When I try to install the Print Workshop 2008 I am prompted to place a disc in the drive and the installation disc is already in the drive.
Here is the problem: the disk drive simply isn't reading the disc. Here are some suggestions:
  1. Make sure the side of the disk with the writing is on the TOP.
  2. Take computer to computer specialist. Sometimes disk readers go out for no reason at all.
Posted on Jul 03, 2008
Can Drivers-Utilities reinstall disc be used to stop Endless Loop Start and Repair found root error Registry is Corrupted. Repair Action Registry Roll Back successful.
Doubtful... You'll need to use a OS Install disc to repair System/Registry files. If you have the System Install Disc, put it in your optical drive while your PC is already up and running. When the Auto-Run prompts, allow it to run, but rather than starting a fresh install, select the "Repair" option... It should then scan your system & settings and replace any missing or broken files. However, if your system can't start at all, place the OS Install disc into your optical drive while it has power then shut down your system. Wait 10 seconds and restart. Boot from the CD and then select the "Repair" option as mentioned.
Good Luck on fixing your system :-D
Apr 05, 2015 | Dell Computers & Internet
How do I install print shop 3.5 on Vista Home?
Insert the disc into the DVD drive in your computer. The installation should begin automatically or give a pop-up asking you what you would like to do. Select Run Setup.exe. Note: If the installation does not begin automatically follow these steps: Click on Start. Click on My Computer (Computer on Windows Vista and Windows 7) Right Click on the DVD drive containing The Print Shop 3.5 disc. Left Click on Open. Double Left Click on Setup.exe. The installer will now search your computer to make sure you have the required Windows Updates in order to install The Print Shop 3.5. If it detects that you are missing an update the installer will prompt you to install these now. Once the updates are complete the installer will move to the next step automatically. From here you should follow the on screen prompts to complete the installation.
Feb 12, 2015 | Encore The Print Shop 3. 0 Deluxe for...
Is there a users guide/manual for print workshop 2010
The manual for Master Clips Print Workshop is located on the CD. To access the manual, double click on My Computer then RIGHT click on your CD-ROM drive and choose Explore.
Double click on the Manuals folder. The manual file name is Mcpub.pdf. If you already have an Adobe Acrobat Reader installed on your system you should be able to simply double click on the file and it will launch the Reader and you will then be able to view or print the manual.
If you are not able to open the file you simply need to install the free Adobe Acrobat Reader by double clicking on the Setup.exe file located in the Manuals folder. After the Reader is installed, double click on the Mcpub.pdf file to view or print the manual.
Aug 22, 2010 | ValuSoft Print Workshop 2010 Full Version...
Not able to print from windows 2008 server 64 bit but able to print from xp clients
Install Addtional Print Driver --x64 bit from Printer Properties----require first to download Print driver from vendor website or if you already have this driver on CD, insert disc to CD/DVD ROM while installing
Apr 27, 2009 | HP Color LaserJet 3500 Printer
Wasn't prompted to load image disc print shop pro deluxe 23
just go to control panel, add remove programs, select print shop (change) and select modify it will allow you to change content to hard drive and not cd.
Mar 19, 2009 | Broderbund PrintShop Pro Publisher Deluxe...
Vista doesn't recognize DVD
Your program Print Workshop 2008 is not compatible with Vista. That is why you cannot install it on the PC. Here are the details for the program direct from there website.
Features
  • Format: DVD-Video
  • PC Games Software; for PC
  • Windows XP Compatible
  • Game Genre: Educational/Productivity; Game Sub-Genre: Productivity
  • Minimum Hard Drive Space Required: 700MB; Minimum Processor Speed Required: 400MHz; Minimum RAM Required: 256MB
  • Published by Valusoft
  • ESRB Rating: Everyone
I'm sorry this is not the answer you were probably hoping for. Thank you for stopping by Fixya! Please leave a positive rating if this solution explained the problem.
Mar 15, 2009 | ValuSoft Print Workshop 2008
Installaton Problem
why cant i install this program
Sep 27, 2008 | ValuSoft Print Workshop 2003 for PC
I cannot install Print Workshop 2008. I have tried going to RUN, and installing device updates, but nothing works. Am I out $20. I had a problem with Print Workshop 2004 but at least I could install...
Usually you just put the CD in the drive and it automatically runs. Do you have more than one CD? Sure you're starting with the right one? Once you have the CD in the drive, double click on My Computer, then double click on the Compac Disk drive icons. If that doesn't start it, it will at least display the names of the files on the CD. Look for the Setup program and double click on that. Good luck.
Mar 23, 2008 | Computers & Internet
Valusoft Print Workshop 2008.
Kim....for the people that try to help on this site as well as tech forums or contacting the supplier you will need to be a bit more specific.....what is it that you see...there should be some sort of message. Forgetting that for the moment though you could have one of the following problems...a corrupt cd (meaning bad), incompatible with your operating system (if running an older O/S this is very possible since you are running a newer Value Print Workship), or a missing driver. Your best bet is to go to their website...valuesoft...and check FAQ's. There might be an answer there and if not try to use the support function.
Hope this helps....Tango
Feb 03, 2008 | ValuSoft Print Workshop 2003 for PC
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
