Question about Samsung DLP HL-P5663W 56" TV
Humming noise when turned on
My tv hums continuously when turned on .is there a setting problem ,age problem? I hae a 61" TV and we just replaced the lamp thinking it was the problem, but there is a loud humming sound even when i mute.
    Sergeant:
    Champion:
  • 417 Answers
There's a air break in the tv needs professional service by a electioneer can be dangerous if you attempt to fix it yourself
Posted on Jul 03, 2008
My tv makes a loud humming noise when it is plugged in. I just replaced the lamp and the noise remains. Any suggestions
Hello: Have your color wheel replaced in this model. The color wheels motor bearings are going out, this is the humming noise you are hearing. you can replaced this part yourself if you are somewhat electrically and mechnically inclined. There are youTube videos that will show u the process.
Nov 20, 2009 | Samsung HLT6187SAX 61" DLP HDTV
Making a lot of noise
Sounds like a bearing in the cooling Fan
Thanks for using FIXYA
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung hln 61 make loud humming
yes this is a very common issue with Samsung DLp's, and it will get louder and louder until TV will not turn ON anymore. You can replace it yourself is very simple, here is kind of a guide for that http://guides.fixyourdlp.com/samsung/bp96-01579a.php and http://guides.fixyourdlp.com/samsung/bp96-01854a.php
Jun 25, 2009 | Samsung HL-P6163W 61" TV
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
Tv hums when hdmi is connected via dvd player
how do you have the audio hooked up for it if you are using componet cable (red,white) for sound they could be causing the humming you can either switch audio cables or use some other form of cable for sound
Jan 24, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Annebatiste:
Humming almost always comes from DC supply problems.A leaky SCR [silicon control recitfiter] transistor [used in a/c to dc power supply], leaky Capacitor [large metal type for heavy voltage\current], bad or value changed bias for SCR transistor, value changed filter resistor and loose transformer[Xformer] that the coils INSIDE vibrate sending a radio frequency [R\F] SIGNAL (like a radio station) into the audio amp section or right into the speakers causing the hum.
Check entire power supply, all filter capacitors, coils, chokes ,transformers (somtimes used to push signal into speakers)
Jun 28, 2008 | Samsung DLP HL-P5663W 56" TV
RCA repair question
i turned the blacl level and contrast all the way black.now i cant pull up menu to set regular settings. what do i do?
Aug 20, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
Zenith C27V22 27" TV loud humming noise
There is a coil in the set with a magnet glued to it, called the horizontal linearity coil. Sometimes the coil "sings", making a squeeling sound. I have seen this many times, and there really isnt anything actually electrically wrong with the set. To stop the squeeling the coil should be replaced.
Jun 19, 2007 | Zenith C27V22 27" TV
Samsung DLP HL-P5663W 56" TV Logo
186 people viewed this question
Henry  Thomas
Henry Thomas
