Handheld Barcode Scanner Logo
650 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
