Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Settings i'm trying to find settings on my computer..
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    Your computer has all kinds of settings. You can set the resolution, the sound, the music, the brightness. You can even set it on fire. But, what settings are you looking for?
If you are going to find settings.
1. Click "Start" on the bottom left of the screen.
2. Click Control Panel
3. Now you should find settings.
Posted on Jul 26, 2008
My ip adress says unavailable
Sounds like the computer you're trying to connect to your wi-fi router is set up with a static IP address that is being reserved by your router for DHCP. To resolve, make sure your router has "DHCP" (dynamic host configuration protocol) turned on. Make sure the computer you're trying to connect to your router is set up to allow the DHCP server in your router to set the computer's IP address and DNS server address. You can find instructions to enable DHCP in your router's user manual or by searching online. You can find instructions for setting your computer's wireless adapter to allow the DHCP server in your router to set the computer's IP and DNS addresses here:
http://www2.wolfson.cam.ac.uk/files/IT/Settings_for_DHCP_for_Windows.pdf
Jan 07, 2014 | Computers & Internet
Tip
Trying to connect computer to LCD TV and get no signal?
Hi.
If you are trying to connect computer to LCD TV and get no signal, as a first thing do the following:
Double check cable and connection. If possible test different connections. Try using VGA, DVI or AV, depending on availability on computer and TV.
Ensure that Video drivers on computer are properly installed, and that the video adapter is working properly.
If you are using a laptop, ensure that you do not need to use a function button to enable the external display, this is pretty common on laptops.
If you are using a desktop, go to display properties, find the windows where you get the picture of two monitors, and ensure that both monitors are enabled.
On Vista try also using the 'Identify Monitor' button on Top. It is located on same properties panel as the two monitor, the main Display Property windows. From the same window you can also modify display resolution, as explained later.
If still no luck, then it may be a problem of synchronization between TV and computer, in that case try the following.
  1. Turn off TV.
  2. Disconnect TV power cord.
  3. Restart computer.
  4. With Computer already on, plug back and restart TV.
....If that does not work.
On computer, go to display properties.
First try changing computer resolution. The TV max resolution may not be available on computer. In that case try lowering down to the smallest 16:9 resolution available on computer graphic settings (usually LCD TVs are 16:9), and if that does not work, set resolution to 800x600, just to test (picture proportion will be distorted, or you get squared box on a 16:9 TV).
If that does not work, open Display Properties. In Display Properties access Advanced, and then Monitor settings (XP). On Vista choose Personalize in control panel, then Display Settings, and go straight to Monitor Settings, in there again go to Advanced.
Under the advanced monitor settings you will find a tab called monitor, in there you find the monitor frequency. Try setting this to 50Hz, if that does not work try 100 HZ, that is the output frequency of your TV. If you get unsupported frequency, revert value to normal.
on Jan 17, 2010 | Televison & Video
The speakers wont work when i plug them into the computer so what do i do ?
Try connecting the speakers to another computer, to see if they work at all.
Try connecting a different set of speakers to your computer, to see if your computer is creating sound (not "muted" ???).
May 21, 2011 | Harman Kardon HK595 Computer Speakers
Computer can't find router
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Apr 18, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I tried to set up a password with my wireless 2350 broadband router and now its saying that the settings don't match my network.. i need help
Change your wireless settings on your computer. Use the router's password. that way you will be able to gain access to your router. when you changed the settings on your router it does not automatically update your computer's connection settings. you have to manually change it. try right clicking the icon for your wireless on your computer. go to the connection settings and add a password that corresponds to the settings you changed on your router.
Mar 11, 2010 | Dell Wireless 2350 Router
I tried to set up WAP security and ended up making it so none of the computers can get on the internet.
To set up security, you have to use a computer that is connected to the router with an ethernet cable. If you try to use a wireless computer to change the settings, it will lose the connection.
You will have to connect one of your computers to the router with an ethernet cable to be able to change the router's settings. Once you have logged into the router that way, write down the security key and input that key on all of the wireless computers when connecting.
Nov 19, 2009 | Dell Computers & Internet
Computer won't use sleep mode anymore
Go to Advance Power Settings.
Set hard drive to turn off a minute or 2 before sleep.
Set Hybrid and Hibernate modes to "Off"
Under USB settings select "Disable"
Under Multimedia select "Allow ....." also setup your screen to turn off ( pick how long monitor will stay on. you can also try going into the bios and setting it to default. save and reboot. let me know if this helps.
Nov 13, 2009 | HP Pavilion S3420F Slimline Desktop PC
Bios setting problem?
Optimal Defaults and Fail Safe Defaults are two different sets of values. If you set one after the other the second would have replaced the first. Try setting back to optimal again.
If you still see errors relating to the Ethernet adapter find the Ethernet adapter in your BIOS settings and set it to Auto. If you still see errors try all of the available Ethernet settings.
Hope this helps you get your computer running again.
Oct 01, 2009 | Computers & Internet
I need to set the distributor timing
These vehicles have to have the timing set while hooked up to a diagnostic computer as they are self setting once they have been zeroed with the diag, computer. if you try to set it on your own you will just be fighting the vehicles control module (computer)
May 05, 2009 | 1999 Chevrolet Silverado 1500
The computer wont recognise my mp3
try messing with the usb settings on the mp3 player in settings/ system settings/ USB mode/ for a newer PC try MSC for an Older PC or mac try Mtp and if that dosen't work try auto detect just mess around with it fir a while
Apr 09, 2009 | SanDisk Sansa Fuze MP3 Player
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
