Question about Toshiba Satellite P105-S6207 Laptop
IPV6 connection says limited when it should say local?
A couple months ago, my ipv6 connection was doing just fine, until a couple weeks ago it said limited i could not get onto online games that i downloaded, like Counter-Strike Source etc etc. My pc didnt even connect to limewire. can you help me? It would be greatly appreciated on my behalf if you did.
Edi.
  • 375 Answers
You are extremely unlikely to be using ipv6 - A 2008 study by Google indicated that penetration was still less than one percent of Internet-enabled hosts in any country. The leaders were Russia (0.76%), France (0.65%), Ukraine (0.64%), Norway (0.49%), and the United States (0.45%).
So unless you have a private network to connect you to all these other IPV6 users, you are using IPV4 like the rest of us...
Posted on Jul 25, 2009
How to disable ipv6?
You can still use IPV4 instead.
IPV6 will be rejected anyway, so you don't need to turn it off.
Apr 30, 2014 | NetGear N600 Wireless Dual Band Router
GETCE6B1, Internet Protocol Version 6 Not Available
The 'IPV4' (Internet Protocol Version 4) was designed for a world with 4 billion unique devices (desktops, laptops, netbooks, iPod Touch/Phone, IP-TV, cell-phones, et cetera).
That limit is being reached!
The newer 'IPV6' (Internet Protocol Version 6) was designed to give a unique IPV6 address for EVERY SQUARE INCH of surface of our planet.
So, if your computer is "talking" to an IPV6 device (router or modem), you should _NOT_ get "IPV6 not available". However, if your computer is "talking" using IPV4, you probably _WILL_ get the IPV6 not available" message.
No big deal. If your computer cannot "talk" IPV6, then it should "talk" IPV4.
Jan 18, 2011 | Sylvania G-Netbook
When my computer wakes up it sometimes gives me an error that there is an IP address conflict and will not connect to internet. I have 1 oe 2 laptops and 2 direct tv recoders attached.
Hi, Lets we disable your IPV6 to IP V4 only .
Do you know how to disable IPv6 in Windows Vistair?t=homnetwirneta-20&l=ur2&o=1? Do you know it's enabled by default? It's pretty simple actually! As I know some might even want to uninstall IPv6, but you won't be able to do it as this is built-in feature in Vista kernel. Although IPv6 is developed with better security and aimed to overcome the shortage of IPv4 addresses, but there are several reasons why people still wish to disable this feature:
- Totally not going to use this IPv6 feature as it's not that popular yet and don't know how to use it
- Disabling this IPv6 feature can conserve Windows' CPU and memory resources
- Better network performance with disabled IPv6 feature
Somehow there are still some disadvantages for disabling this IPv6 feature: you will not be able to use Windows Meeting Space or any application that relies on the Windows Peer-to-Peer Networking platform or the Teredo transition technology. If you are not going to be affected by those disadvantages, let's proceed to do it:
1) Go to Start and right click on Network and then click Properties.
2) Network and Sharing Center window will appear, after that click Manage network connections.
3) Network Connections window will appears. Here you can right click on the network card that you wish to disable IPv6 and click Properties.
4) In the Local Area Connection Properties window, untick Internet Protocol Version 6 (TCP/IPv6) and click OK.
Note: This method disables IPv6 on your LAN interfaces and connections, but does not disable IPv6 on tunnel interfaces or the IPv6 loopback interface. You need to make change in Windows registry in order to disable the IPv6 on tunnel interface. You can stop here if don't feel like working with Windows registry. If not, proceed with Step 5.
5) Type regedit in command prompt in order to launch registry editor.
6) Registry editor will appear, proceed to locate following registry item:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip6\Parameters\DisabledComponents
Note: If the DisabledComponents item is unavailable, you must create it:
a) In the Edit menu, go to New, and then click DWORD (32-bit) Value.
b) Type DisabledComponents, and then press ENTER.
7) Double-click DisabledComponents, set the value as 0xffffffff (hexadecimal value) (just type ffffffff) to disable IPv6 on LAN interfaces, connections, and tunnel interfaces except the IPv6 loopback interface, finally click OK.
8) You must restart the computer for this registry value to take effect.
Dec 19, 2010 | Belkin Wireless Surf Router (F7D2301)
With Ethernet connection, network and sharing center reports 'unidentified'. Only on ethernet, wifi is fine. How can I fix this?
Try BOTH or either steps
1.
- Press Windows key and "r" key at the same time to open RUN box
- type ncpa.cpl
- right click on Local Area connection, click Diagnose
- follow the prompts
2.
- type ncpa.cpl
- right click on Local Area connection, then properties
- on the list with check boxes, uncheck IPv4 & IPv6
click OK, then click YES
- right click again on Local Area conenction, properties
- put the check back on IPv4 & IPv6, it will check back all the rest
- click OK
- wait for a few secs.. it will show "identifying", then you'll be prompted to select is as a HOME or Public network, select HOME
Sep 08, 2010 | Computers & Internet
I have a wrt54g and the IPV6 CONNECTIVITY IS ALSO AT LIMITED IS THERE A WAY TO FIX THIS RUNNING VISTA HOME
mertbren
In regards to IPV6 support this is a future option and is not used yet. However support has been added to the newer routers and operating systems so that when the Internet moves to IPV6 then support is already in the hardware so you do have to buy new hardware.
So if you are having network issues this would not be where your problem is.
Let me know what issues you are having and I can see what we can do to address them.
Issken
http://www.fixya.com/users/issken
May 20, 2010 | Linksys Wireless-G WRT54G Router
Ipv6 no connection
thomasrob184
In regards to your question aboout IPV6 this is not standard that is supported yet. IPV6 is s future technology that his been added so that when this becomes a standard your current hardware will work with it.
So if you are having network trouble it should not be related to IPV6. If you can let me know some more about your problem I can see what I can do to address your issue.
Issken
May 02, 2010 | Gateway (SOLO200ETHERNET) Network Adapter
What is ... '' Teredo Tunneling Pseudo-Interface , something to do with IPv6 as part of networking ??
Teredo is an IPv6 transition technology that provides address assignment and host-to-host automatic tunneling for unicast IPv6 traffic when IPv6/IPv4 hosts are located behind one or multiple IPv4 network address translators (NATs). To traverse IPv4 NATs, IPv6 packets are sent as IPv4-based User Datagram Protocol (UDP) messages. This article provides an overview of Teredo—including Teredo addresses and packet structures—and detailed explanations of how communication is initiated between Teredo clients, Teredo host-specific relays, and IPv6-only hosts using the IPv4 Internet, the IPv6 Internet, Teredo servers, and Teredo relays.
more at http://technet.microsoft.com/en-us/network/cc917486.aspx
Dec 31, 2009 | Computers & Internet
After replacing Cable Modem, D-Link DI-524 Wireless will not work
Did you call Comcast and give them the new MAC address of the Motorola SB5101 SURFboard cable modem? I'm surpised it works at all without doing this first. This is the hardware address of your modem so the world can see you, no one in the world has the same MAC address, they are all different. It's on a sticker on the modem.
May 28, 2009 | D-Link AirPlus DI-524 Wireless Router
Open Questions:
See all Toshiba Satellite P105-S6207 Laptop Questions
Toshiba Satellite P105-S6207 Laptop Logo
403 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
