Question about Fuji FinePix S5700 Digital Camera
Pictures are "grainy"
Yesterday the S shutter speed stopped adjusting ... all pictures came out way over exposed. I could adjust this problem by using the S to change the lighting and then shoot the picture using the P. Now for some reason all of my pictures come out grainy even though the view screen shows an almost perfect picture. I use the camera daily to shoot home in my area for the multi-service which are then published. The camera has been great until yesterday.........Help if you can or should I send it back for a replacement?
Thanks so much.
Les
  • Anonymous Nov 06, 2008
    If I adjust any settings manually and then go back to auto mode, my photos are grainy. Not sure how to fix this but it was happening once before and then cleared up, but of course I have no clue how I 'fixed' it. It is very irritating!
  • 623 Answers
This may work, remove the batteries to try to "reset" the camera.
Posted on Nov 12, 2008
Camera exilim ex-s600 will not take pictures outside,pictures turning out white,yet will take pictures inside ok.is this a worthwhile repair
This seems to be a software problem with your camera. Your camera should, if on AUTO mode, automatically expose your photo accurately. Try half pressing the shutter button (used to take pictures) while outside to adjust focus and exposure, then press the button fully to take picture. If your camera cannot adjust to take a properly exposed picture (not bright white), then it is possible that the shutter speed is stuck on a too high speed, outside daytime shutter speed should be fast (1/1000 sec). Or if your shutter speed adjust accurately, it could be the aperture if the aperture is not small enough for daylight shooting. This is likely a software problem. Try adjusting your settings manually and see if the picture turns out!
Sep 10, 2011 | Casio EXILIM Card EX-S770 Digital Camera
Really Grainy low quality pictures with my new camera.
Try shooting with ISO value of 200 or less; or set to "Auto".
If you're missing the manual, you can get it in English, here. Page 76 briefly discusses ISO settings. This camera can select an ISO as high as 1600. ISO has to do with graininess of film - the higher the number - the more grainy the images. Higher ISOs are selected when light levels are low and no flash is used or is usable (such as when the subject is too distant). Some photographers use higher ISO settings with high shutter speeds to stop fast moving objects (like wheels on a race car). The grainier the film, the quicker it captures light. Fime grained film takes longer to capture light.
Generally, pictures taken outdoors in sunshine look best when ISO is 100 or less. 100 is a good choice for well lit indoor pictures, too; but may be better with an ISO of 200. ISO works like this:
If a picture can be properly exposed with an ISO of 100 in 1/15 sec, it would require only 1/30 sec at ISO 200, or 1/60 sec at ISO 400. When you double the ISO value, the exposure times are halved. What's the big deal about 1/15sec, 1/30 or 1/60 sec you might ask? Easy! the picture will probably be blurry at 1/15 and even 1/30 sec exposure time, due to the camera recording even the slightest movement of your hands. You'll need to supply a tripod or do something else (such as increase the size of the opening of the aperture or f-stop) to get a properly exposed image.
I hope this helped - if it isn't an ISO problem - let me know. Good luck!
Dec 10, 2010 | Canon PowerShot SX30 IS Digital Camera
Polaroid i1035: Bad quality pictures, appear grainy and fuzzy
The grainy effect has to do do with the ISO setting, try adjusting that. A higher ISO is generally better for darker conditions. I have noticed that this camera frequently takes grainy images.
Jan 29, 2009 | Polaroid i1035 Digital Camera
Poor quality pictures.
You need to adjust the shutter speed-if there is a tv setting on it-use it to adjust the shutter speed to something like not 1/4 of a second but 1/1000 of a second what this is how much light is allowed to come in and the longer the shutter speed the worst the picture will be
Jan 25, 2009 | Fuji FinePix S8000fd Digital Camera
I need to change settings for samsung L201
You can reset all settings to the original defaults by following the instructions on page 74 of the manual:
http://downloadcenter.samsung.com/content/UM/200810/20081006113527265_L200_English.pdf
Page 41 explains the ISO settings, which seem to be straight forward to me.. The larger the ISO number, the greater sensitivity to light, so the faster shutter speeds you can use (the larger the shutter speed number the faster it is - ie 125 is faster than 60). The drawback of the ISO is that more noise will appear in the images (dark areas look grainy)
To avoid blur, either take your shots on a tripod or ensure that the shutter speed is at least 1/60 of a second
Dec 28, 2008 | Samsung L200 Digital Camera
Very grainy pictures indoors at night
If you can adjust the ISO sensitivity to a lower number then the graininess will be reduced.
However, by reducing the ISO, you will need a slower shutter speed and a larger aperture. A tripod, table or other support may be necessary.
The "noise reduction" setting on the camera can also be adjusted a step up.
Taking pictures at full resolution and fine compression will also help.
Overall, at least try lowering the ISO, and using the flash brighter.
Jul 01, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Grainy pictures
grainy pictures are possibly casued by a very high ISO (sensativity) setting, you should be on 100 or lower for best normal shots. Higher settings are for low light and custom shooting in strange lighting or aperature/shutter speeds. Try full auto setting.
Mar 03, 2008 | Canon PowerShot S3 IS Digital Camera
Grainy Photos using Natural Light
Sounds like the 'shutter speed' as it was called is too fast.
Jun 23, 2017 | Nikon Cameras
Sport mode settings
Sports photography requires two things: Long zoom, fast shutter speed, and lots of light. Hey! that's three. Ok. So three things.
With your S3IS, you need to use a fast shutter speed to freeze the action (pitchers' arms go pretty fast!) - I suggest trying at 1/500, then 1/1000 second settings. Your camera won't select that automatically, so set the dial to shutter priority, and select that shutter speed. Then, with that shutter speed, you'll likely need to adjust other facets of your exposure to capture enough light. Zoomed in, you'll have an aperture (f/stop) of f/3.5 - or higher (remember: for f/stop, higher numbers = smaller iris, lower number = wider open iris). With your fast shutter speed, you're now fighting for light, so you need the smallest f/stop number you can get - which will be f/2.7 if you're zoomed out, or f/3.5 if you're zoomed in. If at 1/500 shutter and f/3.5 you still have a dark photo, try bumping your ISO setting up to 200 or 400. If you choose 400 or higher you will have a grainy picture. And will need to use a software noise reduction to clean it up.
With the suggestions above, you'll likely not be blurry, but you may be dark. If this is on a bright sunny day, you'll be fine. If this is at a ball park under the lights you may have different results.
Hope this helps...
Oct 17, 2007 | Canon PowerShot S3 IS Digital Camera
Having problems with the flash\ blurred and grainy images
You should not use the flash for these shots (unless you connect a powerful external flash), it won't help you at this distance. You should use the shutter priority mode and experiment with shutter speed (no flash) to get the best result - for sports action it should probably be faster than 1/100 sec. If the light is too low you may use higher ISO setting - 200 or 400 (though higher ISO will result in grainier images, it may be your only option for blur-free photos).
Sep 07, 2005 | Olympus Camedia C-2100 Ultra Zoom Digital...
Fuji FinePix S5700 Digital Camera Logo
134 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
