Question about Dryers
F41 Error code, Kenmore Elite Oasis Steam Gas Dryer.
  • 1 more comment
  • Anonymous Jul 04, 2008
    Yes, I have the same problem from the moment I first started to use it!
    Runs for about five minutes then quits with the F41 error code displayed.
  • Anonymous Dec 11, 2008
    I have the same issue... it runs for a few minutes, then stops with error message F41
  • Anonymous Feb 12, 2009
    Same problem. Gas is not the issue. It's the heater.
Kenmore elite gas dryer code F41 What is it and how do I fix it???
Posted on Jul 31, 2008
2 Suggested Answers
SearsTechToo
  • 261 Answers
SOURCE: Kenmore Elite Oasis error code F41
I don't see this code often although I can steer you in a good direction, F41 to F47 is error codes for dual motor problems on oasis.
Posted on Sep 13, 2008
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore elite model #110-67042601 is flashing a AF code
The AF error code for Kenmore Elite Oasis dryers with model numbers 11067032601, 11067042601, W10035200, 11067032600, and 11067042600 indicates that the dryer is experiencing an airflow problem. The Kenmore Elite Oasis owner's manual recommends four troubleshooting solutions to an airflow problem: clean the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Read more: Error Codes on Kenmore Dryers ' eHow.com http://www.ehow.com/list_7192588_error-codes-kenmore-dryers.html#ixzz1MuOgWsZC it is found also on this link above by clicking the link if you have any further questions please message me back and your dryer should be dlinted at least once per year to avoid dryer breakdown you can also see how to dlint your dryer by clicking this tip that I wrote http://www.fixya.com/support/r8732702-prolong_life_dryer I await your reply if you have any further questions Thanks Rick
May 20, 2011 | Kenmore 72982 Gas Dryer
Error code F44 on sears kenmore elite oasis electric dryer.Doesn't seem to be cycling completely.
The F44 error code on this type of dryer indicates a blower motor control board failure. Since it happens only occasionally, then you could have a loose wiring connection or a partial obstruction in the blower housing. Complete details of the troubleshooting for this error code are included in this link of a previous answer: What does the fault code F44 indicate on my Kenmore Elite Oasis dryer?
I recommend that you unplug the dryer and check the wire harness connections if you are confident that you can safely access the internal dryer components. If you find a loose connection, then tightening it or plugging the harness securely into the connection will likely correct this problem.
May 08, 2010 | Kenmore Elite HE4 Electric Dryer
I need the installation manual for a Kenmore Elite Oasis gas dryer. Specifically I need to know what water line attaches to the dryer (for steam), the hot or the cold?
Hello, Here's the link to view the owners manual and exploded view of the parts for your model. Once there, click on the exact model # you have (it's listed on your dryer's data plate) so you get the right one.
http://www.managemylife.com/mmh/owner_manuals/search?query=kenmore+oasis+elite+dryer+7808
Mar 09, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Have a kenmore oasis dryer that stops and reads a code F41 - what does ths code mean?
(F41)
Motor RPS Thermistor Open/Short
F then 41 flashes when the motor rotor position sensor (RPS) thermistor is detected to be open or shorted.
The RPS sensor needs to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 09, 2009 | Kenmore 67082 Electric Dryer
My 18 month old kenmore elite oasis quiet pak 2 gas dryer smells as if there were a fire in it!!!!  and ironically, when i noticed the smell i also saw water around the base of the kenmore elite oasis top...
Hello plz make sure the gas burner does not have any lint build up on burner assembly inside the machine / plz clean.That usually causes a burnt smell. If there is no error codes on the display and the machines is operating fine you are chasing a ghost. If there is a pump or motor over load an error code should come up on the display.
Dec 11, 2008 | Kenmore Elite HE4 Electric Dryer
Jul 21, 2008 | Kenmore 67082 Electric Dryer
Dryers Logo
551 people viewed this question
Top Dryers Experts
