Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
About hrd ware failure
Some time my compute get hanged due to the when i useing the video editing &grapic software instaled or louched in my computer why the happence can u solve my pro,,,,,,m
  • Gary Luis
    Gary Luis May 11, 2010
    What service pack are you running, what OS, amount of memory, program used for editing?
    You can find this information by clicking on START, SETTINGS CONTROL PANEL. Click on SYSTEM. Click on the GENERAL tab.
  • 186 Answers
I beleive that Notebooks are not ment for heave memory utilizing applicatios like Video or Audio editing.
However, in the current situation, try reinstalling the Graphic Card Drivers which should resolve the issue.
Posted on Aug 14, 2008
Plz tell me how to download a latest video editing software for my sony handycam
Losing your Handycam software is the best thing that could have happened to you all. It stinks. Firewire eliminates the need for the crummy camcorder software. Basically, you need to install, or have installed, a Firewire card in your PC, then buy a Firewire cable. Then WinDV software will work perfectly to import video. USB connections, and the USB cable, are ideal for downloading digital still images from cameras. Running footage requires a very large bandwidth, which basically is the throughput from camera to computer. Think of a funnel with a small opening. The small opening is USB. Make the opening 4 times as large and nothing backs up in the funnel. The large opening is Firewire. Anyways, by using a Firewire connection, you can bypass the camcorder software and use "real" video editing software.
http://windv.mourek.cz/
As for the video editing software
You can use Sonys movie studio http://www.sonycreativesoftware.com/moviestudiohd
Or
Windows Movie Maker - The best video editing tool for Windows that's free and chances are you already have it installed on your computer as part of XP SP2. Microsoft Movie Maker has all the basic video editing tools plus a good collection of transitions and video effects.
There's an in-built movie titler that lets add you styles to text titles including ticker taps, zoom and even the scroll effect. And if you are feeling lazy, just hit the AutoMovie command to have the entire video produced for you with intervention.
Feb 28, 2011 | Sony Handycam® DCR-TRV250 Digital-8...
I have re loaded maxtor onto anothe computer using the start up disc but when executing a window appears asking for driver information. what do i need to do ?
it is asking for the drivers that it needs to "talk" toyour drive. a driver is a small software program that makes a hrd ware device work. when you bout the drive there should have beena disc with drivers on it. perhaps the startup disc even. unplug the drive from the computer and install the drivers then re plug it in. it should work. if you do not have the drivers for it you can get them from www.maxtor.com/support
but most likely the disc you have has them on it. the trouble you have is that you MUST unplug the drive and install the drivers FIRST. othwise you will get an error asking for the drivers.
so just unplug it and put the disc in you drive and look for "install drivers" option when the cd starts up.
Jun 27, 2010 | Maxtor (A01E250) 250 GB Hard Drive
How to transfer videos on the computer??
hi friend,
step 1
Check out the specs of your camcorder and computer, to see the kind of connection you need to transfer video to your PC. Most Macs and some PCs come with firewire cable ports. Check for the port.
  • Step 2 Install a PCI card, if your computer does not support firewire so you will be able to use the firewire cable. You can buy one at an electronics store.
  • Step 3 Shop for video editing software if you plan to edit your video. Find out what kind of file format your video editing software is compatible with. File formats are avi, mpg, mov, moov, movie or qt.
  • Step 4 Make sure the computer and the camera is on. Plug the cable into the appropriate location on your video camera, which varies on different models of camcorders. It should be labeled.
  • Step 5 Plug the other end of the cable into the computer in the appropriate spot. This will vary depending on the model. It will usually be located on the side or the back of the computer. Your computer should automatically detect your camcorder.
  • Step 6 Open the footage in your video editing software and capture it if you plan on editing it. If you just want to put the video on your PC, just save it to your hard drive as an avi file.
  • Step 7 Use your video editing software. Make all editing changes. If you need help, read the tutorials in the software.
  • Step 8 Copy the digital video to a DVD when you are done.
  • Step 9 Disconnect the firewire cable. You will not need to turn off the computer to do this.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • If you don’t see an firewire port, use the windows "device manager" to find out if it is installed.
    • If you are using Windows XP, then you will have the software to capture video with the Windows Movie Maker program. If you have an older windows you will need to buy video editing software.
    • You will need a lot of storage space on your computer, because video files tend to take up a lot of space.
    hope this helps u
    please rate me...........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | Hitachi DZ-MV200A DVD Camcorder
    Computer Hanging Proublum
    i would say your motherboard could be going out
    Aug 06, 2009 | Microsoft Windows 98 for PC
    Video editing software for windows vista
    Bro, I can fix this
    Editing software is a must but can be expensive.
    This is my best advise to get everything you need.
    Go to www.Myspace.com/KyleGallas to watch a video of a Custom Gaming Computer with Tons of editing software...The PC has like $4,000 retail for like $659. It comes with a ton of extras like Cyberlink Power Director, 133 Nintendo DS Games, Fallout 3, Adobe CS4 Master Collection, MS Office Ultmate 2007, Roxio Ultimate 2009...and more...Nothing is trial-ware but yours forever.
    Apr 23, 2009 | Panasonic NV-GS25 Mini DV Digital...
    Is a good free software that i can use with my panasonic sdr-h40 , i have xp , i have set up the software that comes with the camera but it doesnt seen to work , needing either a editing software or a...
    Bro, I can fix this
    Jan 13, 2009 | Panasonic SDR-H40 HDD Camcorder
    Need to capture video
    Are you talking about editing software or capturing video off you computer as you move the mouse...anyways...
    Bro, I can solve this
    Go to www.Myspace.com/KyleGallas to watch a video of a Custom Gaming Computer with all the needed editing software needed...The PC has like $4,000 retail for like $659. It comes with a ton of extras like 133 Nintendo DS Games, Fallout 3, Adobe CS4, MS Office Ultmate 2007, Roxio Ultimate 2009...and more...Nothing is trial-ware but yours forever.
    Jan 04, 2009 | Intel Pro PC Camera CS430 Webcam
    ZR85
    Hi! If you go to the Canon, they have a trouble shooting section. I copied and pasted some information below. Good luck!
    Details Print Friendly Version Issue: How do I transfer video tape recordings to a computer via Firewire?
    Solution: Transferring video recordings to a computer ZR80, ZR85, and ZR90
    Transferring Video Recordings to a Computer You can transfer recordings to a computer using the IEEE1394 (DV) terminal. With the ZR85 and ZR90 transferring video recordings via USB is not possible.
    Before starting the video transferring, make sure to prepare the following:
    • A computer equipped with a IEEE1394 (DV) terminal or a IEEE1394 (DV) capturing board (the IEEE1394 protocol is frequently also called "Firewire" or "iLink").
    • A DV cable (sold separately)
    • Video Editing Software
    You can use (1) the video editing software that came bundled with your computer or video capturing board, (2) the video editing software included with your operating system ("Windows Movie Maker" with Windows Vista Home Premium, Windows Vista Ultimate, Windows XP and Windows ME, "iMovie" with Mac OS 9 and later), or (3) video editing software purchased separately, with features ranging from very basic to very sophisticated.
    • The appropriate driver
    A driver is included with Windows operating systems later than Windows 98 Second Edition and Mac operating systems later than Mac OS 9. The driver is installed automatically when you connect the camcorder to the computer. No additional driver is necessary or available.
    1. Start your computer.
      (If this is the first time you are connecting the camcorder to your Windows based computer your computer will display the "New Hardware Found" message while the driver is installed automatically.)
    2. Set the camcorder to playbackicon.gif mode.
    3. Connect the camcorder to the computer with the DV cable as shown below. Once the camcorder and computer are connected together the camcorder will display "DV IN" on the LCD/viewfinder. This message confirms that the camcorder is ready to receive or transfer video.
    4. Refer to the instructions for your video editing software to download your video from the camcorder.
      Note: Because procedures for digital editing software applications vary greatly, Canon cannot offer any additional support or suggestions regarding downloading and editing your video. Please refer to the software publisher or your computer manufacturer (if the software came with your computer) for assistance in using the software.
    • Operation may not work correctly depending on the software and the specifications/settings of your computer.
    • If the computer freezes while you have connected the camcorder, disconnect and reconnect the DV cable. If the problem persists, disconnect the interface cable, turn off camcorder and computer, turn camcorder and computer back on and reconnect them.
    • Before connecting the camcorder to the computer using a DV cable, make sure that camcorder and computer are not connected with a USB cable, and that no other 1394 device is connected to the computer.
    • We recommend powering the camcorder from a household power source while it is connected to the computer.
    • Refer also to the instruction manual of the computer.
    • The programs ZoomBrowser EX and Image Browser included with the supplied CD-ROM are intended for use only with images recorded on the memory card.
    • Video recordings on the tape cannot be transferred to the computer using the software included with the supplied CD-ROM.
    Nov 07, 2008 | Video Cameras
    Why does qosmio F25 hang and flicker?
    hardware issue.. ur video card adapter has a problem
    Jun 04, 2008 | Microsoft Windows XP Media Center Edition...
    HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
    35 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
