Keyboard not working. Tried several different keyboards and all do the same. The lights on the keyboard come on for a couple of seconds than go off, and the keyboard does not work.
    President:
  • 1,314 Answers
PS/2 port is bad. Instead of using the regular keyboard with the purple end, get one that is USB.
Posted on Jul 03, 2008
My IVSO bluetooth keyboard has a different keymap
Have you tried adjusting the country code for the keyboard from say, UK to US?
Oct 12, 2016 | Samsung Galaxy Tab 10.1 GT-P7500 3G WiFi...
Logitech m205 won't work, the light keeps blinking
If your unit is a wireless keyboard only, then there is a button on the bottom of the keyboard and another on the receiver that is plugged into the usb port of the computer. In order to calibrate the system when it looses its signal, you have to press and hold both buttons down at the same time for 30 to 45 seconds. That means press the button the receiver and the button on the bottom of the keyboard at the same time and hold them down for 30 to 45 seconds. This will revive the signal and bring it back to working condition.
If your unit is a wireless mouse and wireless keyboard then there are probably 3 buttons involved that need to be pressed and held for 30 to 45 seconds at the same time. One button on the mouse, one on the keyboard and the last on the receiver.
If you press and hold the buttons down as explained above, it will correct the problem.
Jul 17, 2011 | Logitech Computers & Internet
I am having trouble when I try to type double letters....like the t in letter - it's like the second t is sticking. It is doing it with all the letters that are consecutive....been, etc.
That's strange never seen this before, have you've tried a different keyboard to see if another keyboard works. If another keyboard works then it is definately the keyboards problem, and it is probably easiest to just replace the keyboard. You could try cleaning the keyboard as well look online for the proper way to clean a keyboard.
djbr1ck
May 12, 2011 | GE HO-98091 (ho98091) Keyboard
My dell keyboard with blue tooth connection
If there is no light on the Bluetooth keyboard it means there is a problem with it.
If the Bluetooth keyboard is not responding try to do the following:
1. Change batteries
2. Go to control panel
3. Click Bluetooth Icon
4. Delete the Bluetooth Keyboard
5. Click on Add new wireless device
6. Press the pairing device on the keyboard
7. Bluetooth keyboard will be detected
8. Follow the onscreen instructions
Hope this helps, Tried it several times and it works perfectly
Nov 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Replace batteries
Usually there is an order to do it in, but as
you only have a keyboard there is only 2 ways. Keyboard first receiver second, if that doesn't work receiver first keyboard second. If the batteries are OK then you should have no problem.
However as you have posted this in a keyboard AND mouse section then like me you may have to do the following to get the right order..
Consider your keyboard as No1
Your reciever as No2
Your mouse as No3
So the order to try is 1st 1,2,3. If that doesn't work then 2,3,1 and finally 3,2,1 Youve now tried all the different ways.
Aug 09, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard doesn't work
If you have droped any kind of liquid on the keyboard get it replaced
Apr 17, 2009 | Computers & Internet
Keyboard doesnt work on my repaired emachine with win xp
Could be a couple of things.
First, try connecting another keyboard using the same type of connection as your keyboard. (PS2, or USB). If that one works in the machine; then it's more then likely that there is a problem with your keyboard.
If it doesn't work, it may be a problem with the system itself or possibly a software problem. To test a keyboard is very simple and this test is integrated in most of the BIOS startup systems today. Simply press more than 7 keys right when you turn your power on to the system. If it beeps after a few seconds of holding or brings up a keyboard error, then the keyboard is communicating with the system. If there's a keyboard error that actually states that there is no keyboard present; then there is a problem.
I hope this helps you narrow it down. If it's not the keyboard itself, and you can't get any keyboards to work, I'd have that shop take another look at what they did.
Sep 29, 2008 | E-Machines eMachines Desktop PC
Ps/2 keyboard port not working
Slim, Other than saying well it was a good couple years for the board lets just verify: Have you tried a different keyboard? Check device manager and see if you uninstall the keyboard and then reinstall it. Or have you recently installed any new devices that may have taken the resources away from the keyboard plug? If not get a usb keyboard and make sure you info is backed up...just in case. Good Luck, Tim
Feb 10, 2007 | MSI KM3M-V Motherboard
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Sep 13, 2006 | Gateway 2520915 Keyboard
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
