Question about Goodman CLQ36AR49 Air Conditioner
Goodman Furnace/AC unit not working 3a fuse blows even after replacement. once thermostat is turned on and clicks to start ac unit the fuse blows
  • deemetriuss1 Apr 15, 2009
    my circuit board got burnt when an electrician came to rewire th 240V aluminum wires on my installation, and after that I replaced the board and the transformer, but even then it blows the 3 amp fuses.
  • 182 Answers
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Posted on Jul 04, 2008
  • 330 Answers
I supposed Goodman Furnace /AC is a central unit.
How many BTU?
What kind fuse did they use before?
Seems 3amp fuse is too weak, more details.
Posted on Jul 03, 2008
Open rollout or open fuse on Goodman
the fuse is located in the circuit board in the blower compartment and the roll-out is located in the burner section and can be a reset-able switch style or the one time fuse link style which is a a small silver cylinder and is mounted in a ceramic piece and is held in with one screw. Both of these are mounted around the opening of the your burner assembly near the opening. This will be near the area of the gas valve.
Sep 24, 2012 | Goodman Manufacturing Goodman R410A 13...
We have Goodman Model GHP 0 75-4 Gas unit. The 3A fuse continues to blow. We replaced the Transformer, (it smoked). The moment we turn on the thermostat to "Cool" the 3A fuse blows on the...
Hello, sounds like something is shorting to ground, make sure all the low voltage wire are secure at tne indoor unit and the outdoor unit, also check the thermostat wiring all the way from tne outdoor unit to the indoor unit aor any cuts or missing insulation.
Jul 22, 2011 | Heating & Cooling
Hi Proper way on wiring furnace.
I can give you a start, For heat only, R terminal on furnace to Red wire to R or RH terminal on thermostat. W terminal to White wire to W terminal on thermostat. G terminal to Green wire to G terminal on thermostat. This will get you heat but not air conditioning.
Jan 06, 2010 | Goodman Heating & Cooling
I have a goodman furnace and ac unit the fan and heat work but every time i turn the ac on it blows the low voltage fuse ive replaced all low voltage wires to outside unit and thermostat i also replaced...
Look at the contactor on the condensing unit, remove the low voltage wires to the contactor and turn on the system. If the low voltage fuse doesn't blow, replace the contactor.
Jun 24, 2009 | Goodman CLQ36AR49 Air Conditioner
I have a goodman furnace and ac unit heat and fan work but soon as i flip the ac on it blows the 5amp fuse at the furnace
their is a control short some place check the control wiring . dog or rodents chewing threw it or shorted controls or thermostat id get service. Tom
A/C blows fuse on call for 2nd stage.
my guess would be a problem with the low voltage wiring a short have it checked out by an electrician
Jun 21, 2009 | Goodman Heating & Cooling
Goodman furnace
double check your wiring. R terminal on the furnace will provide 24 volts to the t-stat. W terminal in the t-stat will send 24 volts back to the furnace W terminal to turn on the heat. G terminal in the t-stat will send power to the G terminal in the furnace when the t-stat is switched to fan on. Y terminal in the t-stat will send power to the Y terminal in the furnace which in turn will send 24 volts to the A/C outside. The C terminal in the furnace should be connected to the c terminal in the A/C outside as well as to the T-stat. Check the fuse again
Jun 02, 2009 | Goodman GMS90703BXA Heater
Problems with low voltage control wiring turning on cond. unit
Only 2 wires going outside.
Yellow from the thermostat and the common wire from the lv side of the transformer.
Apr 28, 2009 | Heating & Cooling
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Jun 26, 2008 | Goodman CKL60AR60 Air Conditioner
Goodman GMS90703BXA Heater/AC - 3 Amps Fuse blows
This fuse is used on the low voltage side of the furnace. All 24 volt controls operate thru it. You may have a short in your thermostst, thermostat wire or even a bad transformer. After replacing the fuse, inspect the wiring in the cabinet as well as the wire heading toward the thermostat for damage. If you find none, check the thermostat for loose wires or contacts. If all else fails, jump out R and W with a small jumper temporarly at the furnace and see if the unit runs. You will have to tape the door switch closed to run it with the panel off. Remember, this will keep the furnace running 100% of the time until you disconnect the jumpers. Not a solution, just a test! If it runs flawless, you have a bad thermostat or wire. Diagnosing a transformer is for a technician.
Aug 12, 2007 | Goodman GMS90703BXA Heater
Goodman CLQ36AR49 Air Conditioner Logo
1,004 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
