Question about Epson Stylus 830U InkJet Photo Printer
Really bad clunking sounds while printing
The alignment of the heads is way out and i can't seem to get them back to normal. When i print a page it comes out blurry, and i get terrible clunking sounds maybe from the little gear cogs
  • 353 Answers
The commonest cause of blurry print is oscillation of the print head running along the track. This is usually due to contamination of the grease by dust etc. Wipe the track clean and try a print. If the blur has gone, you've found that problem - but you will now need to re-lubricate the track. A light lithium grease is ideal.
If the blur has not gone, the clunking noises might or might not be associated. You now need to take off the printer top cover to have a look at what is going on. To help you with this, download the Service Manual from:
http://www.mediafire.com/?m6ouftizois
Report back what you find.
Posted on Feb 01, 2009
Installed new ink. it says out of alenment
Dennis: According to an old FixYa.com, urbanhookupz said: "You need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
now try and print it should solve the problem.
if it does not prompt you to do a test page
Aligning the Print Head
This operation must be carried out when using the printer for the first time.
Aligning the
Print Head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic Print Head alignment only.
?? Ensure that the Inner Cover is closed.
?? The Print Head can also be aligned from the printer itself.
1.With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2. Hold down the RESUME/CANCEL button until the POWER lamp flashes four
times.
1 With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 28.
3 Print the pattern.
(1) Click the Maintenance tab.
(2) Click Print Head Alignment."
May 26, 2015 | Canon MX340 AllInOne InkJet Printer
Manteinance program run automatically every time i try to print something
Its not maintenance programme, its print head alignment page.Once print heads are aligned successfully, you wont get this page.
Reason: One or more print head nozzles are not firing/blocked/dried up the align page will not prints properly to read result printer unable to align P.heads. You can observe the print quality, based on that replace/clean the particular print head(s) and check. Verify that each line it will read & marked as a "right tick". If its marks like "X" ensure that align page not successful.
If you are confused better replace all(four) print heads, to get out of this issue peacefully.But ensure that before replacing the print heads,all cartridge ink level should be more then 50%.
Nov 28, 2012 | HP DesignJet 110 Plus NR InkJet Printer
When printing a page the main headings of the page comes out in focus and clear. However the information following the headings seemed to be double printed over each other, but slightly misaligned causing...
Align completed?.. Take cotton wet cloth( dip cloth in to normal cold water sqeeze it) clean encoder strip left to right once gently..check any markings on it?..do align once again I hope your problem will shortout..
Sep 14, 2011 | HP F4480 All-In-One Printer
I have HP laserjet 1018 printer and it makes noisy sound when it prints. But it prints fine though. What causes making this noise?
The noise is probably due to the print heads aligning and clicking. To try to make this noise a little quieter, clean and align the print heads.
Mar 23, 2011 | HP LaserJet 1018 Printer
I changed the ink cartrige,it keeps saying alignment cancelled and the copy button keeps flashing - when i open it up the ink cartrige wont slide back out it seems stuck.
The printer needs to be aligned and it wasn't done after changing the catridge so it does not want to continue. Have you tried pushing the flashing copy button to print another alignment page? Do you know how to align the printer?
After changing a cartridge the printer wants to print an alignment page to make sure that it prints correctly. Some printers have you print a page and they auto align themselves. Others cue you to print the alignment page which has a picture or other graphics that are in specific places and then it instructs you to insert the alignment page face down and press "ok". The printer scans the alignment page and configures the print heads to set up by the marks. It uses the alignment page as a map of where the print should be on the paper.
Try unplugging the printer from the power supply and wait about 30 seconds. Then plug it back in and turn it on. The display should say "print alignment page". Choose yes or confirm to continue. Your printer will either print the page and align itself, or print the page and tell you to insert it and continue. Either way follow the prompts and complete the alignment process in order to continue printing as normal.
If you are unable to get the printer to reset and start the alignment procedure over again, please advise and I will help you solve this problem.
Nov 06, 2010 | HP PSC 2210 All-In-One InkJet Printer
Printing is offset
you need to run a printer alignment page like you do when you put in new cartridges.
Aligning the
􀁺 Ensure that the Inner Cover is closed.
􀁺 The Print Head can also be aligned from the printer itself.
Feeder.
times.
Feeder.
See “Opening the Printer Properties Dialog Box Directly from the Start Menu” on
page 28.
remember if my answer was of assistance please leave a positive rating and a testimonial.. THanks Good luck
Mar 28, 2010 | Canon Pixma iP3000 All-In-One InkJet...
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Will not print 6BK
Please see the Canon link below, and as Canon links return generic pages, type in "missing black print" (without quotes) or something of that nature. The results will include Reseat/remove printhead, among others. I have reproduced that content for you below, but I would also add that a number of folks have issues with black print cartridges, and it seems this is an issue that is fairly widespread, as one of the results is that your printer may need repair. If you have tried more than one cartridge with the same result, suggest consulting support if you don't think your usage justifies a new print head - especially if you are still under warranty. Page link is:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10444
---------------------From Canon-----------------------
Issue: How do I reseat / remove the print head?
Solution: Reseat MP750 / MP780 print head
Reseat Print Head Reseating the print head is seldomly needed to be done.
  1. Press the Open Button (1) to open the Paper Output Tray (2).
  2. Raise the Scanning Unit until it stops.
    1. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.
    2. The Print Head Holder moves to the middle.
  3. Open the Inner Cover 1.
  4. Open the Inner Cover 2.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  5. Press the ink tank's tab (1), then remove it from the slot (2).
    IMPORTANT:
    Handle ink tanks carefully to avoid staining clothing or the surrounding area.
  6. Lift up the lock lever and take out the print head.
  7. Again, place the print head back in position and press down the lock lever.
  8. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot.
IMPORTANT:
a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
b. If the ink tank is inserted in the wrong slot, perform two head refreshings.
  1. Close the Inner Cover 2.
  2. Close the Inner Cover 1.
  3. Pull the Scanning Unit Lever towards you to close the Scanning Unit.
  4. Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.
Automatically Aligning The Print Head Position:
  1. Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].
  2. Press <Menu> repeatedly until [MAINTENANCE] appears.
  3. Press left or right arrow to select [AUTO HEAD ALIGN].
  4. Press <OK>. The print head position alignment pattern prints.
  5. Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete.
Manually Aligning The Print Head Position:
  1. Load A4- or letter-size plain paper in the paper support or cassette.
  2. Select the paper source with <Feed Switch> button.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Use left or right arrow to select [ALIGN PRINT HEAD].
  5. Press <OK>. A horizontal pattern is printed.
  6. Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
    (1): Bad example (Least solid box)
    (2): Good example (Most solid box)
  7. Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.
    (A): Column
    (0): Select pattern number with most solid image
  8. Press <OK>.
  9. Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].
  10. Press left arrow. A vertical pattern is printed.
  11. Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.
  12. Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.
  13. Press <OK>.
  14. Repeat steps 12 and 13 to adjust column N.
Please post back if you need additional help. Otherwise, thanks for rating FixYa!
May 15, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Lost B&W printing
Hi marc, it sounds like the normal clean has not eliminated the clog you may have in back printhead. I need to know if you refil your own cartridges or not to be specific, but basically you need to remove the black ink cartridge, and clean the printers heads yourself, and right down where cartridge sits wth cotton buds and proper cleaning solution. Wipe the surface of cartridge if it has the printhead attatched (some printers have the printhead on them, some have it on the cartridge. Replace ink, reset black ink level, cancel the alignment for now, go straight to printing. Print a test page and see how it goes.
Jan 26, 2007 | Canon BubbleJet i560 InkJet Printer
Epson Stylus 830U InkJet Photo Printer Logo
160 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
